Question about Kenmore 54613 / 54616 Side by Side Refrigerator
Water dispenser not working. Model 54616.
Water dispenser just stopped working. Filter replaced about 1 month ago.
  • scooter9800 Jan 02, 2009
    It took a while but all is fixed now. Thank you for the advice.
  • 700 Answers
Ok i owuld look at the resevour tank and take a hair drier aand heat up the oiutlet till the water flows again.
Posted on Jan 02, 2009
  • Todd Born
    Todd Born Jan 02, 2009
    ok i owuld look at the resevour tank and take a hair drier aand heat up the oiutlet till the water flows again.
Ice and Water not dispensing. Light button not working
http://www.repairclinic.com/0100_1.asp
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Jul 04, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
How and where do you change water filter
From the KitchenAid Manual:
The water filter is located in the upper right-hand corner of the
refrigerator compartment.
Replacing the Water Filter
To purchase a replacement water filter, model 67003523 Part
Number 4396395, contact your dealer or call 1-800-442-9991
U.S.A. or 1-800-807-6777 Canada.
IMPORTANT: Air trapped in the water system may cause water
and filter to eject. Always dispense water for at least 2 minutes
before removing the filter or blue bypass cap.
1. Turn filter counterclockwise to remove.
2. Remove sealing label from replacement filter and insert the
filter end into the filter head.
3. Turn the filter clockwise until it stops. Snap the filter cover
closed.
4. Flush the water system. Depending on your model, see
"Water Dispenser" or "Water and Ice Dispensers."
NOTE: The dispenser feature may be used without a water filter
installed. Your water will not be filtered. If this option is chosen,
replace the filter with the blue bypass cap.
http://www.kitchenaid.com/digitalassets/KFCS22EVMS/Use%20and%20Care_EN.pdf
May 16, 2014 | KitchenAid KFCS22EVMS French Door Bottom...
Where is the water filter on my whirlpool model gx2fhdxvy09
Water Filtration System
Do not use with water that is microbiologically unsafe or
of unknown quality without adequate disinfection before
or after the system. Systems certified for cyst reduction
may be used on disinfected waters that may contain
filterable cysts.
IMPORTANT: The disposable water filter should be replaced at
least every 6 months. If the water flow to the water dispenser or
ice maker decreases noticeably before 6 months have passed,
replace the water filter more often.
To purchase replacement water filters, model UKF8001AXX-750
or model UKF8001AXX-200, contact your dealer or call
1-800-253-1301 U.S.A. or 1-800-807-6777 Canada.
closed.
4. Flush the water system. See "Water and Ice Dispenser(s)."
User Manual=> HERE I am here should you need me, Thanks John Tripp Appliance 911
Apr 16, 2014 | Admiral 26 cu. ft. Side-By-Side...
[LG Refregerator] Model LFX25961AL water does not dispense and ice is not being made
Make sure the wire guide that pulls up when ice is at full capacity is not accidentally pulled up. (this is above the ice bin in the freezer). Pull back down and should make ice.
Dec 17, 2013 | Refrigerators
Icemaker/water dispenser not working.
Just had to defrost the water tank inside the fridge for a few minutes. Using a waterproof heating pad with extension cord did the trick. Even a fridge needs a warm blanket from time to time.
Oct 21, 2009 | Jenn-Air JFC2089HE French Door...
When water dispenser is pushed the water supply line rattles and very little water comes out. The water supply line has good pressure and the ice maker works. I also changed the filter.
Our water dispenser will work for about half a glass then the pressure immediately stops and the water flow goes to a small stream. Maytag MDZ2667HES Wide by Side. HELP! Filter was changed approx 3 months ago.
Oct 12, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Maytag 2561HES No water coming out of dispenser
Most times that is the dual water control valve on rear of your refrigerator. Sometimes the switch in the door. Have someone pull the refrigerator away from wall and unplug the wires going to each side and ohm the coils. They should both show very close to the same amount of resistance. If you still have problems, let me know and make sure the model number has a prefix like MDO2561HES for example. That way I will be able to help you better. Thanks
Jun 19, 2009 | Refrigerators
My water dispenser suddenly has stopped working.
Yes, it could be the water filter. Also check to make sure the water is turned on and that any lines to the refrigerator aren't kinked or crushed somewhere. It's also possible that you will not be making any ice as well if your appliance has an ice maker
Apr 06, 2009 | GE Profile PSW26P Stainless Steel Side by...
Kenmore 54613 / 54616 Side by Side Refrigerator Logo
71 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
