Question about Amana ACS3350AS Gas Kitchen Range
Control Panel has given out (ACS3350AS)
I bought this stove 5 yrs ago. I have the same problem as everyone else with the heat escaping and heating the control panel. Wish I knew this was a general problem before my family sustained burns. A recall might have been nice. My control panel has given out and I got 2 quotes to repair/replace the control panel: part is $269, labor is $160. This really gets me angry! I believe a stove should last more than 5 yrs! Amana Customer Service was totally unsympathetic!
1) Does anyone know how diificult it is to replace this part on your own?
  • Vicki May 01, 2009
    Have you received any assistance from Amana or Whirlpool?
    Vicki
  • 3 Answers
See the solution I posted here:
http://www.fixya.com/support/t519198-amana_acs3350as_never_buy_amana
Posted on Jan 17, 2009
Maytag MIR8890AS0 6.2 cu.ft. induction range w/true convection. Takes an hour or more for oven to pre heat, doesn't maintain heat. 4 yrs old. Induction top OK.
I don't know, but it sounds like one of the heating elements are burnt out/no longer working. I had a similiar problem 5 years ago.. they're pretty easy to replace yourself if you are handy and have a screw driver. I think the one for my stove cost $18 to replace (5 years ago) here's the trouble shooting guide online for you model:
Maytag Range Stove Oven MIR8890AS0Troubleshooting Repair Help
Dec 07, 2016 | Maytag Kitchen Ranges
Frigidaire oven wont heat up but stovetop and digital all works
Hello angeleyez82 - The EOC (electronic oven control/control board) basically sends power to both the broil and bake elements. As long as the power supply to the range (240VAC) and wiring between the elements is correct, then typically only the element(s) or EOC could prevent the unit from heating. I hope this information helps to some degree.
Jun 25, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
The heating element goes on but the oven does not heat up. A few months ago noticed that it began to heat up very slowly. Now does not heat up.
Hello, dinophyl (early Jurassic protozoa, hey) Do you have a Gas or Electric kitchen range? Very good possibly that the thermostat control in the oven is bad. That little brass bulb in the oven. This controls the internal temperature of the oven. If it an electric range then the the electrical thermostat on the oven knob could also be the culprit also. GB..stewbison
Sep 24, 2011 | Amana ACS3350AS Gas Kitchen Range
My Maytag stove. I know it's normal to feel heat from the vent on the stove top when the oven is on. But the temp of the heat escaping is sooo much hotter than it used to be. Do I need a fix ? Model...
The heat from your vent should be a little lower than what the oven is set at. So I doubt if you have a problem but you might want to take some temperature measurements to see.
Sep 07, 2011 | Ovens
I have an Amana ACS3350AS Gas range and the Control panel cover has cracked due to heat.After much searching on the web I found a replacement but I can't seam to find any manuals on how to dismantle it...
hello, this unit should only have screws under the control panel when you open the oven door. some of them have a side screw on each side when you pull out the oven an inch or two. hope this helps
Jun 08, 2011 | Amana ACS3350AS Gas Kitchen Range
Amana ACS3350AS stove temp in oven stays at 100 degrees . takes 1/2 hour to light or get to set tempeture. replace senor temperature and control panel. what should i do now
We had the same problem and it turned out to be a burned out lower heating element. Only the top one was heating and I could never get it over about 150deg or so.
Mar 16, 2009 | Amana ACS3350AS Gas Kitchen Range
AMANA acs3350AS
Here are your part numbers:
Control: 31944801
Overlay: 32061901B
There are several online sources such as repairclinic.com or sears.com just search appliance parts and you can compare prices if you like or you might even call an appliance store to see if they can order them for you. When you decide where to buy use those numbers and you you will get what you need to fix your range. Good luck.
Jan 06, 2009 | Amana ACS3350AS Gas Kitchen Range
Self Clean won't start - Amana ACS3350AS Gas Kitchen Range
Our door on this oven is coming apart, so the oven door never truly closes.  When you set the self clean cycle, push the door shut until it locks... at least this has worked for me.  But I think all your problems, which are similar to mine, result from the oven door not truly closing... heat escapes, so the temp is not right and takes forever to heat up.  The heat melts the control panel, causing other problems.  In fact, our door is starting to fall open... a bit dangerous.
May 06, 2008 | Amana ACS3350AS Gas Kitchen Range
Amana ACS3350AS Gas Kitchen Range Logo
325 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal De GO PATS
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
