Question about Magic Chef 9122 Gas Single Oven
I just cleaned by hand by magic chef wall oven and now I can't
Figure how to light the pilot light. what is a pilotless ignation mean??
First time cleaning it and I tried turning the oven on but nothing happened? Did I not leave it on long enough but I was leary of leaving on because it is a gas oven.
  • Anonymous Jan 31, 2009
    oven will not turn on at all
  • 306 Answers
Pilotless ignition means that a hot surface ignitor lights the oven burner. It does take a little bit of time to light the burner. Maybe 30 seconds. If you want to make sure it lights take the bottom panel out from the oven and observe the hot surface glow and the burners light. No real danger as the gas valve will only open after the hot surface ignitor has satisfied the gas valve. Let me know how it goes. ken
Posted on Jan 02, 2009
Pilot light flame too loeeds adjustment
Adjust the pilot flame height using the adjustment screw for each burner.
Mar 12, 2014 | Magic Chef Ovens
Magic Chef Chateau stove pilot goes out when two burners are used!
The pilot flame may not be set high enough to cope with the demand of two burners.
Dec 19, 2013 | Ovens
MY MAGIC CHEF, CONCEPT SERIES, W/MAGIC CONTROL CENTER DOESN'T LIGHT.
I have a Magic Chief Concept Series oven - Replaced the Thermo-coupler and the control switch. I now have a pilot light but the thermo-coupler doesn't get hot enough to light the burner, But if I take a lighter and put it on the thermo-coupler it will but when I take if off it shuts off after a few seconds. Could you please give me Ideas of what could be wrong
Dec 18, 2012 | Magic Chef Ovens
We have a Magic Chef gas oven (model # CPL1100BDW) without electronic ignition. The oven isn't working. The oven pilot is out, can't get it to light, and the oven will not light - (obviously)....
Hello & Welcome to FixYa
If the pilot is clean and still won't light then the problem is with the safety valve that won't open and so needs replacement. Please get back to me if you have any other questions.
Kevin
Nov 14, 2011 | Magic Chef Ovens
I have a magic chef electric wall oven and it flashes an error code of F3 when I try to bake something. How do I fix it and what does it mean?
The F3 code means that the temperature sensor in the oven is not giving the signal to the oven control. This could be the result of a problem with the wiring or the wire harness between the control board and the sensor or indicate that the sensor itself has failed.
To identify the correct parts, you need to provide your oven model number. Try here: http://www.partselect.com/Magic-Chef-Parts.htm . There are other sources for parts.
I hope this helps. If you add a comment with the model number, I'll be glad to give you more specific information for your wall oven.
Sep 25, 2011 | Magic Chef Ovens
I have a magic chef gas stove witch has electric pilots.when i turn on oven it seems the electric pilot lights up but the burner doesn't come on.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or
Oven not Heating
Oven Problems
Replacing the Igniter
heatman101
Jan 06, 2011 | Magic Chef Ovens
Magic Chef range the pilot on the oven will not light.
Is this a manual lighting pilot,do you light it?
If so you may have a bad gas valve.
If this is an auto light pilot it could be the electronic spark is bad.Im guessing the popping noise is the autospark trying to light.
Jan 05, 2010 | Magic Chef Ovens
Gas smell oven does not light
you may need new coupler on pilot system
Jun 23, 2009 | Magic Chef 9122 Gas Single Oven
Old Magic Chef Gas Oven won't light
sounding like thermostat isn't working. If you could ohm out the t-stat should be closed when you call for heat. If that passes the test then only thing it could be is the gas valve.
Nov 24, 2008 | Magic Chef Ovens
How to light the pilot in my RV?
push in on the themostat when the oven is on piolt hold a lighter under the burner and presto also light the stove to get gas flowing first this can take up to fifteen min to light if it has been awile since lit
Jul 19, 2008 | Magic Chef 9512 Electric Single Oven
Magic Chef 9122 Gas Single Oven Logo
479 people viewed this question
Top Magic Chef Ovens Experts
Dan Webster
Dan Webster
Sal De
Oloyede Monsuru
Are you a Magic Chef Oven Expert? Answer questions, earn points and help others
