Question about Whirlpool Duet GHW9150P Front Load Washer
Water leaks from whirlpool front loading washer when washing heavier loads
  • threedj1 Jan 18, 2009
    I have the same problem with heavy loads. It isn't leaking from the door, it is underneath the machine near the front right.
    Problem Solver:
  • 6 Answers
Check your rubber seal in the washer by the door and make sure your getting a good seal. Part of the seal has probably pulled loose.
Posted on Jan 02, 2009
First check is the standpipe drain. The hose that comes from washer should not be inserted more than 4". More than that can cause a syphoning situation that can cause leaks from beneath. If that seems okay you will have to see where water is coming from by observing the machine in action with back or bottom service panel removed (if it has one.)
Jan 06, 2013 | Whirlpool LHW0050PQ Front Load Washer
Our front load whirlpool washer gradually fills over the course of the day it is like there is a slow leak into the washer
water inlet valve in the machine is either sticky or faulty. get it replaced. till the time, after wash, keep your water valve (which supplies water to the machine) closed
Mar 19, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Front Loading Door leaking water
The most common cause for a front loading washer to leak from the front door is a torn or detached gasket where that gasket attached to the machine.
Open the door and begin to pull the gasket away from the opening. Look for any problems. If you find a place where the gasket is not firmly secured to the opening, you can list that area up and glue (even with super glue) the gasket back down to the metal opening.
If you find gasket damage, it will need to be replaced.
Jan 03, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
Whirlpool front load leaking water from the detergent dispenser
Could be pressure too high reduce feed to machine only ....Slightly...Also try cleaning just in case its blocked
Sep 28, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Water filling up in Front loading Whirlpool washer
sounds like you have a faulty water valve that does not close when the power is not supplied to the machine.or a problem with the cotrol board supplying power to the valve when the unit is not in use
Sep 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
HE2 washer leaking water from bottom of door/seal during washing
Open the door so it is 90degrees from machine, see if it is upright. if not undo the door bolts slightly and re alighn door. Good luck and feel free to give feed back.
Sep 03, 2009 | Kenmore HE2 Plus Front Load Washer
Whirlpool top loading washing machine water comes out of the bottom
whirlpool top load washer leaking water into tub with unit in off position
Jun 20, 2009 | Washing Machines
Whirlpool fron load Duet washer leaks
Check the easy stuff first, fill hoses tight?- drain hose cracked? Failing those checks, cut a piece of cardboard slightly smaller than the size of your washer. Slip the cardboard under the washer and run a short load. Look carefully at the water mark on the cardboard. The mark on the cardboard the water leak will leave, will help you tell from which side or front to back the leak is common from. This will help point you in the correct direction to look for the trouble maker.
Oct 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
WhirlPool Front Load Washer Leaking
to richhardh..
did u try holding the "End of Cycle Signal" button for 3 ?
May 16, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
132 people viewed this question
Dan Webster
Dan Webster
Sal De
