Question about Jeep Yellow Sports Outdoor Power Wheels vehicle
No power supply to gearbox
New 12 volt Barbie Jeep Battery has been fully charged and used unit sat for 1 week unpluged with charger attached to battery.Battery has been charging for 6 hours with no resolve.Is there a fuse somewhere on this unit?Model#L7820-9993
It has a thermal fuse. Depress the gas pedal for 25 seconds and try it then
Posted on Apr 18, 2009
After a year in storage, jeep won't work.
the radio runs off of a seperate battery source, so that wouldn't have any effect on this, i would first of all check the battery and charger with a multimeter and make sure that they are showing the correct voltage, if its a 12v battery make sure that they are showing at least 12 volts, if its a 6v battery make sure that its showing at least 6v
Jun 06, 2012 | Fisher Price Power Wheels Barbie Jeep
HOW DO I CHARGE THE BATTERY ?
In the hood of the jeep there is the battery. The jeep should of came with a plug-in quick charger that fits in a general outlet. Simply unplug the battery, and plug it into your wall in the house, etc.
Sep 04, 2011 | Fisher Price Power Wheels Barbie Jammin'...
I have lost the ac adapter for my Xantrex Powerpack 200 Plus. Where can I get one for a reasonable price?
You need a 12 Volt AC/ 1 AMP (1000ma) charger. You can use one with a lower ma rating but it will take longer to charge. The factory unit will take 35 hours to fully recharge a totally discharged battery. If you use your car's cigarette lighter it will take 3 hours if you're charging and driving. Good Luck!
Aug 24, 2011 | Xantrex Technology XPower Powerpack 200...
Upon power up, 3 red LEDs flashing rapidly continously, no power.
The control systems on power mobility equipment have a "prevent" circuit that immobilizes the equipment while it is plugged into a charger, so folks won't take off with it plugged into the wall outlet. When you turn it on when plugged into a charger, the display will flash constantly, or sweep constantly, depending on the manufacturer. This is normal. Your off-board charger should have a red light to indicate power to the charger, and another light for the charge status. Yellowish means it is charging, when it turns green, you are fully charged. If the status light is green all the time, that is an indication that the charger is not functioning properly, or that the batteries are below a chargeable state. Check charger output, which should be 26-28 volts dc, and each battery should show at least a 12 volt reading, but around 13.5 volts with a full charge. If one or both of the batteries drops below 12 volts after a short period of time, it's time for a fresh pair. Fully charge new ones before using the chair.
May 31, 2009 | Pride New Jazzy 600 Power Wheelchair by...
Tom tom will not charge using 12 volt charger
I have the same tomtom and it has the same problem. Sorry to say it is the battery. You cant change it it has to go to Tom Tom. I just bought a new one. Hope this helps.
Nov 17, 2008 | Tomtom ONE GPS Receiver
Mx 3000 universal lcd remote
There are 4 reasons why your unit is behaving this way:
1. Charger is the problem.
2. The docking station is the broken.
3. The battery is broken or not accepting charge.
4. The actual unit is the problem.
It is very hard to tell which one is causing this to happen.
Let us do some troubleshooting first:
1. Plug your charger in an A/C outlet and make sure the red power light (left) is lit, otherwise the charger or the docking station is broken.
2. You can test the charger with a multimeter. Unplug the charger from the docking station and measure the voltage across the outside and inside, it should register more than 5 volts DC. If there is a 5Volt DC the docking station is the problem otherwise the charger is broken.
3. If the red power light is lit and the status light (right) is lit too, your docking station is broken.
4. If the red power light is lit, dock the unit into the charger, the status light (left) should turn red when your battery is accepting charge or turn blue when your battery is fully charged.
5. If the status light will not lit at all (while the red power light is on), tap the screen while the unit is docked on the charger. If the unit will become alive, you need a new battery otherwise you need a new unit.
12 hours is very long time to charge, the status light should turn to blue in less than 2 hours especially for a new battery.
Aug 29, 2008 | Universal Remote Control MX-3000 LCD...
Jeep Yellow Sports Outdoor Power Wheels vehicle Logo
648 people viewed this question
Top Jeep Toys Experts
Glenn Smart
Glenn Smart
 Brian Main
Brian Main
Are you a Jeep Toy Expert? Answer questions, earn points and help others
