Question about Car Audio & Video
Kenwood kdc-mp438u protect mode is on and i did not have a passcode for it.. how do i get rid of this
  • egarza111 Jan 07, 2009
    Protect mode is on my stereo i cant do anything with it
  • Anonymous Feb 23, 2009
    Try disconnecting all the speaker wires and turn the unit on, if the protect mode comes back it is an internal problem with the unit, if when no speakers are connected the protect mode does not appear then you know there is a short in one of the speakers or wire. Connect each speaker one at a time checking the unit after every connection to see if the protect mode appears. If it appears after connecting one speaker you know either that wire or speaker is the problem.
  • 10 Answers
SOURCE: on my kenwood kdc mp438u i tried everything it
Unplug stereo with ingition on and leave for about a min. replug and it should display "Standby"
Posted on Oct 18, 2009
SOURCE: Protect mode Kenwood KDC MP438U in dash reciever
Anytime there is a short circuit or your battery down low enough you will recieve this signal. If you press the little "reset button" using a small pin or screwdriver your unit should reboot without the "PROTECT" signal. If seeing this "PROTECT" sign is a result of jumping your car, this will fix it. If the signal persists, then there is still a short circuit and you need to check your connection with the battery. Most likely it is touching the chasis or some othere metal.
Posted on Mar 29, 2009
SOURCE: Security Code for Protect mode
how do i unlock the protect mode on the kenwood kdc-mp239
Posted on Sep 24, 2008
  • 80 Answers
SOURCE: Kenwood KDC-MP438U and Nissan Pathfinder Steering wheel controls
you need an aftermarket PAC!
it will work just fine!
Posted on Feb 26, 2009
  • 22 Answers
SOURCE: I need a kenwood wiring diagram
I have found your owners manual your can click here or copy and paste the link into your browser.
Hope this helps.
Posted on Mar 10, 2009
How do you set the clock on a kenwood kdc-x592
Refer to Manual ... Exemple.... Download Kenwood KDC-MP438U manual & Setting On Google then take the one you need
Sep 29, 2010 | Kenwood KDC-MP438U Car CD/ MP3 Player
Reset security code
My Kenwood KDC-MP438U Says PROTECT, and I can't figure out how to get it to work
Jan 10, 2010 | Kenwood KDC-MP228 CD Player
On my kenwood kdc mp438u i tried everything it said to do but it keep saying protect
Could be a short circuit on your speaker output, try disconnecting all 4 speaker wires and then power up. Otherwise its the audio amplifier circuit that needs to be replaced ( audio IC )
Sep 27, 2009 | Kenwood KDC-MP438U Car CD/ MP3 Player
I got a Kenwood KDC-MP438U and its stuck on protected mode
Protected mode means that there is a speaker wire that is grounding out on the chassis, another wire or another wire. Check all the wire connections to make sure there is no loose wire that may be getting grounded out. After it's insulated properly and reconnected, hit the reset and you'll be back in business. k
Jun 07, 2009 | Kenwood KDC-MP228 CD Player
Kenwood KDC-MP438U reciever installed. No sound in any mode.
if its a newer truck it will most likely have a factory amp u either have to utilize or bypass
Apr 21, 2009 | Kenwood KDC-MP438U Car CD/ MP3 Player
Kenwood KDC-MP438U
Solution is simple and no code is needed. Make sure all wirw are secures and not opening spliced. Ones verifying, make sure radio is turned off and reset the protect button.
The Protect Button is pin hole size and is located right above the headphone jack. Hence all shpuld be good from there on.
Mar 10, 2009 | Kenwood KDC-MP438U Car CD/ MP3 Player
"PROTECT" is constantly displayed on the screen of my kdc-mp438u
You need to unplug the unit from the back and find the problem. Usually, it is almost always your speaker connections. Once you find the problem within the speakers, plug it back in and it resets it.
Dec 29, 2008 | Kenwood KDC-MP438U Car CD/ MP3 Player
Kdc mp438u
it says protect meaning one of the speakers is shorted troubleshoot my speakers all were good put my old radio in everything worked put the kdc back in verified that the radio is bad took back to best buy interchange for a pioneer for about 60 more
Jul 03, 2008 | Kenwood KDC-X590 CD Player
Turn on the car so the radio is flashing "Protect." Look on the front / removable face of the stereo. On it you will find a small round hole - that's a reset button. Find a small paper clip, unfold the clip and stick it gently into the hole. The "Protect" will stop flashing, and Kenwood will be displayed. Unfortunately all your settings/presets will be gone, but at least the stereo is working again!
Apr 30, 2008 | Kenwood KDC-W3534A CD Player
Car Audio & Video Logo
1,485 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
