Question about Acoustic Research S108PS Subwoofer
How do I connect my AR subwoofer to the tuner?
    Genius:
  • 1,199 Answers
If your tuner has a sub out you use that together with a single rca cable for the signel
Posted on Jan 02, 2009
Subwoofer not recognized and no sound from tuner
do a test tone which will test all speakers connected to the receiver.
Apr 19, 2014 | Yamaha Audio Players & Recorders
I have atomic A-8 subwoofer and philips FR740 receiver. when i turn the amplifier and the subwoofer "on", the subwoofer starts to hum loudly and it is wery annoying. i made all the connections...
The symptom sounds like an open signal shield somewhere and the cable is acting like an antenna for airborne electrical noise.
Disconnect the RCA cable at the sub. Is it still humming? NO? Problem is external to it. YES? Internal. Broken ground somewhere.
Recheck all connections making sure to twist the RCA head as you install it so oxides will be worn off.
Consider what may have changed in the environment regarding electrical devices, motors, magnetic sources. Ensure signal and speaker wires as ar not running are as non-parallel to any power cords as practicable.
Apr 23, 2011 | Eltax Atomic A-8.2 Subwoofer
AR SW-30 subwoofer doesn't switch to standby mode when off
Disconnect its input cable to see if a true lack of signal lets it go to sleep. If not, it has a bug. Otherwise, you probably have some sort of signal present on the sub cable.
Jan 17, 2010 | Audio Players & Recorders
Add su bwoofer to KLH 200
the subwoofer i have, a polk, connects directly to the right and left speaker lines of the klh2400.
i then connect my stereo left and stereo right speakers to the subwoofer.
essentially, the subwoofer becomes a middle station between my speakers.
make sense?
Jun 06, 2009 | KLH KL2400 Tuner
S112ps ar speaker need new one
I am selling one right now. 1.24.09 Call me 615.473.4676 Charlse
Jul 28, 2008 | Acoustic Research S112PS Subwoofer
Subwoofer
i have the same tuner.on the back you will see all connectors bottom row of rca jacks you will see subwoffer if your sub has to rca. red/white use a splitter monstor cable gold ..works best. i use Home Theater Reserch speakers... you can also plug your subs power plug into the tuner snd you never have to power it on seprate .........
Dec 08, 2007 | Yamaha HTR-5230 Receiver
Kenwood receiver/sub problem
The amp's remote turn-on wire is probably connected to the blue wire coming from the back of the stereo - this is intended for a power antenna, which is why it only works when listening to the radio. Disconnect it from the blue wire and connect it to the blue/white wire coming from the back of the receiver and you should be good to go.
Sep 21, 2007 | Kenwood KSC-WD250 Car Subwoofer
Orange light
I have the same speaker and it sounds like its behaving properly.
if you look on the back of the amp, you will find a switch that allows the speaker to automatically switch the speaker on or off based on the level of the audio coming from the tuner that it is attached to. If the switch is set to the auto mode, then it will listen for audio on the line and if the signal level coming into the subwoofer is high enough, the amplifier in the subwoofer will turn on and play. If the signal is not strong or loud enough, then the subwoofer will not turn on. There are two solutions to getting the speaker to work.
1. When you turn on the tuner or audio source that is feeding the Subwoofer speaker, you will need to turn it up loud enough to trigger the circuit in the subwoofer to switch on.
2. Alternatively, you can bypass the automatic circuit and set it to the "ON position all the time. In this position the subwoofer is always ready and waiting and should play any signal that is fed to it regardless of the loudness or volume of sound from the tuner. The switch is located on the back of the speaker cabinet just to the right of the red and black speaker wire connections. It is labeled "AUTO" and the switch positions are labeled ON and OFF.
Hope this helps!
Jul 09, 2007 | Acoustic Research S112PS Subwoofer
Acoustic Research S108PS Subwoofer Logo
192 people viewed this question
Top Acoustic Research Audio Players & Recorders Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you an Acoustic Research Audio Player and Recorder Expert? Answer questions, earn points and help others
