Question about Belkin N1 Vision Router
Xbox 360 router wont work with Belkin N1 Vision.
It just cant find the signal. my router is only 120 ft away form my xbox 360. The router says that the signal should go 1600 ft.
    Problem Solver:
  • 9 Answers
Make sure u are looking for the right connection when the box opens for the connections on the left hand side u will c a small box click it u will get wireless /dialup/vpn just make sure you look for the right one also go onto ur computer into windows media into library options into sharing and search have your xbox on it will appear click on it to allow it to share with your pc i would appreciate it if you could rate this solution
Posted on Jan 11, 2009
The router wont set up a wireless connection in the xbox so the internet does not work.
you need a wirless device to plug into the xbox 360 or u can use a long ethernet cable
Jun 27, 2010 | Belkin N1 Vision Router
I have a belkin -n1 wireless router.. it is a great router because it works all the way through the house. the only problem with it is that i cant update my xbox with it, neither by wire or wirless. if it...
first check whether the gaming ports for xbox have been forwarded in the belkin router or not....if not do it first....if you dont know the port numbers call xbox support and get the list of port numbers to be forwarded....
then enable DMZ for the ip address of XBOX in belkin router...
then enable UPNP in belkin router....
atlast Disable firewall in belkin router.... your XBOX will go online and GET UPDATE..... you can call belkin tech support of your country to assist you to forward ports for XBOX in belkin router... if you reside in USA/Newzealand/Australia/Canada you can call this toll free 1800 2 BELKIN(235546)...... or you can call my personal mobile... Im from India country code +91 Mobile number 9003593572
Apr 09, 2010 | Microsoft Wireless Network Adapter Xbox...
Issues with my Belkin F5D8635-4v1 connecting to xbox; it says the MTU settings are wrong on the router but i have checked and changed but still it will not work...any idea's? - I have checked all TCP / UDP...
MTU settings are set independantly of other network protocols.
Google MTU ~ xbox ~ and your specific use to find an ideal value to set your MTU to which may well differ from documentation you may have about your device/requirement.
Dec 30, 2009 | Belkin N1 Vision Router
For some reason the router says unknown_4 for my xbox 360 how do i fix that
Where did you see that message? Try to set static IP address on your XBOX. Go to Network Settings > IP Settings of your xbox and set it to Manual IP and type the numbers below
IP Address: 192.68.2.200
Subnet Mask: 255.255.255.0
Default Gateway: 192.168.2.1
DNS: Automatic
Reboot your router and xbox after that.
Jul 28, 2009 | Belkin N1 Vision Router
Belkin N1 router and xbox 360
You must configure NAT (Port forward) in the router.
Apr 14, 2009 | Computers & Internet
Belkin n1 F5D8631-4 NAT goes back to strict after been open
Step 1 : Check the IP Addressof the Xbox And take a note of it
Step 2 : Open RSP By typing 192.168.2.1 on the Address bar of the internet explorer
Step 3 : On the left side Click Firewall
Step 4 : Leave the Password blank and click Submit
Step 5 : Disable it And Apply Changes
Step 6 : On the left side Under Firewall Click DMZ
Step 7 : Add the IP Address of the XboX in DMZ
Step 8 : Click Apply Changes
Step 9 : Restart the Router
Step 10 : Test the Connection
Mar 15, 2009 | Belkin F5D8631-4 Router (F5D8631au4A)
My Belkin N1 and my xbox 360
I just got it and yes latest firmware as of end of mai has been downloaded
Jun 02, 2008 | Belkin (F5D8231-4) Wireless Router...
XBOX Live problems with Belkin N1 router
I suggest setting this up with a WPA encryption rather than WEP encryption. This should get ya setup without a problem. Also, I've noticed live to be a bit buggy since Christmas. If you continue to have troubles after trying this call 800-4my-xbox. The recording will tell you if they are having network issues.
I bet this helps!
Dec 31, 2007 | Computers & Internet
Belkin N1 Vision
DHCP Host name is what your looking for.
you need to name each item ie. psp as psp and ps3 as ps3 when you setup each item for connection. so when you setup or edit the settings for your ps3 on your ps3 you need to look for DHCP Host name and name it ps3. etc
do the same for all.
Nov 26, 2007 | Belkin N1 Vision Router
Belkin N1 Vision Router Logo
1,373 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
