Question about Casio PRG-40T-7 Pathfinder
6 year old Casio no. 2271 has ceased responding to buttons
Over the last few days correct responses became less and less. It is now 'seized up' on 'Set'    'AL - OFF'
Would removing and reinserting the batteries re-boot the system? If not. what?
Thankyou
Murray
  • diddydaveh
    diddydaveh May 11, 2010
    Hi, when was the last time the batteries replaced
  • 154 Answers
Hi, If you buy some new batteries - i.e. from ebay (very cheap) and replace the old ones - or take tyhe watch into a jewellers and get them replaced (appx. £15) this should do the trick. The batteries should be replaced every 2 years.
Posted on Feb 20, 2009
How can i change the time
Note how the buttons around the outside edge of the watch match up to the compass directions on the outer ring of the watch face. Use the butttons on the NW, NE, SE, and SW positions.
  1. To enter time setting mode, press and hold NW until the Seconds start to flash. (You can exit time setting mode at any point by pressing NW twice)
  2. Release NW and press SE to reset the Seconds to 00.
  3. Press SW and the Hours will start to flash.
  4. Set the hour by pressing NE (down) or SE (up) Press the lower button to move up and the upper button to move down.
  5. When the hour is correct, press SW and the Minutes will flash.
  6. Set the minutes by pressing NE (down) or SE (up)
  7. When the minurtes are correct, press SW and the 12/24hr setting will flash.
  8. Switch between 12hr mode and 24 hour mode by pressing SE.
  9. Press SW and the Year will flash.
  10. Set the year by pressing NE (down) or SE (up)
  11. When the year is correct, press SW and the Month will flash.
  12. Set the month by pressing NE (down) or SE (up)
  13. When the month is correct, press SW and the Day will flash.
  14. Set the day by pressing NE (down) or SE )
  15. When the day is correct, press SW and the seconds will flash again.
  16. Exit time setting mode by pressing NW twice.
This is a complex watch. You can download a manual here http://www.casio.com/products/archive/Watches/PRO_TREK/SPF40-1V/
Apr 02, 2014 | Casio Sea-Pathfinder SPF40-1V Wrist Watch
I am changing the batteries in a Casio model 2271 watch. A small silver spring fell out during disassembly. Can you tell me where it goes back?
just bring your casio watch to casio service center, i'm sure they have what you are lookin for.
Jul 14, 2011 | Watches
I can't set the day of week on my Casio, CA-53W. Thanks
If the day of the week is incorrect, make sure the date is set correctly. The format on the Casio CA-53W is year first, then month, then day last.
May 31, 2011 | Casio New CASIO CA-53W Water Resistant...
How to adjust the time on a CASIO W-59 watch
Hi Harry,
Your Module number is 2271.
1. To set the time, press and hold button A (left top) until Seconds digits start to flash.
2. Press button D (lower left) to move flashing in the following sequence to change other setting:
Seconds >> Hour >> Minutes >> 12/24 Hour Format >> Year >> Month >> Day >> (Then back to Seconds)
3. While a setting is flashing, use E (+) (bottom right) and B (-) (top right) to change it.
Note: When in the 12/24 Hour Mode, use E and B to toggle between 12-Hour and 24-Hour Mode.
4. Press buton A to exit setting screen.
Your time should now be set.
You may also download a manual for watch/Module number:
http://pathfinder.casio.com/resource/manuals/module_2271.pdf
This should give you all the info you need to operate all the functions of your watch. Thanks.
Regards, Bill
Sep 27, 2010 | Watches
I replaced all four batteries and i still have nothing .inside the watch it says to jumper the A C point with a twizers. what is the AC point and where.this s a casio 2271 2years old had factory batteries...
Casio battery changes are quite tricky.If you look closely at the watch module there is a place for the battery and a v-small depression usually circular on the silver module .There will be the letters AC in small writing.You need to touch the depression AC and the battery at the same time with a conductive tweezers.This shorts the module and re sets the watch.Make sure any seals go back in to protect from water/dust.
Regards
Aug 13, 2010 | Casio PRG-40T-7 Pathfinder
How to restart my casio module no 2271 watch
mcdevito75 here, I'm figureing you"ve changed the battery, Pressing the MODE button should re-start your watch. If you didn"t change the battery and your watch just stopped, try pressing the MODE or any button to re-start the watch. If nothing, change the battery and repeat the above instructions.
Jun 23, 2010 | Casio PRG-40T-7 Pathfinder
I BOUGHT A CASIO WATCH A178WA-1AV CASUAL CLASSIC .I CANT GET CORRECT DAY SAT BUT MONTH AND DATE ARE OK 2-13. NO INFO IN MANUAL HOW TO ADJUST.
Hey makfloyd2
Sounds like you have set the year incorrectly. Continue as if setting the time as you already have done by holding top left button, then when screen flashes scroll with bottom left button and the watch scrolls in the following order - seconds, hour, mins, YEAR, month, day. Check that year is correct and also check the format of the month and date. In England our format is 10/2/10 which is 10th Feb 2010 (dd/mm/yyy), however some casio watches are in US format mm/dd/yyyy. So check this out too.
Hope this solves your problems
Kind Regards
Jim
Feb 13, 2010 | Watches
The display of my casio GL150 is frozen
Try to hold down the light button for a few seconds.
Apr 06, 2009 | Casio G-Shock GL150-2V Wrist Watch
Repliciment wrist gand for Casio Pathfinder
you can go to this link and in the upper right corner type in the model number not the module number (there are instructions for finding the model number if you don't know it) I found a band for a watch that is over 8 years old on here.
http://www.fsiwebs.com/shopcart3/SC_ProdList.asp?
Jan 05, 2008 | Casio Casual Sports Watch HDC6007BVCF
Casio PRG-40T-7 Pathfinder Logo
510 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
