Question about Enlight Intel Xeon 470 WATT EN-470 MP (EN470MP) Power Supply
Cannot scan I am unable to get the printer to scan anything. The screens progress through the choices, and then it shows to insert the paper ... then nothing. I can't get any other buttons to work. Can anyone help me?
    President:
  • 8,637 Answers
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 28, 2009
Kodak ESP 3250 Printer shows message "Unable to detect edge of paper" and paper just goes straight through
I've had this problem with my esp 3250 that has become progressively worse over past year. I have tried every fix available online from driver, cleaning, power, etc. My printers default quality was set to 'draft' (just to save ink) which obviously speeds up the printing and I've found that if I use 'normal' or 'best' quality, it seems to help the printer detect paper edges, I think bc it slows down physical printing process? go figure but it's gotten me around a few times when I've needed hard copies immediately. Also, changing to heavier bond paper, 92 or better helped with edge detection. I'll finish current ink and not buy another one of these:(
Jan 16, 2011 | Office Equipment & Supplies
I am trying to scan a document and it is not working, I have a hp photosmart c4280 printer. How do I install a usb cord
hi
Place the document or image into the scanner for scanning. A scanner with a paper feeder will only receive flat papers and photographs, but a flatbed scanner opens to accommodate books, fabrics and leaves along with flat papers. There is even a attachment for feeding photo slides into flatbed scanners.
  • Step 2 Start the scanning softwaremag-glass_10x10.gif. If the scanner does not engage the software automatically, press the "start" or "scan" button, or click the scanner icon on the computer screen to initialize the software.
  • Step 3 Activate the scan. Click the "file" menu and select "acquire," "import," or another practical choice that applies.
  • Step 4 Preview the item to be scanned. Most scanners have a preview option. This will show the scan area inside dotted lines. The lines can be moved with the mouse to relocate, enlarge or crop the scanning area.
  • Step 5 Set the resolution for images by number of dots per inch (dpi). For computer screen viewing, 100 dpi should suffice. Use 200 to 300 dpi for items to be printed.
  • Step 6 Use the appropriate setting for scanning black and white text. If the scanner does not show a preset for text, use "line art" or "black and white" at 300 dpi. Then use the optical character recognition (OCR) program to convert the image of the text into a file for word processi
  • Jun 09, 2010 | HP Photosmart C4280 Aio Printer
    Unable to scan
    if already installed, put hard copy on scanner, then go to my computer and double click scanner icon. a window pops up showing progress of scan.
    Sep 25, 2009 | Brother DCP 115C All-In-One InkJet Printer
    My brand new X5340 printer shows there is a paper jam but there isn't one. The one and only sheet it has printed was the test page. Since then, I have been unable to get rid of the "clear paper jam"...
    hi
    follow these steps
    1.checked for and remove any obstructionsfrom paper feed tray.
    2.tilt and shake printer..checked for any rattling noise..checked for any foreign objects inside printer obstructing the paper flow.
    3.Take a sheet of paper ..fold it length wise 3-4 times to make it a thick.insert this into paper feed tray...move it left and right a couple of times..unplug power cable and replug it after 10 seconds...try printing ...if it does not work,,,,contact tech support 1-800-332-4120...ur printer is brand new and under warranty cover,,,they would replace it for u.
    goodluck:))))
    Jan 23, 2009 | Lexmark X5150 All-In-One InkJet Printer
    Stuck in Progressive Mode
    Had the same problem; here's what i did. Take DVD out of Receiver, close door to receiver and hold down stop button on receiver itself for five(5) seconds. changes should take effect and progressive scan screen should revert back to sanyo screen.
    May 06, 2008 | Dual DWM-3900 System
    Progressive scan mode
    tis could be a dirty optical reader or a dirty DVD disk
    need to be cleaned
    DVD disk could be scratched on the header of the disk and the optical reader is unable to read>>>>>
    hope this helps
    Apr 17, 2008 | Insignia IS-DVD1001 DVD Recorder/VCR
    Printer message: Unable to Print
    5A: encoder disc or encoder strip or main circuit board or printhead circuit board or power supply defective!
    Sorry, cant be fixed by yourself!
    Feb 20, 2008 | Brother MFC-440CN InkJet Printer
    DVD recorder: Changed the settings, now
    we could go through the setting like, you can see the monitor. using the remote do the following steps:
    Step 1. press set up button.
    Step 2. press down arrow once. ( playback)
    Step 3. press OK.
    Step 4. press down arrow once. (video (selection))
    Step 5. press OK. (progressive scan)
    Step 6. press OK, again.
    Step 7. press down arrow once. (progressive scan off)
    Step 8. press OK
    you have now turned progressive scan off.
    Dec 19, 2007 | Philips Magnavox MWR10D6 DVD Recorder
    Unable to print
    wireless print, scan and copy unable to print anything
    Nov 20, 2007 | HP Office Equipment & Supplies
    Computers & Internet Logo
    41 people viewed this question
    Top Enlight Computers & Internet Experts
    gaucherre
    Larry Maranto
    Jerry Umali
    Are you an Enlight Computer and Internet Expert? Answer questions, earn points and help others
