Question about HP LaserJet 4 plus Printer
Paper; gsm We have had many problems in the past with this printer, but I am currently only looking for some advise in regard to paper quality: Having used up to 160 gsm paper without a problem, I would like to know whether this printer will also be able to cope with 200 gsm. Thanks N.
  • 40 Answers
I'm not sure how this'll translate to your paper weight, but the printer is engineered to use 18-24 pound paper. You can safely run heavier paper through it using the MP tray and opening the rear face-up exit tray so the paper feeds straight through front-to-back with no U-turns. I personally don't recommend running anything heavier than a 65 pound paper, which is about as heavy as the cardboard they use when they package dress shirts. Let me know if that helps!
Posted on May 29, 2007
Kodak ESP 3250 Printer shows message "Unable to detect edge of paper" and paper just goes straight through
I've had this problem with my esp 3250 that has become progressively worse over past year. I have tried every fix available online from driver, cleaning, power, etc. My printers default quality was set to 'draft' (just to save ink) which obviously speeds up the printing and I've found that if I use 'normal' or 'best' quality, it seems to help the printer detect paper edges, I think bc it slows down physical printing process? go figure but it's gotten me around a few times when I've needed hard copies immediately. Also, changing to heavier bond paper, 92 or better helped with edge detection. I'll finish current ink and not buy another one of these:(
Jan 16, 2011 | Office Equipment & Supplies
I have a Brother MFC 8840D. The print quality is excellent and appears to be stable (it does not rub off), but once I fold a document and place it into an envelope, the recipient will receive a smeared...
It sounds likea problem with your paper stock. Check the following to make sure you are using a paper type that is compatible with your printer.
Recommended paper
Plain Paper: Xerox Premier 80 gsm
Xerox Business 80 gsm
Mode DATACOPY 80 gsm
IGEPA X-Press 80 gsm
Recycled paper: Xerox Recycled Supreme
Transparency: 3M CG 3300
Labels: Avery laser label L7163
??  Before you buy a large amount of paper, please test some to make sure that the paper is suitable.
??  Use paper that is made for plain-paper copying.
??  Use paper that is 75 to 90 gsm.
??  Use neutral paper. Do not use acidic or alkaline paper.
??  Use long-grain paper.
??  Use paper with a moisture content of approximately 5%.
Caution
Do not use ink jet paper. It may cause a paper jam and damage your MFC.
Choosing acceptable paper
It is recommended that you test paper (especially special sizes and types of paper) on the MFC before purchasing large quantities.
??  Avoid feeding label sheets that are partly used or your MFC will be damaged.
??  Avoid using coated paper, such as vinyl coated paper.
??  Avoid using preprinted or highly textured paper, or paper with an embossed letterhead. For optimum printing, use a recommended type of paper, especially for plain paper and transparencies. For more information on paper specifications, call your nearest authorized sales representative or the place where you purchased your MFC.
??  Use labels or transparencies that are designed for use in laser printers.
??  For the best print quality, we recommend using long-grained paper.
??  If you are using special paper and the paper has problems feeding from the paper tray, try again using the manual feed tray or Multi-purpose tray.
??  You can use recycled paper in this MFC.
The output quality depends on the paper type and paper brand. Visit http://solutions.brother.com and check the latest recommendations for paper that can be used with the MFC-8840D.
Dec 23, 2010 | Brother MFC 8840D All-In-One Laser Printer
When printing photos on glossy Kodak paper the error message " paper jam reload" appears.
Some printers are not able to or having difficulty feeding glossy photo papers at 230 gsm and above, try using photo papers below 230 gsm.
Jan 13, 2010 | Epson Stylus Multifunction Printer/...
My printer not printing at all- paper just rolling out with scant
if you haven't used the printer for a while before you discovered the bad print quality, the print head has most probably completely dried out. i don't think there is anything you can do about that, except for replacing it better having it replaced by an authorised technician.
Jun 08, 2009 | Epson Stylus CX3200 All-In-One InkJet...
Paper jam in tray 1
Hi glenpcr,
I had the same problem and solved it.
At my printer it was a problem of the MP-tray (multi purpose tray).
There are two hinges which keep the open MP-tray in a horizontal position. One of this hinges was broken and I just received it.
Just try it.
regards,
Stephan
Feb 10, 2009 | Samsung CLP-510 Laser Printer
Black paper
Switch to a higher print mode. Follow the steps below to switch to a higher print mode.
  1. In the program you are printing from, click File and then click Print .
  2. Make sure the printer is selected, and then click Properties .
  3. Select the Paper/Quality tab.
  4. In the Print Quality area, click the next high-quality setting. If the current setting is Draft, click Normal. If the current setting is Normal, click Best.
Jan 14, 2009 | HP OfficeJet V40 All-In-One InkJet Printer
My hp 915 having trouble printing photos with glosy papers
don't try to put heavy weight paper like 230 gsm in hp 915, it's not a photo printer (MFP), use upto 170-180 gsm only for gears safety, for heavy weight media try another photosmart series printer.
Jan 09, 2009 | HP Compaq Presario 915 (470045-499) PC...
Hp deskjet d2360
Hi
Yes the HP Deskjet D2360 will print pics. If you want to print photo quality, make sure your ink cartridges are in good shape and obtain photo quality paper.
You can actually print pictures on almost all printer paper but if you want a good result, I would suggest you look online for inkjet photo A4 photo paper.
Paper can be obtained in a number of finishes. For example Glossy, Silk, Matt and so on. If you just want reasonable quality for a school project or something, then a good quality non photo paper may be good enough for you.
Paper also comes in different thickness or weights. This is determined by the paper's GSM. For example: 80gsm is normal photocopier paper. A good quality photo paper would be 140gsm or 160gsm. When looking for paper online you'll see the GSM shown. It really is your personal choice. There are heaps of suppliers on the internet. Amazon do a good range.
You can also set your printer for various levels of quality. A rule of thumb is, the bettter the quality, the more ink you will use.
If you want to find out more about your printer, visit http.www.hp.com then look for your particular model.
Hope this helps.
Jan 29, 2008 | HP Deskjet D2360 InkJet Printer
HP PSC 1350 Photo Printing (Glossy Paper) Pront Quality issue
keep checking the HP site for an updated Driver for your printer, but why not use an online photo printing service like Walgreens or Walmart, You can't possibly print photos at home cheaper than they can, and this way you get actual photographs back.
Dec 09, 2007 | HP PSC 1315 All-In-One InkJet Printer
HP LaserJet 4 plus Printer Logo
79 people viewed this question
Clive
Clive
