Question about Denon DVM-715 Multi-disc DVD Player
My denon dvm 715 will not turn on...it says "init" on the display but even when I unplug it and plug back in it still just says 'init" and wont turn on.
  • 4 more comments
  • eric922 Jan 02, 2009
    It is not a new machine...
    It had been working for 3 years.
    That solution is for the Denon AVR-2807 7.1 Channels Receiver ....my uniit is a dvd player and i do not have any of those buttons on it:(
    Cant make sure there is no dvd in the tray because it wont open because it wont turn on....
    unplugged for 5 minutes, plugged back in, held down standby button (there is no "power" button, and it just kept saying init.
    the user manual does not say how to initialize.
    I cannot take whatever disk there is in the tray out of the tray because it wont turn on.
    There is no "parameters" knob, and it is plugged in fine.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, the display message "init" of course would refer to initializing and therefore is a firmware issue. Offhand, I doubt if this is user fixable not unless you can "jar" the system into booting completely.
You may want to try and see it the Denon DVM-715 if at all would accept init commands. The following may or may not "jar" the unit as it was intended for a region free hack of another model, but you could give it a try if only to determine if the firmware is still running:
  • Ensure there is no disc in the player, if there are and could not be removed, still follow below steps.
  • Power off using the front panel On/Off button (not standby) or merely unplug, wait 5 minutes, then plug back in
  • Press and hold Open/Close, Play and Skip Reverse (I<<).
  • Keep the above buttons held and Power-up the player using the On/Off button or plugging back in, holding the above buttons until the player's name disappears from the front panel.
  • Wait until the player finishes LOADING and the front panel of the player shows 0:00:00.
  • On the remote handset, press in sequence; 7 3 1 9 4 6 2 8
  • The unit should enter standby mode. On the front panel of the player, press the Standby button to turn the player back on.
  • To confirm the update, press on the front panel Stop and Skip Forward (>>I). The front panel should briefly display “Region_Ax” where x is the original region number. If not, then repeat the process 1-7 above.
Good luck and Thank you for using FixYa. Happy New Year.
Posted on Jan 02, 2009
    President:
  • 2,110 Answers
It seems to me this a kind of circuit problem...SO it is better to contact a technician...
    Genius:
  • 1,011 Answers
Sir,
Connection of the power cord is faulty. Check the insertion of the power supply cord plug.
Preset Init : Set all the preset data back to the factory defaults.
To clear the PRESET data, push the PARAMETERS knob.
“Preset Int?” flashes on the character display.
Push the PARAMETERS knob again.
“Preset Initial!” is displayed on the character display while data clearing.
Once clearing is completed, “Complete!” is displayed.
thanks
g.luck
    Genius:
  • 2,035 Answers
You’ll rarely need to "initialize the microprocessor" under normal operating conditions. In a few cases, the microprocessor will temporarily freeze or "lock up" just as your home computer does. When this happens, just follow the guidelines in the back of your owner’s manual to "unlock" the microprocessor and restore normal operation. (This is directly comparable to rebooting your computer. It’s an electronic wake up call to your unit’s temporarily paralyzed microprocessor "brain.") If you experience some unusual behavior -- a channel that’s suddenly silent, "forgotten" level adjustments, some eccentricities in your unit etc. -- you may need to reset the microprocessor. Of course, you should check all connections carefully first. But if you’ve eliminated these items as a source of potential problems, you may need to go through the initialization process.)
Initialization is easy. Please refer to your owners manual for instruction on reseting the microprocessor as each unit may have its own individual protocal for reset.
What causes these problems? Several things can -- a jolt of static electricity, a current surge through an antenna input, etc. But don’t worry, the microprocessor is well shielded from any permanent effects.
When you do initialize the microprocessor, remember that this erases any setup instructions you may have previously programmed into the unit. However, the on-screen menu will quickly get you through a new setup. And, if you write down your preferred settings BEFORE you reset your unit’s microprocessor, you’ll have an even easier job!
If in the event you do intialize microprocessor reset please refer to your owners manual for instructions on setup..
Here is is the user manual link:
http://www.usa.denon.com/DVM-715_1815-OM.pdf
If your not able to get information then you can get from the denon tech support
Voice:
(800) 497-8921 Customer Service & Technical Support
Good luck...
    Genius:
  • 1,269 Answers
Init mean initializing. Make sure there's no CD or DVD inside the tray. Unplug the power to the unit for 3-5 minutes. When you plug it back in, hold the power button for 5 seconds then release.
  • 827 Answers
Just to clarify, is this a new player? Just wondering if it has a transit switch on the bottom? The transit switch would just keep everything locked while the machine is being transported..
Chris (ziraffa)
  • 2 more comments
  • chris grams
    chris grams Jan 02, 2009
    Okay, in the user manual, it says to Initialize the Microprocessor:
    1. Switch off the power unit using
    2. Hold the following and , and press .
    3. Check that the entire display is blinking at an interval of about 1 second, and release your fingers from the 2 buttons.
    The microprocessor will be initialized.
    This will reset all the default settings.
    Hope this helps
    Chris (ziraffa)
  • chris grams
    Oh sorry, mate, my mistake..
    I have just found a user manual on www.retrevo.com, but you'll have to sign up for the site to download it. It only says turn off for 15 seconds and plug back in to reset.. not much help. It also mentioned checking the cables, and changing the batteries in the remote..
    Maybe you should have a look at the manual, you might get some ideas..
    Apologies for my initial mistake.. Hope you get sorted out..
    Chris (ziraffa)
  • chris grams
    Make sure there's no disk in the tray, I think that is what is trying to initialize..
  • chris grams
    I would change the fuse on the plug..
Protection
I just had this same problem and called Denon. I was told to unplug the unit and unplug all attached to it. Then, push both the tuning buttons at the same time (both the up and the down) hold them in while plugging the Denon back to the electrical. Watch the front of the Denon and see 5 cycles flash on the tuner display and then let go of the tuner buttons. Then plug things back in.
That helped the protect thing for minutes. I redid it several times.
No good. One of the channels blew out. I would now get rid of it for parts. I have not had luck with Denon.
May 11, 2013 | Denon DRA-775RD 2 Channels Receiver
Denon avr-1508 turns on but no sound
Try plugging is a set of headphones and then unplugging them. These models have a problem with the headphone jack thinking that there is headphones plugged in even when there isn't. This will mute all audio to the speakers.
Mar 28, 2013 | Denon AVR-1508 Receiver
Denon AVR-1908 won't power on
Are you getting a standby light at all? Is it flashing? Do you here a click when you plug the unit in? If the answer is no to all of these then you blew a fuse. If you do have soome sort of standby light, then your set is in protect mode. More than likely for a blown channel. If no lights, but you ar egetting a click, you could have a bad transformer. Use a DVM and see if it is open or not. Good luck
Aug 23, 2012 | Denon AVR-1908
1270 e MAKING a shrill sound and screen says parameter init. Had to unplug to make sound stop. Still says parameter init when plugged back in
It may need to be reset.
Please try to unplug it. press & hold the menu/function key while plugging it back in. When lights are blinking release it then press 91. and then display will show parameter init then change to maintenance. Press 99. The display should show date & time.
Hope this helps.
Mar 28, 2011 | Brother IntelliFAX 1270E Plain Paper Fax
Denon dvm 715 says load
probaly laser pickup assembly i am troubleshooting a DVM 715 now and i see no output from laser when it is loading be careful not to look directly into laser use a white sheet of paper to reflect beam on
Jun 01, 2010 | Denon DVM-715 Multi-disc DVD Player
Belt wont start on a brand new Sole F80. Motor
It sound like the motor control board is the culprit. Unplug unit then remove shroud then find the 2 leads that connects the motor to the motor control board disconnect them then plug in unit and see if the display blackout after programing the display then hitting start.
Mar 12, 2010 | RTO Sole F80 Treadmill
PocketStudio 5 Error - encDSP Init Err
I turned off the unit, then while holding down rew and record buttons at same time, turned on unit. I don't know why, but it worked.
Feb 07, 2009 | Tascam Pocketstudio 5 MP3 Player
Denon AVR 4802 Receiver w/ Denon DVM 4800 DVD player - video fail
no the problem is at the plasma you will have to change the setting back to the scale range that will accept the signals from the Denon, see Plasma's manual for instructions
Jan 27, 2009 | Denon AVR-4802 Receiver
Replacement pickup lens assembly
try to replace the data bus(ribbon) running from the pickup lens to the motherboard, that may the problem before replacing the lens ,NOTE that lens faulty is not easy.
name ;emanuel mollel
mobile;255757566502
TANZANIA, IT student
May 07, 2008 | Denon DVM-2815 Multi-disc DVD Player
Need help! DVD tray won't open
soundsa as though there is a draw drive problem and that could be a motor or as simple as a belt?? are you sure tjhat the eject button works properly as I found out on these denons that the eject switch or push button wont make contact with the switch behind it because the Printed cuircut board shifted??
Apr 02, 2006 | Denon DVM-1800 DVD Player
Denon DVM-715 Multi-disc DVD Player Logo
89 people viewed this question
Top Denon Televison & Video Experts
Jonathon summesfield
Are you a Denon Televison and Video Expert? Answer questions, earn points and help others
