I can hear the audio but the picture is lines going across the swing
I had this problem when I used my 360 on a new projector, its because the video setting on your 360 is set to 60Hz, and your display can only support 50Hz, you should still be able to see the picture enough to change the setting, but most games will now not work, so yu will really need to buy either;
- The VGA (like what PC'a use + audio) HD Cable
- The Component (a yellow, blue, green and red plug + audio) HD Cable
- The Advanced SCART Cable
or you can connect the standart composite cable (one yellow plug) to an RF modulator and use a coax (arial) connection, but this will give pretty dire quality.
same problem as above!!!
same. ive connected my xbox to standard tv with the component cable, hadtv with the component cable, tried both again with a different component cable, and then also with an hdmi cable. none of them gave me a picture more than just lines across the screen
