Right side speaker barely works
Got an old philips 7831 receiver that has a problem with the balance on the right side speaker - the left is fine, but when you turn the bal. knob to the right side, it's barely working. any ideas?
    Problem Solver:
  • 5 Answers
Likely the control is old and dirty.  It is known as a rheostat on older units and often a little contact cleaner on it will work.  A simple thing to try that might work is to rotate the knob back and forth, left to right, each time going to full stop.  do this several, several times.  See if this makes things better.  Of course, the assumption I am making is that the right speaker is operating normally.  If you switch out the left speaker for the right, and the problem persists, on the same side, it is the receiver.  If the problem now appears on the left side, it is a speaker issue and not the receiver.  Good luck and let us know how it goes.
Posted on Jan 02, 2009
No left a or b speakers
have you checked the speaker balance position as what you describe indicates you have the setting all the way to the right
Oct 03, 2016 | Audio Players & Recorders
Why is my right channel not working on my Technics reciever?
The right channel output section or speaker might have damaged. Seek tech support.
Jun 03, 2012 | Audio Players & Recorders
I have a Pioneer VSX 452 receiver. I am trying to run a second set of speakers off the b channel and use the a and b switches on the front of the receiver. If only the a channel is depressed the two...
Thanks for the detailed explanation...
It seems to be there is a short or misplaced (+) (-) leads on the speaker connection you made..sometimes a tiny cable piece can make a short in between the leads and cause such problem..My recommendation is:
** take all the wires off..
** install only B speaker leads and test it..( make sure LEFT and RIGHT (+) and (-) leads properly
and individually connected to the right places on the back......it is important...This causes balancing problem..
** if it works fine...
** than go ahead and install the A speaker leads..and test it..
if you do everything properly both A and B speakers should work fine as independently ...
Take care and if it succeeds please Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
Jun 22, 2011 | Pioneer VSX-454 Receiver
I have a Kenwood stereo receiver model k2 3600 , the left speaker keeps going out , the right speaker works fine. I've tried adjusting the speaker wire for the left speaker, and I always end up having...
HI,
BASED ON THE INFO YOU GAVE I HAVE SOME SUGGESTIONS BELOW..
1, switch the working right speakers cable to left output and problem left to right (from the back of receiver -not from the speakers it self..) to see if problem continues..
2.After switching them ,if it (old left new right one ) still stops left speaker cable may have short ( a tiny cable inner pieces may touching to other side ) at either at the back of receiver output or at the end ,at speaker input .
make sure you control it carefully...if the problem persist please contact to me..
Take care and please Remember to rate/vote and give me 4 Thumbs Up
Hope this helps!
Thanks
Jun 17, 2011 | Kenwood Audio Players & Recorders
Str-gx800es sony receiver problem- right channel speaker sound is 'static', low and distorted. I have checked checked all speaker and output/input source cable connections with no luck. All left channel...
If you have checked the speakers and wiring, the right channel has a audio driver or output problem, which explains the low volume, static, and distortion. A service technician will be required to fix the receiver so it will balance the left side.
Jan 10, 2011 | Sony STR-GX800ES Receiver
Only get sound out of right side both a and b
Good day sir, Hi, your Philips receiver trouble can be any of the ff:
  1. your receiver left fuse is blown, check if it has a user fuse at the back. or
  2. your main IC amplifier for the left channel is bad. you need to replace that IC, but check first the wiring of the speakers.
  3. Check your receiver left speakers if it is producing a soft hum, to do this turn down the right channel, or adjusting the balance knob to the left, or simply remove the speaker connection of the right channel. place your ears on the left speaker as you adjust the volume up and down, do you hear a soft hum that goes up and down also? If yes the problem is on the source section before main amplification, usually the pre-amplifier stage, If you hear no hum at all. problem with the main left amplifier. The main amplifier is usually a single IC for both left and right channel, OR one IC amplifier for the left and one for the right, in both cases, replace the bad IC.
Jan 21, 2010 | Philips Audio Players & Recorders
I have an old onkyo a-8067 reciever and only the left side speakers work. A while back the right side was fading and now it doesn't work at all. I also have a sony STR D1015 home theater receiver that has...
Fixed the Onkyo. Took apart the balance adjuster and rebent the feather-like things inside so they made contact. Clamped it back together and it works fine.
Nov 26, 2008 | Audio Players & Recorders
My l/r channel will not work
With the radio on u will need to push audio button it will change to something different on the face push until speaker balance comes up & then push butons below it left or right to balance each side of speakers. For me it was the left speakers that i needed to balance good luck John
Jun 06, 2008 | Pioneer DEH-1600 CD Player
Sony str-de875 amp. one speaker louder than the rest
hi. i have a sony amplifier. i plug the speakers in like normal. i turn it on and the right side speeker works fine. but you half to crank it up all the way just to barely hear the left speeker. we switched speakers and its still the same effect. we think its the amp itself. we tried our balance settings. it was fine. but right now its just playing one speaker louder then the left one. can anyone help me?
Apr 03, 2008 | Sony STR-DE875 Receiver
Sound not coming from left side surround sound speaker or my right side front speaker
it is highly likely that you're TV is outputting mono sound, hence the left channel only. check your physical connections to the TV and the balance / channel volume on the television as well.
May 01, 2007 | Onkyo HTR500 Receiver
94 people viewed this question
 Grubhead
Grubhead
