Even though I have been adding music for almost 2 years, one day after I synchronized music, my mp3 said that there were no songs, artists, albums or playlists. And when I connected it back on my computer, I deleted the songs (They only showed up on the computer) and was going to sync them back, but now it wont sync.
Try resetting the MP3 player: locate the little reset hole (it is quite small) and give it a poke with something blunt like a unraveled paper clip.
Testimonial: "The screen is frozen now and when I poked the reset hole, nothing happened. It might work later. I dont know. But thanks for the help!"
SOURCE: Philips GoGear 8GB wont show song titles or artists.
the phillips go gear mp3 player is a total pice of **** the best thing you could do is go out return it and buy a sandisk sansa other wise called a sansa fuse they are great and they have an expandable micro sd card port.
oh and to fix your phlips go gear mp3 player you need to take a pin and stick it in a small hole on the side i belive it is on the left side next to the mic.
SOURCE: Philips GoGear SA3245 - Playlists Not Showing Up on Player
Have solved this problem on GoGear syncing with WMP 11 by going to options on the device itself, then go to the "settings" option, scroll down to "PC Connection Preferences", from here you will select the check box saying "MTP" then back out of options and connect your device and go back to your WMP 11 and drag your playlists to the syncing area and resync your device. You should then be able to see your playlists under the playlist option in music along with the "playlist on the go" playlist.
Hope this will help!
- Jared
Determan Technology LLC
SOURCE: i added new songs to my phillips go gear...now
Is there only certain music or all of them? Maybe it can't read the format of the music.
SOURCE: how do you delete a album or song from the
The best way to do it is to connect it to a PC. Right click on the Device logo, select explore , identify the files or songs , right click the mouse on those files or songs and select delete and click on Yes.
Since you can see all the data on a bigger screen one makes lesser mistakes while deleting .
