Question about Patton U2-1487 Floor / Box Fan
I have a bad off,hi lo,med switch
Looking for a hi ,low ,med off switch
    Sergeant:
    Champion:
  • 239 Answers
Go to lowes and get a universal one
Posted on Jan 02, 2009
How does the lighting dimmer work on my remote
The low/med/hi buttons work the fan motor. Push and hold the light button to get the dimmer working. All the light bulbs come on at the same time.
May 25, 2015 | Hampton Bay Dryers
Furnace transformer/fan-relay wiring to fan-motor
All you need is 2 fan speeds, 1 for cool and 1 for heat. Leave the low speed disconnected. Normally we have high speed for cooling, and med. or low for heat. So either speed connected to the heating circuit is fine.
Apr 12, 2017 | Heating & Cooling
My GE JVM1850 microwave runs but does not heat. I've jumped all three safety interlock switches.
there should be a setting on it hi med lo if its on low it wont heat anything
Dec 23, 2010 | Microwave Ovens
I have a ge electric skillet but it doesnt say what the degrees are to cook can you help
If you're not looking specifically for temp to cook specific food items, rather what lo, med low, med etc mean . . . from the packing insert lo is 185 degrees, med low is 225 degrees, med is 300 degrees, med hi is 375 degrees and hi is 415 degrees. I just purchased this item yesterday.
May 10, 2010 | GE 169216
Rear AC fan will not run in lo med or hi, switch or is there resistors on the fan that need checked?
When a blower motor does not turn on in low or med. and only turns on high its usally a resistor block. If nothing works it is most likely the bolwer motor itself or a fuse.
Feb 28, 2010 | 2001 Chevrolet Suburban
Low does not work, medium and high do
You probably cant fix it, this sounds like a multispeed blower with hi/medium/lo settings. You
can either replace the motor or connect one of the
working speeds to low/med or low/hi. or bump med to low and high to medium.
Jan 12, 2010 | Desa International Blower Glow Warm Wall...
Heater blower works intermitantly
If you have access to a DC voltmeter; try this:
Check for voltage on each of the heater resistor terminals, when it is unplugged, key in the on position. With the heater switch on low, you should have 3 volts DC, on lo-med, 6 VDC, hi-med, 9 VDC and on hi, 12 vdc. It looks to me like you might have a bad heater switrch, if the voltages do not match exactly what is posted above, or vary when you slightly manipulate the switch, the switch contacts are bad. Hope this helps. If not, please repost for additinal info.
Oct 08, 2008 | 2000 Toyota Celica
HI speed on my Hampton Bay ceiling Fan.
If you are looking to lower your fan speed, I suggest getting an adjustable wall switch that will limit the current to the settings. I have the same situation, I myself didn't do it but I know it is possible. In my bedroom, I have my ceiling fan wired to a turn knob switch, a dimmer so to speak, that limits the elctrical current, thus slowing the rpm's of the fan blades.
Feb 25, 2008 | Dryers
Fahrenheat baseboard heater knobs
go to a radio shack to find replacement knobs. get something called a "bar knob." this has a set screw which holds the knob on the thermo shaft. use a marker and print lo med high and off on the unit or use a brother p touch label maker.
Jan 10, 2008 | Fahrenheat Electric Convector Baseboard...
Patton U2-1487 Floor / Box Fan Logo
494 people viewed this question
Top Patton Dryers Experts
Mohamed Ismail
Mohamed Ismail
Are you a Patton Dryer Expert? Answer questions, earn points and help others
