Question about Vizio L32 32 in. LCD HDTV
No signal I have hooked up my TV an how do i play DVD my movie's on page 19 connecting my DVD play but it say no signal i'm useing the red white yellow coax
Try this.
1. Take note of what input you are using to your television. AV1 or AV2 or Component 1 Component 2.
2. On the remote, toggle the input selection to corresponding input for your DVD.
Posted on Jan 02, 2009
Dvd playing hooked up to an old t.v. plays in color when i hook it up to my lg tv it plays in black and white?
My DVD player only plays in black and white - TOSHIBA FORUMS
39L1350U) and am trying to hook up the DVD player. ... My DVD player only plays in black and white ... My DVD player is an old Sony. .... Was using and S-Video connecting cable to the TV. ... suggested to use VIDEO instead of COLOR STREAM, I changed that in the TV menu, plug the red and while at the back of TV where ...
No Color When My DVD Player Is Hooked Up - Community ...
Jul 14, 2014 - I hooked up my DVD player and I have no color. ... you need to use the connections on the left side of the TV or on connections on the back. .... is turned on, which can cause this black and white image issue you're having. ... If the Player shows correctly on a different TV with the same hook up, and different ...
The picture from a disc player displays on the TV in black ...
Jan 17, 2016 | LG Televison & Video
Vizio tv - plays fine and in color. hooked up phillips dvd player - all connectors connected correctly. when i play the dvd, it is only in black and white . . . not color. how can i get my dvd to play...
Which input on the TV and which output on the DVD player are you using? HDMI is the best and easiest. Next is standard video plus audio (3 leads, yellow - video, red and white - audio). If you are using the component input, you can get B&W if you have the leads incorrectly connected. If you're going from component to video in, you might have the same result, I'm not certain. I hope this helps you resolve your problem. Let us know.
Mar 23, 2014 | Vizio E601I-A3 60-inch Class Razor LED...
My dvd player is hooked up to t.v. but only plays movies in black/white
How is the DVD player connected to the TV? If you are using component video, check that the cables are connected correctly.
If you switch the order on two of the cables, the black and white result is common. So double-check that the red, blue and green connections (RPbPy) have been connected to both devices in the same order. Next try a different set of component video cables, in case one of the wires is damaged.
If possible, try a different type of connection to rule out a damaged input/output. Connect the TV to a different DVD player or the DVD player to another TV, if possible, to rule out similar damage.
Please add a comment with the connection type for additional support. I hope this helps.
Oct 07, 2012 | Vizio L37 Television
No signal fromdvd player video 1 (av)
yellow is video and red and white are audio you a get by with one audio. i think you are missing your video cable you can get by with two cables just use the white cable as a yellow and plug it into the yellow dvd plug and tv yellow plug and the red will stay hooked up for sound ( you wont have stereo but it should work)
Aug 05, 2012 | Audio Players & Recorders
Dvd is playing movies in black and white
use red/white/Yellow cables to connect to a loose hard diskon which I keep films, TV-serials and talking books. The colour is fine.
But I connect the DVD to the TV with a scart cable.
Hope you get your colour
Feb 26, 2012 | Apex Digital ADV3800 DVD Player/VCR
Black and white only when playing a DVD or VHS hooked up to my Sony Bravia 32" LCD TV.
What type of connections are you using?
If you are using coax cable check to make sure that the TV is on the proper channel that the DVD/VCR is switched to i.e. 3 or 4.
If you are using Componant video (red, green, blue, and red, white) verify that the green is plugged in all the way on both the TV and DVD/VCR and try connecting it to a different Componant input on the TV.
Note: the TV may be YCbCr, and DVD/VCR YPbPr or vice versa these two types usually are not compatible with each other. YCbCr is a digital signal and YPbPr is an analog signal.
If you are using A/V video cables or (yellow, red, white) check the DVD/VCR video setting to see if it is in progressive scan mode, as this can cause a problem with some TV sets that are not compatible.
Feb 05, 2010 | Goldstar GVR-E435 VHS VCR
There is no colour on the movie
Make sure you have the cables hook up right. If you are running component mode it takes three for video blue red and white ends. If you are running composite it takes red, white, and yellow.
Nov 20, 2009 | Toshiba HD-A20
Problems hooking up dvd player to Dynex 22"
Mar 09, 2009 | Dynex 19 in. LCD Flat-Panel HDTV
Samsung HD Plasma - hooked up DVD to it but movies play in black & white??
anytime you connect componet signal (green red and blue)to regular video inputs (yellow) end will have same effect. make sure that if you are using component signal from DVD player you have to connected to component input in the set.
component signal will use green red and blue for video and red and white for sound.
Composite signal will be yellow (video)
red and white(audio)
Jul 10, 2008 | Televison & Video
Having problems connecting dvd player to my tv
Normally a DVD's output would be:
Yellow - video
White - audio left (in some models mono)
Red - audio right
Based on your post/description, your movies will play normally. You simply left out the red (right output) hence you will not get stereo effect (which is immaterial since your TV is mono).
The correct procedure calls that you connect the red & white to a stereo amplifier.
Alternately, you can use the adapter shown below to connect the white & red and make them a single RCA male out.
Hope this be of use/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Nov 17, 2007 | Televison & Video
Vizio L32 32 in. LCD HDTV Logo
152 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
