I bought a HP laserjetprinter P1505n and the orange seal with a strip inside the catridge was broken while removing it. the problem is the half of its part is inside the cartridge. just tell me how can i use it. whether i can repair it
  • 66 Answers
The cartridge should still be under warranty. Taking it apart could be very messy and voids warranty on the cartridge. Get a replacement from HP or supplier. Otherwise, shake it every time one side fades.
Posted on Jan 02, 2009
HP12A Toner sealing tape broken
If any scraps of the strip are left over then try pulling it out with pliers etc. If not the strip is likely to be stuck in there. In which case I would recommend contacting your retailer.
Nov 19, 2012 | HP 12A Toner (Q2612A) Printer
Memory error msg shows after taken print of HP 1505n printer
Just observed that while loading the catridge, memory reading mechanism has to engage with memory, if this mechanism broken, not moving or jammed result memory error msg.. most of the cases observed broken.
Sep 15, 2011 | HP LaserJet P1505n Printer
I am using Windows 7 but I cannot install my printer as I need to have drivers first
HP LaserJet P1505n is compatible with Windows 7and you can download the drivers from HP Official Support.
Visit the above link. Select the Operating System (Windows 7) (32-bit OR 64-bit) and download the drivers fro FREE
CreativeTECH
Jan 24, 2011 | HP LaserJet P1505n Printer
My Printer HP 1600 Laserjet error 10.1001
Did you fix your problem? I have the same one. With Hp 2600N
All cartridge are new, and i removed the orange tab from each one.
I even tryed a second new cyan.
Did you remove All the orange tab from cartridge?
Feb 03, 2010 | HP LaserJet 1600 Printer
My hp color laser jet2605dn has a brand new magenta ink cartridge yet does not print the red in pictures on my brochures
One solution is to make sure you have removed the orange plastic strip from the toner. The cartridges are sealed with a plastic strip when shipped and it needs to be removed from the toner side before installing.
Jul 13, 2009 | HP Color LaserJet 2600n Printer
HP 2320 problem
For Every New Catridge there is lock on catridge head u must remove to use the catridge...take out the catridge then remove the shipping seal or lock. refer instruction printed on catridge cover.
Jul 07, 2009 | Office Equipment & Supplies
My printer is epson fx 1170 it prints half word
this is due to catridge problem,
1.remove your catridge, use cleaner solvent to wet the head of catridge for 2mts and wipe it or clean it with tissue paper
2. check your catridge has ink or finish..
3. due to dry head and not enough of ink, this type of problem comes frequently
Jun 23, 2009 | HP Photosmart C6380 All-In-One InkJet...
Problem with printing page
In this case what i would request u to do is.......
Take out both the catridges from the Printer.........
Take 2 Paper Towels one should be wet with Luke warm water and the other one should be dry...........
Take the Colour catridge first turn it upside down and u will see a small copper plate on the catridge from where the ink comes out.......
Place the wet paper towel using ur thumb on the Copper plate and press it a lit bit for 10 Seconds......
Now remove it and see whether u see any ink on the paper towel..........
U should see some ink on it now place the dry paper towel on the ink catridge in the same way........
Now do the same procedure again..........
Do the same procedure twice on the Black Catridge.................
Now take the dry paper towel and turn the direction of the cartridge so that u can see a Copper plate on it with small boxes just clean that copper plate with the Dry Paper Towel..........
Know insert both the catridges inside the Printer the Colour Catridge should go in the right side and the black on the left........
Unplug the Power Supply from the printer.......
Replug in the Power Supply......
Try to Print it will work fine..........
Jan 05, 2009 | Lexmark X2500 All-In-One Printer
55 people viewed this question
jasbo
jasbo
