Question about Canon EOS 40D Digital Camera
I've locked it up somehow. Menu doesn't display, shutter won't de
I've locked it up somehow. menu no longer displays; shutter won't fully depress and when i tried to download pics that took earlier the computer no longer recognizes camera. I've downloaded fine in teh past and also menu came up with no problem.
  • Anonymous Mar 06, 2009
    None of my camera buttons work. Only the shutter button and both dials seem to work. It still takes pictures but won't even display the picture after it takes it like it usually does.
  • 423 Answers
Try taking the batteries out replace with fresh ones.
Posted on Feb 16, 2009
Why is image not displaying on LCD monitor?
Need more info. Does the menu display? Then LCD probably good. If the menu does not display, then LCD (or its driver circuitry) is probably bad. Not display after taking a photo? Or not display when you push the arrow button to turn on display. Check to make sure card is in camera. Set menu to factory default to make sure some setting in the custom functions isn't turning off the LCD. Also check the brightness level.
Jun 05, 2014 | Canon EOS 600D Rebel T3i Digital Camera
How to set self timer for D90
Instructions for this are on Page 179 of the D-90 users manual. First go to the menu and select the custom settings menu then scroll down to "timers/AF Lock."
Select this then select the number of shots you want the camera to take at one time on the self timer setting. Exit the menu.
Then go to the top of the camera and find the little button to the right of the control panel which contains a series of stacked rectangles.
Depress this button (camera must be on) and the control panel will clear. Rotate the wheel on the back of the camera while holding the button down until you see a little clock symbol.
If you have set it in the menu to take only one shot, you will see only the little clock. If you have set it to take multiple shots you will see the series of stacked rectangles next to the little clock.
Depress the shutter fully then walk or run to get in the picture. Just before the picture shoots, the autofocus light will flash warning you that the picture is about to be taken. The camera will shoot in the amount of time you have selected in the menu.
If you want to shoot another delayed shutter picture, repeat the procedure using the button and wheel.
May 10, 2013 | Nikon D90 Digital Camera with 18-105mm...
I have a Konica Minolta Magicolor 1650en. When replacing color toner, I managed to install magenta and yellow, following menu prompts, but when I try to install Cyan, the cartridge doesn't...
I had a similar problem in that after changing one of the cartridges (I bought a whole set), the message "cannot rotate cartridge" appeared. I tried pressing the cartridge in more firmly and may have caused the carousel to rotate a little in the process. I cycled the power which seemed to clear the error message and allowed me to select the next cartridge to change, but upon opening the door to change it, was unable to remove the old one as it was positioned a little too high. I eventually cleared the problem by manually rotating the carousel by pressing in and holding the carousel release (see arrow) mmgazette.jpgwhile rotating the carousel downward slightly, to line the cartridge up as it appears in this picture. Then powered it back up and was able to do the normal cartridge replacement procedure for the remaining cartridges without further error messages.
Jun 11, 2011 | Computers & Internet
SCX4521 Printer is displaying error message Scanner Is locked how to solve this problem
Solution from samsung site i hope it will work for you
1. Press MENU # 1 9 3 4 in sequence rapidly. The LCD panel should now display TECH.
2. Press MENU, and then press ENTER. The LCD panel will display Tech Mode.
3. Press the left arrow (4. Press ENTER. The operator panel will display [YES].
5. Press ENTER. The toner warning message should be gone.
6. To exit TECH MODE, press MENU # 1 9 3 4 in rapid succession, as if you were dialing a phone number. The operator panel should no longer display TECH.
Oct 18, 2010 | Samsung SCX-5530FN All-In-One Laser...
My Nikon D200 just started locking when I depressed the shutter. It gave me the R25 reading in the view finder. If I depress the ae focus lock it fires. What is going on? Cmaclennan@verizon.net
Check your Custom Setting Menu, a1-a10:AUTOFOCUS.
Press Menu, select the Custom Menu Setting (looks like a pencil).
Select "AUTOFOCUS" and move to right.
a1 AF-C Mode Priority. Set to "Focus"
a2 AF-S Mode Priority. Default is "Focus", change this to "Release". This will enable the camera to fire anytime you press the shutter, regardless of if it's in focus or not. Use this setting if your having problems locking up, especially using some different lenses.
Try these settings. They may work for you.
Oct 08, 2009 | Nikon D200 Digital Camera with 18-200mm...
Sony DAV DZ230 Child Lock
hello You can deactivate the buttons on the unit
(except for "/1) for preventing misoperation,
such as child mischief (child lock function).
When the child lock function is activated, the
buttons on the unit are locked and “ ” lights
up in the front panel display. (You can operate
the system by using the remote.)
Note
•When you operate the buttons on the unit while the
child lock function is on, “CHILD LOCK” appears in
1 Press SYSTEM MENU.
2 Press
X/x repeatedly until “CHILD
LOCK” appears in the front panel
display, then press or
c.
3 Press
X/x to select a setting.
The default setting is underlined.
• “OFF”: Child lock function off.
• “ON”: Child lock function on.
4 Press .
The setting is made.
5 Press SYSTEM MENU.
The system menu turns off.
Tip
• You can activate the child lock function by pressing
x for more than 5 seconds (“ ” lights up in the
front panel display).
To cancel, press x for more than 5 seconds so that
“ ” disappears from the front panel display.
Deactivating the Buttons
on the Unit good luck
shaun
Sep 12, 2009 | Audio Players & Recorders
My nikon d70 wont focus at all
  • Make sure both lens and body are set for autofocus. There are two switches near each other with "AF" and "M" settings.
  • Check the camera's focusing settings, or do a factory reset (from menu) to 'start over'. Usually helps to have AF-Assist on.
  • Try setting the AE/AF-lock button (upper rear, near right thumb when holding camera) to turn on AF. The camera may respond better to this than half-pressing the shutter release.
  • Make sure the lens is fully attached to the camera. You shouldn't be able to rotate the lens without depressing the lens release button, and you should be able see a tight seal between the two.
Jun 23, 2009 | Nikon D70s Digital Camera
My Nikon D80's viewfinder stays black when camera is on. Playback
dj & izik13,
If you can both acces the settings menu let me know if you can change any of the settings. Have you tried to reset? To do it you have to turn on the camera and hold down the two buttons that have a green dot by them on the top by the shutter release (the +/- ) and the AF button by the top menu display for longer than 2 seconds, just remember you'll have to reset some of your favorite setting all over again, but it will get things back to the original factory settings. Let me know if that worked
randy320sgi
Jan 10, 2009 | Nikon D80 Digital Camera with 18-135mm...
Shutter locked up while reviewing stored pics
Problem not solved at this time. However the Optio web site offers live chat. M-F 9:30 am to 6:30 pm. I will contact them to discuss later today. I will post their recommendations. Thanks Txlingo
Sep 28, 2008 | Pentax Optio S4i Digital Camera
Monitor problem
o monitor esta com um probleminha simples ele esta aparesendo a mensagen de osd. os botoes estao todos bloqueado..cmo fasso para ageitar.
Sep 11, 2007 | ViewSonic 17" CRT Monitor
Canon EOS 40D Digital Camera Logo
111 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
