Question about Frigidaire GLRT188WD Top Freezer Refrigerator
Leaking water the drip pan in the back of the frig is overflowing. Also lots of condensation inside frig on roof.
  • Frigidaire Master
  • 8,220 Answers
Look at your door gaskets. If they ain't kosher then excessive humidity will build into the frig.
Posted on Jan 02, 2009
My drip pan under the frig over flows with water then on to my floor. both fans work. Air flow from freezer to frig and back seams good. Tube going to drip pan is clean. Seals looks good and clean. MOD...
I had a similar problem with my Whirlpool model 6ED25DQFW side by side refrigerator/freezer with ice maker/water dispenser. Water was slowly pooling under the refrigerator under the freezer section. The defrost drain pipe was not blocked, the condenser fan was running, the drip pan was not leaking.
The source of the leak was found to be the icemaker solenoid block plastic body which had a pinhole leak.
To fix requires either plastic welding, or replacement of the solenoid block plastic body.
To access the solenoid block firstly requires removal of the cardboard cover, located at the lower rear of the refrigerator.
Aug 16, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Have 2 evaps on roof shut main water feed valve off. There is some water in pan of one and dripping on my new roof. Wondering why there is water in pan? can you help
Yes, there should be a water/condensation pan under it with an overflow drain that takes the water down off the roof. Perhaps, whomever installed your new roof, removed the drain tubing and forgot to put it back.
Apr 13, 2011 | Mastercool 67680 Evaporative Cooler Air...
On humid days water puddles in the bottom of the frig.
Sounds like the door is not closing properly so humid air is coming into the fridge OR door not closing properly and the humid air is condensing around the door so it is leaking the condensation OR
The water from the defrost cycle is not evaporating so it overflows from the evaporator pan above the compressor. You better call a service technician before getting some floor damage (Do not call A&E)
May 02, 2010 | Refrigerators
My older KA Ref Model KTRP20K & M is giving off a strong odor similar to iodine. Very strong in AM but can still smell it in PM. I've checked for spoilage and nothing there. Any thoughts? Is it time...
since it is working ok . i am wondering if you dont have mold growing in the drip pan ... condensation from inside the refrigerator goes down a small tube in the back bottom of the frig ... that tube goes to a pan under the refrigerator and normally the water just evaporates .. if there is a lot of condensate from the frig then the pan may stay wet long enough for mold to get established ... a large amount of condensate from the frig usually indicates a leaky seal around the door .. or a door that doesnt close completely .. you might want to clean everything under the frig including any fans, coils and that pan (unplug first) ... now this all assumes that the smell is coming from the outside not inside the refrigerator .. if the smell is inside then you may have to defrost and clean the evaporator (the coils inside the freezer (somtimes also in the refrigerator) ... there are some kinds of mold that actually grow in that cold environment .. some hot soapy water with a little bleach usually does the job .. or if you have one, a steam cleaner, those do great .. it allows you to get down in the little places and clean everything ... make sure the frig is at room temp first so plastic doesnt crack ..
the refrigerant r22 or r134a have very little smell so even if you had a leak it wouldnt smell strong .. a few refrigerators use ammonia and that would have a distinctive smell easily recognized if there was a leak .
Nov 22, 2009 | Cell Phones
Water leaks from under the middle but not all the time maybe once or twice per month
condensation normally drains thru a tube at the bottom of the frig to a drip pan under the condenser coil (under the frig) .. the water normally just evaporates from the pan .. if there is too much moisture in the frig, that usually means a door is ajar (not closing completely) or the seal on the door is not sealing properly .. warm moist air from the room getting in will cause too much condensation .. the drip pan may overflow ... you should check the drip pan for damage (clean the condenser while you are down there) .. also check the tube that carries the condensation (back bottom of the frig) .. it has a one way valve (lets water out only) that becomes stuck sometimes and needs cleaning.. if there is a large amount of moist things in the frig then that an cause the problem as well .. just put those things in plastic bags or containers to eliminate that problem ..
Nov 21, 2009 | Amana AFD2535DES French Door Refrigerator
Refrigerator is leaking on the ground
Assuming you are talking about water leaking, if it has a drip pan to catch condensation, it may be full and overflowing or missing a drip pan allowing water to fall to floor. If it has an icemaker and/or cold water dispensor, it could be a connection leak.
Oct 08, 2009 | Kenmore Refrigerators
Both units are liaking water inside coach. Have claned out overflo
Did you check & make sure drain holes were cleaned out in base of unit on roof? When you say overflow, do you mean drip pans under cover on roof unit, and if so, did you inspect them for cracks ? There were some years that experience cracks in drip pans.
Jul 11, 2009 | Dometic Rooftop RV Air Conditioner
Drip pan needs emptying; had repairman out for other issues, now fridge keeps overflowing
The accumulated ice you saw is of course the source of the water. The refrigerator will eventually rid itself of the excess ice and the problem will therefore disappear on it's own after a while. The drip pan is normally filled with only a small amount of water, and that is dried up by the condenser cooling fan under the fridge. The pan is removable from most units, but not without making a mess. I suppose you can make and clean up the mess one time and be done with it.
May 20, 2009 | Jenn-Air JCD2389G Side by Side...
Water is steadily running/drippin into the drip pan...overflowing
The frirgerator has a defrost when it defrost it has to go somewhere check the drip pan and make sure it is not full.
If this continues then try checking the water line coming into the back and up the back of frig. try that first
Feb 26, 2009 | Whirlpool ED0GTQXMQ Side by Side...
Water puddling under the frigerator
I had the same problem. The problem was the drain tube from inside the freezer to the drain pan was partially plugged so ice was building up inside, then when the freezer went thru its defrost cycle large amounts of ice were melting. I fixed it by removing valve in the end of the drain hose, all ice inside freezer and ice in drain hose (pour hot tap water thru it).
Hopefully this helps.
Jan 22, 2009 | Refrigerators
Frigidaire GLRT188WD Top Freezer Refrigerator Logo
125 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
