Question about Peg Perego Venezia Single MT - Safari Stroller
5point harness how do you attach the harness at the back
0 characters
1 Points
How do i move the straps to a higher/ lower **** ??
Undo the popper on the shoulder harness pads and slide pad down length of harness. You will reveal a metal D ring which is where the harness is attached to the anchor point. Unhook this ring. Remove the top of the seat fabric from the sub seat (seat frame) and you will find further sets of anchor points behind the fabric. Post required anchor point through the hole it lines up with and re-attach harness, then put harness pad back into position and do up popper.
Mar 24, 2012 | Quinny Buzz 3 - Rocking Black Stroller
How do you move the straps for a bigger child
Undo the popper on the shoulder harness pad. Slide the pad down the length of the shoulder harness strap.
Unhook the metal D ring.
Feed the short length, low down anchor point back in behind the seat fabric. Bring the longer length, higher up anchor point out at the desired height.
Re-attach the D ring. Adjust the harness straps accordingly.
Slide harness pad back up shoulder harness and re-attach popper.
Sep 11, 2011 | Quinny Buzz Three Wheel Stroller
How do i take off straps to clean or wash them
Good Afternoon
The harness straps are attached to the sub seat (seat frame) of the Buzz and do not come off.
To clean them, remove the seat fabric to expose the entire length of the harness straps, and use a bowl of warm soapy water and a sponge.
Aug 19, 2011 | Quinny Buzz Three Wheel Stroller
How do i remove the seat cover from Maclaren Quest Sport 2010 model stroller?
Dear maclaren were do I buy these steps at my nephew is disable he loves this stroller so much but straps are broken were can I purchase them at or please get me in the right direction. Thank you oscar o
Mar 09, 2011 | Maclaren Quest Sport Stroller
How do i fix the footmuff on the quinny buzz seat
Undo the harness at the top then feed harness through footmuff re-attach harness to top of pram
Feb 17, 2010 | Quinny Buzz Three Wheel Stroller
How to attach 5 point harness to the back rest of pliko pramette.
did you solve this problem as i still have the same problem !!!
Jan 14, 2010 | Baby Strollers
HOw to attach harness
The top harness goes in the middle of the waist harness they click in place,they will only fit one way,this is on the big buckle part there is one of these on each side.
Apr 30, 2009 | Baby Strollers
Quinny 2006 Dreami Cot
The US distributor for Quinny Strollers is below. They may cary the part you are looking for as well...
Dorel Juvenile Group USA
Canton Commerce Centre
45 Dan Road
Canton, Massachusetts, USA02021
(781) 364-3100
(800) 544-1108
Mar 24, 2009 | Quinny Buzz Jogger
Attaching a maxi cosi to a zapp
I have a maxi cosi car seat, the harness is too tight and can't extend any more. I can't fit my 2 month old into it that's how tight it is, any suggestions would be appreciated
Jun 14, 2008 | Quinny ZAPP Stroller
Broken harness on bugaboo cameleon!
I actually called bugaboo and they are sending me a new clip. covered under my guarantee.
Jun 12, 2008 | Bugaboo Cameleon Jogger
Peg Perego Venezia Single MT - Safari Stroller Logo
23 people viewed this question
Top Peg Perego Baby Strollers Experts
Jennifer Rock
Jennifer Rock
Stephen Faulkner
Stephen Faulkner
Are you a Peg Perego Baby Stroller Expert? Answer questions, earn points and help others
