Question about Toshiba Qosmio G25-AV513 Notebook
Removing the last screw from a Toshiba Qosmio G25
I found a guide online and was able to take my laptop apart, but it didn't include anything about the odd screww (#4) - under the battery near the IR sensor. It is different from the others a star shape with a pin in the center. I can't seem to get it out and didnt know if there was something special or a tool that will remove it without breaking the plastic case? Thanks in advance.
Chris
It is called a "security Torx" ... a regular star shape is a "Torx" ... the center pin, makes it a "security" one :-)
Last time I purchased such a tool, was from Pep-boys, but I have seen them at other automotive repair stores... on the flip side, where did you find the guide? :-)
Posted on Feb 08, 2009
I hear noise coming from the back vents and I think it might be the processor fan. Is there a way to fix/clean it so that noise goes away and do I have to open it from the bottom? This is for Qosmio G25.
You probably need to replace the cooling fan, but you can try cleaning it out first. Get a can of compressed air or use an air compressor to spray pressurized air into the vent to spray dust out. If this doesn't work, you probably need to replace the fan. I actually found a guide for opening up the Qosmio G25 and replacing or cleaning the cooling fan. Check it out:
http://www.irisvista.com/tech/laptops/toshiba-qosmio-g25/replace-cooling-fans-1.htm
Sep 24, 2011 | Toshiba Qosmio G25-AV513 Notebook
How can i get ethernet driver for toshiba laptopsa
You can obtain Ethernet drivers from Toshiba eSupport.
If the Toshiba laptop in question is the Toshiba Qosmio G25 Notebook PC, here is the Drivers download page,
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=1021511&rpn=PQG20U&modelFilter=G25-AV513&selCategory=2756709&selFamily=804517
(The LAN driver is what you seek)
For additional questions please post in a Comment.
Regards,
joecoolvette
Jul 09, 2011 | Toshiba Qosmio G25 (G25-AV513) PC Notebook
I need to replace my fan for my toshiba laptop, nad need to know how to disassemble the laptop to get to the fan.
Toshiba Portege A100 http://www.irisvista.com/tech/laptops/Toshiba-Portege-A100/remove-systemboard-replace-fan-1.htm Toshiba Portege A600 or A605 http://www.irisvista.com/tech/laptops/Toshiba-Portege-A600-A605/disassemble-laptop-1.htm Toshiba Portege M700 http://www.irisvista.com/tech/laptops/Toshiba-Portege-M700/take-apart-tablet-pc-1.htm Toshiba Qosimo F40 or F45 http://www.irisvista.com/tech/laptops/Toshiba-Qosmio-F40-F45/laptop-disassembly-1.htm Toshiba Qosimo G25 or G20 http://www.irisvista.com/tech/laptops/toshiba-qosmio-g25/replace-cooling-fans-1.htm Toshiba Qosimo X305 http://www.irisvista.com/tech/laptops/Toshiba-Qosmio-X305/laptop-disassembly-1.htm Toshiba Satellite 1955-S805 http://sites.google.com/site/electrochain/toshibafan Toshiba Satellite 2410 http://mardou.dyndns.org/Privat/homepage_cms.ns5/content/homepage_tutorials_toshiba_satellite_2410_-_luefter_tauschen.html?Open&lang= Toshiba Satellite A35extlink.png http://www.irisvista.com/tech/laptops/ToshibaA35/Satellite-A35-fixing-overheating.htm Toshiba Satellite A60extlink.png http://tech.icrontic.com/articles/clean_laptop_heatsink Toshiba Satellite A105extlink.png http://www.paulstravelpictures.com/Toshiba-Satellite-A105-Laptop-Overheating-Dust-Removal-Guide/index.html Toshiba Satellite P10extlink.png http://loblog.wordpress.com/2006/03/08/toshiba-p10-schaltet-sich-ab/ Toshiba Satellite P305Dextlink.png http://www.insidemylaptop.com/clean-cooling-fan-toshiba-satellite-p305d/ Toshiba Satellite X205extlink.png http://www.irisvista.com/tech/laptops/Toshiba-Satellite-X205/take-apart-laptop-1.htm List of a lot of pc fan repair guides:http://repair4laptop.org/notebook_fan.html
May 09, 2011 | Computers & Internet
Has anyone found a Service Manual for the Qosmio G25? My laptop is shutting down due to heat and I would like to open it up and possibly vacuum it out or see if there is a fan problem.
Hi!
I'm taramarsh to assist you today with this issue!
So...
Replacing or cleaning cooling fans
Here are the steps:
1. Place the notebook upside down and remove the battery.
2. Remove hard drive covers and the memory cover.
3. Remove both memory modules. (The Qosmio G25 model has two hard drives. Hard drive #1 in located closer to the battery).
4. Remove one screw while you will secure the hard drive and make it to slide out. Because the two hard drives are looking similar I suggest you to mark each one apart for a later identification. In case you will not do that and will mix the HDDs you risk to not be able to boot back into your operating system...!
5. Remove the rest of the screws on the bottom of the notebook and disconnect that cable marked with a tiny red arrow.
6. Disconnect the two cables existing on the left side of the modem card. The modem is secured to the motherboard by two screws. Remove these screws.
7. Lift up the modem from the motherboard (the last modem connector is located under).
8. Disconnect the cable from the modem (top arrow).
9. Turn the laptop into the normal working position (keyboard up).
10. Using a screwdriver or a flathead tool lift up the keyboard plastic upper part. Remove it from the laptop.
11. Now you have to be able to see three screws situated on the upper part of the keyboard. Unscrew them all.
12.Remove the keyboard and flip it.
13. Are also two screws attaching the keyboard connector cover. Remove that cover.
14. Move gently the keyboard to be able to see and identify the connector on the motherboard.
15. Remove the cable and remove the keyboard.
16. Now you have to be able to see SIX screws: two attaching the video connector cover and the rest of four securing the top cover. Remove all starting on the left side with the two video connector cable.
17. On the video connector side unplug the cable that has a WHITE CONNECTOR.
18. Flip to close the display.
19. Turn the notebook upside down as it was from the beginning of this operation.
20. Lift up the bottom part of the notebook case and remove it. Pay attention to the latches on the sides.
21. Opening the cover will let you see the WLAN card, the optical drive, the TV tuner and the two fans.
Mar 02, 2011 | Toshiba Qosmio G25-AV513 Notebook
Verticle stripes on monitor--Toshiba Qosmio G25-AV513 PC Notebook
Following factors could be causing this problem and solution as well:
1) Cable Cut: check is to see if the cable between the screen and laptop is pinched or cut. Every laptop has this wire that runs through one of the hinges
2) If this problem temporary i mean for some seconds then it could be a short signal cut problem to screen which causes screen distortion
3) Connect an external monitor and restart the laptop. If you see the same strip on the external video, then that is the motherboard or the video card problem in case you have a video card on your laptop apart from integrated graphics chip
Nov 18, 2009 | Toshiba Qosmio G25-AV513 Notebook
Wireless connection on qosmio G25-513 not working
access your router with following link
http://192.168.0.1
then type user name:admin
password is:admin or blank
then enable DHCP.then u can get ip automatically
then enable in your intel pro ipaddress properties auto get ip addrese.
thats it.
Nov 13, 2008 | Toshiba Qosmio G25-AV513 Notebook
Qosmio g25-av513 disassembly
Hi Paul have a g25-av513. First disconnect and remove both hard drives and the battery. In the battery compartment there is a small screw you need to remove and in the hard drive 2 bay there are 2 f8 screws that need to be removed as well. In all there should be 17 screws that need to be removed before you can pop the back cover off. When removing pay close attention to the connectors attached to the underside of the back cover. be careful not to pull to hard or you may tear the connectors which are very thin wires. First you have to remove all the screws on the underside of the laptop. The screws are marked f8's and f16's the longer ones are the f16's of course. I have taken mine apart several times already due to a boot up shut down issue which I believe is related to the modem board underneath hard drive 2. It seems that when ever I disconnect and reconnect this board my power shut down issue disappears. If it happens again I'm going to remove i all together and see if that takes care of my problem.
Jun 01, 2008 | Toshiba Qosmio G25-AV513 Notebook
Removing dust from Toshiba Qosmio G25
I just found this online. It might help you. After choosing the appropriate laptop, Make sure to click the pictures to see the editing arrows and circles that show where to unscrew and what to unplug. http://www.laptoprepair101.com/laptop/2006/02/04/toshiba-laptop-disassembly-manuals/comment-page-1/
Apr 29, 2008 | Toshiba Qosmio G25-AV513 Notebook
Toshiba Qosmio G25-AV513 Notebook Logo
142 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
