Question about Frigidaire AEQ6000ES Electric Dryer
Aeq6000 won't turn off
My Affinity dryer works and dries just fine. This afternoon, however, it decided to not turn off. Unless the door is open (door switch disengaged, to be specific), the drum continues to turn. I haven't noticed it giving any heat if the dryer is otherwise supposed to be off. Pressing cancel does nothing (unless a cycle was running, then the heat will turn off, but the drum will continue to spin). I have unplugged the machine, but this didn't rest anything; the drum continues to turn if plugged in. Any suggestions on what to do? Other than keep the breaker off unless actually drying?
  • 1 more comment
  • mrrpersonal
    mrrpersonal Oct 22, 2012
    Yeah, I was afraid that was the problem. But, in the interest of trying to save money, I'd like to troubleshoot other things first. Where are the fuses/relays so I can take a look at those (is there a decent wiring diagram anywhere online?) Thanks for the help so far.
  • mrrpersonal
    mrrpersonal Jan 30, 2013
    Well, it's been a while.
    The place where I bought the dryer spent a long time looking for a replacement machine for me, but acceptable stock did not come in for several weeks. Fantastic job by them in honoring their warranty, btw; were willing to repair or replace as I saw fit.
    Anyway, I convinced them to let me just switch out my possibly bad control board for one from a working machine. They agreed (again, great people)
    Anyway, when I removed my control board, an inspection revealed some broken solder joints. I resoldered them and the machine has been working fine ever since.
  • mrrpersonal
    Hmm. I'll throw a few more "anyway"s in there. Anyway Anyway Anyway. This is why you should proofread, people.
    Top Expert:
  • Frigidaire Master
  • 9,472 Answers
This has to do with the control board failure. The control board runs every aspect of the dryer and will need to be replaced. Here is the new control board.
Posted on Oct 21, 2012
SOURCE:
  • 49 Answers
SOURCE: my affinity dryer will not continue the cycle
the lights that are flashing probably mean a certain error has occured. call a servicer to find out what it means
Posted on Aug 21, 2009
bmf4069
  • 6 Answers
SOURCE: Drum runs continuously
Sounds like you have a shorted relay in the door switch. If you know a good electrician or repair man I'd give them a call.
Posted on Nov 19, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: Fridgidaire Dryer runs constantly when plugged in
You have a couple different options. One is to check the timer and make sure that it is working correctly. Second thing is to check the computer and the fusees to make sure all is well.
Posted on Feb 13, 2009
  • 1531 Answers
SOURCE: Frigidaire Affinity Electric dryer E68 error.
this is a fault code that means there is a stuck key on the board you may have to remove the control panel and check the keys if this does not work you may have to replace the panel or control board
Posted on Sep 17, 2009
Testimonial: "Thanks I relayed the information to my dad (I'm in CA and he is in FL) and he checking it out."
  • 494 Answers
SOURCE: dryer will not stop running
Your machine may have a feature called wrinkle guard or wrinkle shield, which basically keeps tumbling the clothes without heat to prevent wrinkles from setting in. Turn that feature off and see if that does the trick.
Posted on May 15, 2010
MY FRIGIDAIRE AFFINITY MODEL # AEQ6000ESO WILL NOT HEAT. IT STARTS FINE.
There is a reset on some models by unplugging the appliance and waiting a couple minutes then plug back in make sure timer is on off position and pulled out. You can also open and close the door just alil bit 6 times within 12 seconds while machine is plugged in. But I think you should test ur thermostats and heating element with a multi meter for continuity? A worse case may be that the motor has burned a winding and or ur ur power outlet is only giving half the current as the dryer uses 120 to run and the other 120 to operate the heating? thus if u only get 120 instead of 240 volts you will get an appliance that runs but does not heat.
Feb 06, 2015 | Frigidaire AEQ6000ES Affinity 5.8 Cu. Ft....
How do you open the Frigidaire affinity dryer bc i think the belt is broken
If the belt is broken dryer will not tumble, you can turn drum and should be resistance to turn, if turns easy then belt is broken. This is a difficult repair. If you can't see how to open dryer you won't be able to replace belt.
Aug 30, 2014 | Frigidaire AEQ6000ES Affinity 5.8 Cu. Ft....
When push start it makes a click but does not start. got power. belt good.
Sounds like a bad thermal shut off maybe? or the push start swtich is gone bad? can check these with a multimeter. for continuity may also want to check the door switch as this can also shut off the cycle and all u will get is a click or nothing
May 19, 2014 | Frigidaire AEQ6000ES Affinity 5.8 Cu. Ft....
Steam valve won't shut off
If the water sprays after the dry cycle has completed and you have to physically have to turn the tap off, then you need to replace the water inlet valve on the unit. Here is a link to the valve.
Oct 20, 2012 | Frigidaire FASE7073LW Affinity 7.0 cu ft...
Maytag dryer 2003 was working great I took one dried load out put another in and started the dryer. Working just fine then I found a wet garment that I dropped so I opened dryer door added this item...
When your dryer won't start, it could be a number of problems from a broken door latch or start switch to an exhaust duct blocked by lint. It could even be a tripped circuit breaker or blown fuse.
The first step in troubleshooting any electrical appliance is to ensure that it is plugged in and receiving power. While dryer plugs do not come loose easily, it can happen.
For more troubleshooting tips, read Dryer won't start for possible causes, signs to look for and things you can do. I hope this helps!
Aug 03, 2012 | Dryers
(2007) Frigidaire Affinity Gas Dryer won't shut off
mybe the star button stay stuck and the dryer tinks some one is puching the star button and it will continio to run. try to open the door and it will stop and then clouse the door if the dryer star whitout pushing the star then you now the star switch is stuck. goo lock
Feb 21, 2012 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
My Dryer won't stop drying until I open the door.
If it does this in a Timed Dry setting the timer is bad. If it does this in an Auto dry setting it could be a bad moisture sensor or a bad timer.
Aug 21, 2011 | Crosley Dryers
Fridgidaire dryer aeq6000es. won't start, beeps 3 times with error message dr
Hello
This code means the dryer door is not closed or the door safety switch is not making a good connection at times. The dryer door safety switch is in the opening of the door and when the door is closed the switch button is depressed. If the control circuit board doesn't get a signal that the dryer door switch is closed it will not allow the dryer to start.. Try firmly closing the dryer door a 2nd time when this happens, if that cures the problem you are good to go, if that doesn't cure the issue you must remove the front panel of the dryer and replace the switch. If you need a switch they are available from Sears Direct for about $15.00 Below is a picture of the switch that most likely used in your model and make, the button on top is what the dryer door depresses when closed..
Jul 12, 2011 | Dryers
My Frigidaire Affinity electric dryer will not start. Its only just over 2 years old. the timer counts down but the drum will not turn nor is there any heat. I've tried jumping the dryer but it still will...
Listen, when you push the start button to hear a low hum, if you do hear this it maybe that your belt is broken. This is an involved job but can be done if you are handy.
Jan 22, 2011 | Frigidaire AEQ6000ES Electric Dryer
Dryers Logo
214 people viewed this question
Top Frigidaire Dryers Experts
Marvin
Marvin
Craig Butler
Craig Butler
Donni Steen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
