Question about GPX ML648B MP3 Player
Need to charge battery in GPX ML638B 1GB - GPX ML648B MP3 Player
  • sarahbplus3 Jan 06, 2009
    It won't charge up when connected to computer. I have the 2G version. The instructions don't tell you anything. I guessed that it had to be in "USB mode," and tried that, but it still won't work after charging for several hours.
All you have to do is turn off your device and hook up your usb cord to your device and to your computer
Posted on Jan 04, 2009
3 Suggested Answers
SOURCE: charging my gpx ML638B
It will if it is a mini-USB plug. The mp3 has the mini-USB cord bundled, and can be used with anything with a mini-USB port. My cell has the same port, so I can charge it on the PC like the mp3, and can use the wall socket charger for the phone on the mp3.
Posted on Jan 13, 2009
  • 8 Answers
SOURCE: how do i charge my gpx?
The MW3337 runs off a single AAA battery. remove the back cover and you will see the battery compartment and SD card slot.
Posted on Mar 09, 2009
I have a ml638b digital media player, video and music, and i think i accidently deleted the firmware, it does not turn on, but wen plugged into a computer it works fine, how do i fix it?
The gpx ML638B has 2 modes while plugged into the computer. 1 as a usb mass storage, the other i believe was called an mtx device. these modes are switched by pressing the "mode" button on the side while connected to the PC. try switching between the 2 modes and browsing the drive letter it is assigned to to find and delete songs individually.
when all else fails you can always select from settings menu to format which will delete everything. and or you can use the master reset button using a pin or paper clip in the back of it.
As for only turning on when it is connected to the PC. then most likely your internal rechargable battery isnt charged enough yet or has bit the dust. try lleaving it plugged up for a few hours to charge fully through the usb connection.
Aug 04, 2010 | GPX MW3826 MP3 Player
I have gpx ml638b and the drivers wont dwld on my system and i can only hear about 20 sec. of the music it dwld and it wont let me put a 700 mb movie on it even when the file says its empty this would only...
Here is a link to the official GPX ML638b page http://www.gpx.com/store/p/261-ML638B.aspx I think the link to Software Restore Utility has the drivers you need. (I'm not 100% sure)
The only difference between the ML648B and Your model is that yours holds 1GB and the other holds 2. Also the Letter at the end of the models name specifies which color it is, B for Black and S for Silver.
Movies must be an AMV file format see here for a full tutorial on that http://www.fixya.com/support/r2808906-videos_pictures_gpx The link has a video tutorial on what you must do step by step to begin enjoying videos.
As far as only playing the first couple of seconds of music, your player may be in Intro Mode. To remedy this, Play a song and hit the button on the side of the player, select Play Mode and then select Normal.
I hope this answers all of your questions and gives you a better understanding of this device.
Mar 04, 2010 | GPX ML648B MP3 Player
I can not put pictures on my gpx ml638b media player
you can download the Manual in English under the download tab . . . under the picture.
Mar 15, 2009 | GPX MW3337G
How do i charge my gpx?
plug it into the computer through the mini usb dugh
Feb 14, 2009 | GPX MW3337G
ML638B
you charge it until the battery is full it will show u on the screen.
Jan 19, 2009 | GPX ML648B MP3 Player
Having trouble synching with gpx ml638b...
If this problem occurs then your ML648B needs to be formatted.
1. Connect your ML648B to your computer with Windows XP or later.
2. By default your computer will recognize ML648B as GPX MTP Device. Press the POWER button from top of your ML648B, to change it to USB mode connection. You will also see USB on the screen of ML648B.
3. ML648B will now mount 2 drives, one as Tools (as CD-Drive) and second as Removable Disk (Drive) – under My Computer on your Windows Desktop.
4. Right click your mouse and then select the Format option. When the Format Removable Disk window appears select the Start button to start formatting your MP3 player.
Jan 05, 2009 | GPX ML648B MP3 Player
Charging my gpx ML638B
Dec 18, 2008 | GPX ML648B MP3 Player
Can not download music to player.
Windows Media Player says that my ML638B is full but it’s actually empty. How do I fix this problem?
If this problem occurs then your ML638B needs to be formatted.
1. Connect your ML638B to your computer with Windows XP or later.
2. By default your computer will recognize ML638B as GPX MTP Device. Press the POWER button from top of your ML638B, to change it to USB mode connection. You will also see USB on the screen of ML638B.
3. ML638B will now mount 2 drives, one as Tools (as CD-Drive) and second as Removable Disk (Drive) – under My Computer on your Windows Desktop.
Dec 13, 2008 | GPX MW-3805 MP3 Player
Hello gpx mp3 player get songs on it
I can not put music on my GPX ML638B. All it says is there is not enough space. It 's brand new.
Oct 11, 2008 | GPX Audio Players & Recorders
GPX ML638B MP3 Player, 1GB
Sep 23, 2008 | GPX MW3836 MP3 Player
GPX ML648B  MP3 Player Logo
229 people viewed this question
Top GPX Audio Players & Recorders Experts
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
