Question about SATO CL408e Thermal Printer
Printer problem We are not able to print barcode labels from our printer SATO CL408e. Error shows: FRAMING ERROR
Check baud rate on NIC card (pull out NIC), against COM settings on PC. they must match. 9600 usually works
Posted on Jan 14, 2008
Sato cl408e - printing over perforations. I tried turning the Pitch(all the way to the right) and Offset(all the way to the left), and this helped a little, but still not right. Because of this, when the...
Reset printer sensor threshold setting.
Turn on printer whilst holding down line key untill printer beeps.
Use feed key to step to Gap in display.
Load label plus backing under sensor and not volts reading.
remove labels and place backing only under sensor and note volts reading.
use following formula
High reading + Low reading / 0.5 = Value to use
e.g 2.8 + 1.4 / 0.5 = 2.1.
use result to change value of input using line key once set press feed key to set.
To change label start position use the pitch menu.
Jun 02, 2011 | SATO CL408e Thermal Printer
Hi, Sato CL408e, it starts printing between the labels. The feed is off by about 0.5cm. Any idea on how I can adgust that?
1) Try to calibrate the printer.
Else
do factory reset ( Press LINE and FEED At same time and switch on the printer.
Else
Change the potentiometer offset (Pitch,print) settings in the front panel.
Rgds
Mohan
Jan 21, 2011 | SATO CL408e Thermal Printer
My sato cl408e is printing but 1/4 of the print on the inside of the label not readable. very dull and missing print. The other 3/4 of the print is perfect. Could this be a dirty print head or the...
It could be a print ehad problem, or an out of alignment condition between the platen and the head.
YOu can use a test mode to print a factory test print, that will put the print across the label. Settings and a barcode for alignment will be pirnted.
If you are using less than full width stock, only print 5 or less labels as the head will try to print across the full width, and if no label present, may harm printhead.
there are adjustments on the outside(right) of the platen support bearing that you can loosen the screw, and cam adjustment, to level the head across the platen.
Mar 02, 2010 | SATO CL408e Label Printer
Sato 408E problem
Using direct thermal labels it can dirt the printhead and platen roller, you must clean them with isopropyl alcohol and a flannel. Also adjust the darkness to less value to best print.
Roberto Martinez
Jun 29, 2009 | SATO CL408e Thermal Printer
Printer Error(Sato Cl 408 e)
PROBLEMA EN AJUSTAR EL CORTE DE LA ETIQUETA, CUANDO LA IMPRESORA SENSA LA ETIQUETA, ESTA QUE CORRIDA HACIA LA PARTE DE ATRAS DEL CABEZAL HACIENDO NECESARIO UN FEED PARA PODER CORTAR LA ETIQUETA
Jul 05, 2008 | SATO CL408e Thermal Printer
Printing
Have you tried using a SATO label Gallery? I think it's more compatible with SATO printer
Apr 13, 2007 | SATO CL408e Thermal Printer
SATO CL408e Thermal Printer Logo
1,023 people viewed this question
Top SATO Office Equipment & Supplies Experts
M_Butkus
Argospete
Argospete
 steve
steve
Are you a SATO Office Equipment and Supply Expert? Answer questions, earn points and help others
