Question about Pool & Spa
Rust from the teledyne heater
Our heater is an older one-can't get rid of the rust now even with the water control
  • Anonymous Jan 19, 2009
    i have rust coming out of heater into spa
  • 990 Answers
If you have a by-pass or water control you should be closeing this down to get more water through the heater. This is all I can think of without calling a repairman to disassemble the heater.It sounds backwards but close this valve to get more flow. I hope this helps.
Posted on Dec 17, 2009
What will resolve my rust problem, drained and cleaned spa, refilled new filters, chemicals ran it, next day rusty water, should I back flush my teledyne laars series 2 heater?
yes but it sounds like the heat exchange is clogged with rust get pool chemistry back in speck that should go away also use metal sequestoring agent that will help also
Aug 24, 2014 | Pool & Spa
BLUE PRINT FOR A TELEDYNE LAARS MODEL NO ESC250P
check gas pressure if ok check gas pressure on gas valve might have to adjust gas valve if new at this call a professional
Jan 15, 2013 | Teledyne Laars Pool & Spa
I have older Teledyne Laars LPG spa heater and thermostat/heatcontroller has stopped working. Can I diagnose whether problem is electronic or physical? ie the very small copper tube from heat chamber to...
the pressure switch is connected to the copper tube check for blockage if ok check the wires to the pressure switch should have 24 volts ac on both sides if not bad pressure switch or connections make sure filters are clean
May 17, 2011 | Teledyne Laars END CAP - 10403800
Teledyne laars model #LLD400N nat gas input 999,000 btu"s everything fires up...just no heat.
check for the manual bypass if closed water passes through to fast and doesn't heat if open water bypasses heater and heater starts to shake then shuts off
Jan 26, 2011 | Teledyne Laars Pool & Spa
LLD125 pool heater leaking water from inside
My heat exchanger was cracked. I found an old welder who knew how to weld the cracks for $100 vs $900 for a new exchanger,. Also ordered replacement seals for the 2 chambers. I used high temp automotive engine sealant as an additional sealant precaution. Also inspected tubes and cleaned corrosion. Works fine last 3 years. Takes some mechanical skills.
May 18, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
I seem to be getting rust in my spa and was wondering if the heat exchange tube assembly in a Teledyne Laars Series 2 modelESG could be the problem?
Not the excanger but the headers that connect to it. This is a long played argument between should I run water through my heater constantly and have the water erode my pipes or isolate it an have the stagnent water rust away in the header. I have long been of the school that says keep water running through heater. The damage it will do is minimal if your chems are kept right and the rust that forms the other way not only hurts the heater but it will stain the plaster when it gets into the pool or spa.
Aug 15, 2009 | Pool & Spa
What type of pipe is needed on the inflow of the teledyne laars?
Most pool stores carry a set of two pipes used for older heaters. They are about 17" long, stainless steel, and bend 90 degrees about 8" from one end. They are usually refered to as heat sinks. The fact that the old one has pin holes in it would lead me to believe using PVC would be a bad idea.
Jun 01, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Pool Heater will not fire up.
Older heaters with "Hot - Cold" turn control can attract spider webs etc. I had exactly your problem and just blew the inside of the control switch with compressed air to clean it out. My heater fired up after that clean up procedure. Hope this solves your problem!
Apr 24, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Pool & Spa Logo
144 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
