Question about Krups Small Appliances Espresso Machine
Ihave a Krups mini expresso machine and no directions on how to operate? Can you help us?
    President:
  • 379 Answers
I'm going to go out on a limb here , since i don't have a model number , is this your model (krups espresso mini #962) ?
heres the manual .
http://krups.custhelp.com/cgi-bin/krups.cfg/php/enduser/fattach_get.php?p_sid=d*C5VSmj&p_accessibility=0&p_tbl=9&p_id=127&p_created=1160132950&p_olh=0
Posted on Jan 02, 2009
  • Rick Byrd
    Rick Byrd Jan 03, 2009
    follow up - was this information worth a FIX YA vote ? thanks for voting ! .
Directions on how to use a KRUPS type 963/b expresso machine
Unfortunately there is no result on Krups website for 963/b espresso machine. However, if you browse to the website: www.krups.com and choose any of the customer support options, l am sure they will be glad to assist you.
Best wishes,
Graemevm
Dec 23, 2009 | Coffee Makers & Espresso Machines
When I try to make espresso with my new XP2070, water comes out through the steam arm and not through the nozzles. I've tried it without coffee and all the water still comes out through the steam/hot water...
David, the XP2070 won't operate properly until you've set the clock on the unit.
In case you don't have an owner's manual, I've attached a copy of the manual from the Krups site that you can download and print for free.
Please take some time to reaquaint yourself with the setup and procedure for using the expresso portion of the unit, as you might just have some sequence issues that is preventing the expresso from getting brewed.
Otherwise, it could be that the unit has a faulty seal in the pressure vessel that isn't allowing the expresso side to function properly, hence the reason the water might be coming out of the frothing tube instead of through the expresso brewing section.
http://www.krupsusa.com/NR/rdonlyres/C308FB44-1EC6-4119-A060-C73BD65F4789/7355/XP2070espresso.pdf
I hope you find this Very Helpful and best regards!
Nov 09, 2009 | Krups XP2070 10 cup Coffee Maker/15 bar...
Krups K2 XP402040 Expresso maker. This makes the
Would you like to try not put too much coffee powder, and not make the coffee powder too firm ( I mean not press them too heavy.)
Or, not grind the coffee powder too thin....
Hope it helps you.
Oct 30, 2009 | Krups Coffee Makers & Espresso Machines
Error Code 9 on a Krups XP7240 Expresso machine
After I changed piston sealing I get the same error 09. It was caused by missing connection to the thermoblock temperature sensor. In my case both connectors for thermocouple were cracked. They are located directly on the body of thermoblock, below two fuses, covered by rubber housing. After I solder them again on the position error 09 disappeared. Unfortunately it is necessary to open at least front panel of the machine. Moreover I tink that there is also important to save polarity of those two cables.
Jun 06, 2009 | Krups XP4030 Espresso Machine
I have an old expresso maker Krups type 963 and need instructions
Be advise on the recall of Krups. Just a sticker. Operation is fine.
http://www.cpsc.gov/cpscpub/prerel/prhtml95/95051.html
Dec 26, 2008 | Krups Small Appliances Espresso Machine
Krups Caffe Bistro 867 Expresso & Coffee Maker INSTRUCTIONS
http://www.krupsusa.com/All+Products/Coffee+Machines/Espresso+coffee+machines/Products/867+Bistro/867+Bistro.htm
Aug 12, 2008 | Krups Caffe Bistro 867 Espresso & Coffee...
Krups model 865 Coffe and Expresso maker manual
I NEED A MANUAL FOR A 865 KRUPS COFFEE AND EXPRESSO MACHINE, I DID NOT GET ONE
Jan 27, 2008 | Krups Coffee Makers & Espresso Machines
Krups Small Appliances Espresso Machine Logo
558 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
