Question about Whirlpool LSN2000LW Washer
Whirlpool washing machine
Our Whirlpool LSN2000LW washing machine just started to go out of balance when a "normal" size load is in its spin cycle. It will not if my wife puts in 1/2 of a normal load. I've checked the machine and its level side to side and front to back. The machine also sits on a concrete floor. Any suggestions of what could be causing this????
  • Anonymous Mar 21, 2014
    I have a whirlpool Model WTW4800XQ1 Serial C12122855. It has started getting off balance on every spin cycle. Is it possible the Spring support system is wore out causing this? Or what is the most likely cause?
    President:
  • 1,462 Answers
Check that the machine ramps up to spin speed reasonably and distributes the clothes- ie doesn't spring straight up to spin speed. if this is ok then the fault may well be the shock absorbers located at the bottom of the machine and going from base to tub. check also that the counterweights are intact
Posted on May 09, 2007
What will cause my Whirlpool washing machine to set on low speed spin cycle?
The machine uses automatic load sensors to balance the load and when you put something in the machine that is big, like a comforter, it knows that it cannot balance that item. So with a front loader it wont spin at high speed because it would be off balance and either damage the machine or the machine would "walk" because of the off balance motion.
Apr 28, 2014 | Whirlpool Washing Machines
My washer is leval but continues to display ul code when spin cycle starts
UL does not mean the washing machine unit itself is unlevel, it means the load cannot be balance, possibly washing too small a load that the machine cannot distribute in drum evenly ( happens alot when only one or two items being washed), could be poor pump out (check filters if accessible) the machine tries to start spin with excess water or maybe it is a mixed load, lots of small items and maybe one or two large items that hinder the distribution. My machine is very temperamental when I do the sheets, because they get tangled during the wash part of the cycle and then the machine cannot get them balanced to spin. I sometime have to manual move the item about and then put it to the spin only cycle.Hope this helps
Oct 06, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool front load washer won't spin - just sometimes
Most Whirlpool (Hotpoint) machines have "out of balance" sensors that detect very large movements of the drum suspension usually due to a very badly balanced washing load.
This can occur for various reasons but putting large and/or heavy items in can trigger these sensors i,f as the machine starts to spin, the items dont get distributed evenly around the drum. This is more likley with large/heavy items.
The machine will then restrict the spin speed for the remainder of the wash cycle, and once the machine is switched off, the next time the machine is used it returns the spin speed back to normal - but if it detects an out of balance situation, it will again restrict the spin speed.
It sounds to me the machine is acting as designed. You could try positioning the items differently as you load them, and hope they dont end up "all over one side".
Oct 06, 2017 | Whirlpool CAM2752KQ Top Load Washer
Whirlpool Ultimate Care II Model #LSQ7030KQ0 Won't Spin
Either a bad lid switch or a bad clutch/brake on the transmission.
Jun 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Spin cycle
The balancer spring are detached from spinning drum out of alignment /outbalance / replace balncer spring available in apliance center.
Jan 02, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
check if the springs for support and leveling are in good condition and mounted properly039ec06.jpg1bd62d6.jpg
Dec 28, 2007 | Washing Machines
Washing machine not spinning
HI! base in your complaint and explanations! i find the problem is the motor belt... maybe this is too loose belt... you can replaced a new one replacement belt... and make sure when you replace the belt is the same size in the original!
Nov 01, 2007 | GE WJSE3110A Top Load Washer
Washer goes into unbalance mode
Check the springs and spring mounts,(might be broken or not on right), also could be something wrong with the balance switch (where the tub hits the switch).It could be mis aligned or defective. Check the springs first.
May 13, 2007 | Whirlpool AWM6120 Front Load Washer
Whirlpool LSN2000LW Washer Logo
107 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
