Question about Hotpoint RGB745 Gas Kitchen Range
My hotpoint gas stove does not ignite from the inside is this the ignitor? and how do I fix it
  • hady2 Jan 02, 2009
    How do I fix it
  • Hotpoint Master
  • 8,220 Answers
Well lets think about it. If you see the ignitor glowing then you have a complete circuit. That means the oven control is sending down juice to the ignitor. The oven safety is alloing for continuity because the ignitor is indeed coming on. So what in the heck could be the problem. All the components SEEM to be working. The answer is simple. The ignitor WILL get WEAK and not put out enough AMPS to open the bi-metal inside that safety valve. The way to know for sure is to clamp on an ammeter to the system and do a simple amp draw check, however, we aint all got a hundred dollar ampmeter to check amp draw with.
Look at the ignitor,is it orange or very bright? If it is a mellow orange the chances are it is weak. Replace it.
Posted on Jan 02, 2009
  • Dan Webster
    Dan Webster Jan 02, 2009
    I will remove the door if it comes off easily. Then remove the racks and floor of the oven. Next I remove the flame spreader and then I can get to the burner. I carefully pull on the ignitor wires until I get to the quick connect. Unplug the igniter and get the burner with igniter out of the stove. I swap is all out on the bench. If you don't have money for a new part you could always swap ignitors. Most of these stoves have 2 ignitors one for broil and one for bake. Most folk don't do a lot of broiling.
Can't seem to access Hotpoint Stove Pilot Light?
Your range uses electronic ignition, not pilot lights. For surface burners the igniter sparks when the gas valve is turned to the "light" position. All burners should spark when any gas valve is in the light position. For the oven the ignitor is also electric but does not spark but rather heats up or glows. What is the problem with your range?
Nov 30, 2014 | Hotpoint RGB745 Gas Kitchen Range
All pilots ignite when 1 gas knob is used on one burner
All igniters will spark when you turn on any burner but only the one you have turned on will allow gas through to ignite.
May 04, 2014 | GE Kitchen Ranges
I have a GE Hotpoint stove/range model num 317B6641P001 that the oven will not ignite nor will the igniter turn on.
It sounds like the ignitor is bad...you will not or should not smell gas if ignitor is bad...gas valve is not supposed to open until the sensor by the ignitor has reached a certain temp. It's a safety feature. If you replace the ignitor, it should work like normal.
Jan 31, 2013 | GE Profile JGSP44 Dual Fuel (Electric and...
Broiler w/new igniter does not work, gas feed ok
WB13K21 is the ignitor that goes in your stove,i looked up part number RGB 745 and it doesn't come up as a good part number,if the bake ignitor works you can try that up in the broil,they are the same,if it lites then you know the ignitor they put in is no good.here's the sears site so you can see the ignitor yourself.http://www.searspartsdirect.com/partsdirect/part-model/Hotpoint-Parts/Range-Parts/Model-RGB745DEP1CT/1811/0124002/G0907278/00001?blt=06&prst=&shdMod=
Nov 04, 2011 | Hotpoint RGB745 Gas Kitchen Range
Gas oven, broiler and stove top work, but bake does not
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Nov 07, 2010 | Hotpoint RGB745 Gas Kitchen Range
I have a gas stove. The oven is not getting gas. The pilot light is lit, and the range works normally. Do you have any idea why the oven is not getting gas?
heatman101
Oct 16, 2010 | Hotpoint Ovens
Oven won't work
If its gas change the oven ignitor. It has to draw enough current to open the gas valve. So its only working half the time. Replace the oven ignitor and it will fix it.
Nov 12, 2008 | Kitchen Ranges
Ge xl44 I think pilot not lit. no more snap - snap and does not light
relace spark module if no snap snap from all burners.If one is just bad replace ignitor.
Nov 21, 2007 | Hotpoint RGB745 Gas Kitchen Range
Hotpoint RGB745 Gas Kitchen Range Logo
161 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Dan Webster
Dan Webster
Justin Duby
Justin Duby
Ismael Rodriguez...
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
