Question about Apple iPod shuffle MP3 Player
Apple 512a112 IPOD does not detected by the computer it show error in device
  • 64 Answers
Try a different computer, if not then there is a short in the USB connection so it would be a "total" given the shuffles current value! sorry! good luck, hope this helps! problem solved!
Posted on Jul 27, 2007
My laptop is not seeing my ipod. Cable o.k.
Try to use different usb port on your computer. If still not detecting the device try to use other computer then if the device will detect by other computer there is a problem with the usb port on your computer.
I’m happy to assist further over the phone at https://www.6ya.com/expert/ramy_d9e7ebea3891f482
Jan 12, 2015 | Apple Ipod Classic Black 160gb Video Mp3...
HOW TO UNLOK THE A1136 IPOD
click start control panel scroll to folder options tick in the box to show hidden files and holders
connect your Ipod to your computer
click start click click on you Ipod to open
then go Ipod controls device there should be a folder saying locked
right click select rename to open or delete the folder your Ipod should now be open
or you might do a factory reset
The iPod A1136 is the fifth generation iPod from Apple that uses a click wheel to scroll through your device's media library, and may occasionally lock up when you attempt to play a song or display a photo.
This error error occurs when the hard disk is unable to access the information and stalls while opening a file.
A reset of the device usually corrects the problem, as it clears the device's memory and any errors.
Check your iPod's buttons to determine if the cause is due to a hardware error before resetting the device, as the problem may be due to the iPod's hold switch.
Slide the hold switch at the top of the iPod to the right, and slide it back to the left to ensure the switch is in the off position.
Hold down the center button in the click wheel, and at the same time hold down "Menu" on the click wheel.
Continue to hold the iPod's buttons until the device's screen shuts off, turns back on and shows the Apple logo.
Plug the iPod's connector cable into the dock connector on the bottom of the iPod.
Plug the other end of the cable into your computer's USB or FireWire port to charge the iPod.
Wait at least two hours for the iPod to charge. Launch iTunes on the computer, and click "Controls" of the iTunes menu.
Click "Eject iPod" in the sub-menu to disconnect the device.
The iPod takes four hours to completely charge its battery.
hope this helps
Oct 18, 2012 | Apple Ipod Video 5.5 Gen Black 30gb Mp3...
hope this helps
Oct 18, 2012 | Apple iPod MA446LL/A MP3 Player
Ipod toch 4 showing usb with arrow pointing to i tunes logo
There has been an issue with the recent iPod update where it leaves the device in Recovery Mode. Here are some steps that have been known to fix this problem for Windows users:
1. Disconnect your iPod from the computer.
2. Restart the computer.
3. Connect the iPod to the computer.
4. Select Install Drivers Later on the dialog that appears.
5. Hold down the Windows Key and press R.
6. Type devmgmt.msc and click OK.
7. Right-click Apple Mobile Device listed under Other Devices and then select Properties.
8. Select Browse...
9. Point it to C:\Program Files\Common Files\Apple\Mobile Device Support and click OK.
The install should finish and your iPhone should now be all good.
If this doesn't resolve your problem, try this:
  1. Open iTunes and connect the iPod to your PC or Mac.
  2. Press and hold the Home button and the Sleep/Wake button at the same time.
  3. After exactly 10 seconds release the Sleep/Wake button. Continue holding the home button until you iTunes pops up a message telling you that it has detected an iPod in recovery mode.
  4. The iPod screen will remain black. Using iTunes, restore your iPod.
http://support.apple.com/kb/TS1275
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Mar 13, 2011 | Apple iPod touch
Ipod keep freezing with only the apple showing on screen...wont do anything else...says port is not found
1) Start iTunes.
2) Power the device on by holding the sleep/wake and home button for about 10 seconds. Release the sleep/wake button, but keep holding the home button.
3) If you did it correctly, the device will be showing either a connect to itunes screen (recovery mode) or a black screen (DFU mode) We are trying for DFU mode here, but recovery may work too. Connect the ipod to your computer. iTunes will tell you that it has detected an iPhone or iPod touch in recovery mode.
4) If you see the iTunes icon and cable on your iPhone, your device is not in DFU mode, but in recovery mode. Your device's screen will be black when you are in DFU mode. I always have to try this several times so succeed.
5) Connect your device back to your Pc/Mac and press SHIFT+CLICK (pc) or COMMAND+ CLICK on the restore button.
6) Select the firmware version you'd like to install from your computer. You can google for ipod touch firmare to download the file, or just let it update right from apple.
7) Wait for a couple of minutes and your iPhone/iPod will be as new.
Jan 07, 2011 | Apple iPod touch
Restoring an ipod
Make sure you got the latest itunes version and latest ipod classic version.  Also you need to be on the original computer you used to sync with the ipod.  Open up itunes and connect the ipod.  Your ipod should show up on the computer.  Just click on the restore itunes back to factory default button and you should be g to g.
Nov 05, 2009 | Apple iPod classic MP3 Player
My Computer and iTunes does not recognize my iPod
That Means Ur Device Has an "ERROR" For Sure -
U Should Get it To Apple - It shows Yellow Sign in DM -
Sure U have an Error - Why Dont U Try by Formatting Ur PC-
Then ur Device n Finaly See if it Works -
Jan 06, 2009 | Apple iPod classic MP3 Player
I connected my i pod 2 the computer and it showed me a messagae saying error in usb device.and after that it got stuck i cant it switch it off and its not even getting detected by my laptop,the light keeps...
Try reseting the iPod.
To reset iPod nano:
1 Toggle the Hold switch on and off (slide it to HOLD and then back again).
2 Press and hold the Menu and Center buttons for at least 6 seconds, until the
Apple logo appears.
-Logan
Dec 12, 2008 | Apple iPod nano
Apple iPod shuffle MP3 Player Logo
21 people viewed this question
Top Apple Audio Players & Recorders Experts
Parshiv Luthra
Marvin
Marvin
Dapid Candra
Dapid Candra
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
