Question about Sharp LC-42D43U 42 in. LCD HDTV
Air analog 3 message keeps popping up what does that mean?
When watching tv a message sometimes popping up saying air- analog 3
  • Anonymous May 15, 2009
    I have direct TV and the message on and off can I get help from the Direct TV.
    Problem Solver:
  • 13 Answers
I bought the 32 inch LCD tv. I contacted Sharp. Here is there response.
Thank you for contacting Sharp Electronics Corporation.
The display will populate on screen any time there is a change to the incoming signal (mono to stereo audio, weak/fluctuating signal strength). Unfortunately there is no way to deactivate the on screen display. If you are able, try using an alternate connection (composite video and analog audio; yellow, red and white cables) from your source device (cable/sat box, if using) to the unit. This will prevent this issue from occurring by providing a more consistent signal. Let me know if you have any other questions!
Posted on Jan 11, 2009
When im watching my fire tv stick it keeps flashing onto a blue screen then flashing back to what im watching how do i fix this
It just does this with the fire stick, regular TV is ok? If that is the case the fire stick is most likely defective.
Jan 10, 2017 | Amazon Fire TV Stick
Connecting blue ray player to tv to get netflix
You must have a smart TV for this setup.
Jan 09, 2017 | Vizio Televison & Video
Toshiba mw20f11 shows no tv stations/service with indoor antenna . Do I need to get a box in order for it to work?
YES YOULL NEED TO GET A BOX FOR IT TO WORK BECAUSE IT ENHANCES THE SIGNAL RANGE AND CONECTION
Jan 09, 2017 | Toshiba Televison & Video
My lg plasma tv is cutting off the edges of the shows we are watching. I cant find a setting that will take care of it. Can you help
hmm normally these settings are found in the picture settings of the set top box or just a setting in the tv's picture settings now there might be an option to say fill screen that may work best for some or leave the tv in 16:9 some broadcasts may only be in 4:3 at times this is normal broadcasting and not much can be done unless the setting on the picture option is set to fill screen
Jan 08, 2017 | LG Televison & Video
My sony wega kf-50E200A tv keeps turning off. during each cycle the green light blinks 42 times and the tv comes on again for about 3 minutes and it happens all over again
More than likely the power supply is defective, but without testing and the repair manual that is just a guess, you make the decision to replace or repair the TV.
Jan 07, 2017 | Sony KF-50E200A TV Lamp with Housing
Just bought a new smart tv and my panasonic recorder keeps saying not connected - why
Usually this message is because there is no direct connection between the recorder and the TV!
where do you see the message, if on the recorder then check cable connections! if on TV then turn on the recorder!
Jan 07, 2017 | Panasonic Televison & Video
Toshiba mv19m4..can i get to the menu without a remote? Want to adjust brightness..
YES THER WIIL BE A BUTTON THAT SAYS MENU DOWN BELOW AND THERE YOU CAN ADJSUT THE BRIGHTNESS CONTRAST SHARPNESS AND SOMETIMES DENSITY OF THE SCREEN INCLUDING THE COLOR
Dec 04, 2016 | Toshiba MV19M4 19 in. TV/VCR Combo
How could I connect a Daewoo 42sm TV?, I can't afford cable so I use a converter box(analog to digital w/rabbit antenna)on my other TV and I was given this Daewoo TV and would like to watch it;please
If your converter box only has RF outpit connectors "F" type screw on it looks like this my be more of a monitor then tv.I took a quick look at the manual and didn't see any RF inputs so it appears it doesn't have tuners built in Looks like you'll need a box that has RCA output connectors.or others that will match what the monitor has on it for input types
Mar 06, 2014 | Televison & Video
Where can I purchase the Audio Video Connection for my dvd player I want to hook it up to my TV but can't find the correct cable Thank you Sandy
For the COBY TF-DVD7500, the video is carried on a single RCA plug cable. You can make due with a composite video cable (with three RCA plugs on each end) or get an RCA cable. The audio output can either be digital audio (which uses a special coax cable) or a headphone connector (analog audio).I believe the headphone jack is a 3.5 mm connector. If you use a composite video cable to your TV, you can connect the red and white plugs to an adapter (3.5 mm M to 2 RCA F). Then the TV speakers will get the audio track; otherwise you can use the DVD player speakers or the digital audio out.
I hope this helps.
Jan 24, 2011 | Coby TF-DVD7500 Portable DVD Player with...
Sharp LC-42D43U 42 in. LCD HDTV Logo
291 people viewed this question
Top Sharp Televison & Video Experts
Dave Naylor
Dave Naylor
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
