Question about Ruud Matching Split Air Conditioner
Worcester highflow 400 central heating/hot water problem
The central heating light flashes continually and although the hot water and central heating light go on nothing happens. If I reset the central heating temperature control by switching off and then positioning I get hot water for 4 mins before it reverts back to flashing. What's the problem? How can it be fixed? I've had for about 4 years and no problems until now.
  • 2 more comments
  • bendonnelly1 Jan 02, 2009
    HI Steve thanks for that suggestion. I'm not brave enough to take the facia panel off but I'm sure you're correct there's a problem with the pump. I've just paid £400 + to get an engineer out tomorrow with a service plan. I wish I was more technical but I'm freezing here and had to something quickly. Many thanks for the suggestion once again.
  • fairfordmick May 11, 2010
    what is the system pressure
  • Stephen Evans May 11, 2010
    Wishing you the Best. your welcome. Steve
    If you know what the circulator pump is, see if it is pumping. First turn the power switch on the side of the unit off. turn the thermostat on. then turn the power switch back on. usually the coupling assembly (2 metal pieces connected together with springs) is visible if the pump is red. if the pump is green and named gruenfos, put the metal tip of a screwdriver against it and the handle to your ear, this will act like a stethescope and determine if you can hear it. Steve.
3 Suggested Answers
SOURCE: worcester bosch highflow 400
Sounds like a control panel.Detatch the block connector that serves the gas valve,see if you have power on the bare pins.both left and right pins should measure mains voltage.If you have no power at the pins its the pcb control board.Replace the board.
Posted on Nov 24, 2008
  • 588 Answers
SOURCE: central heating keeps going off for no reason.have
It sounds the furnace is going into lock out, you have a safety fault problem of some kind.
It could a ignitor, flame sensor, limit or roll out switch, etc.
You really need to have a service technician check it out.
Posted on Mar 26, 2010
My central heating turns off when i turn the hot water tap on. when i turn it off the central heating doesn't come back back on until i turn the power off and on.
Combi-boiler-turn hot water tap on/off and the heating stops for ...
Combi-boiler-turn hot water tap on/off and the heating stops for 20secs ... hot watertakes priority over central heating so when you run the hot tap, heating is ... Yeah onmy worcester combi there is a diverter valve - it feeds either the heating or ...
My central heating works but I have no hot water - 24'7 ...
Diverter valves switch heat between the hot water and the central heating. When youturn your hot tap on, the diverter valve temporarily shuts off the water supply ...
Does your boiler keep switching itself off? Here's why ...
Jul 7, 2015 - ... Bathroom Suites, - Showers, - Wet Rooms, - Taps and Accessories, Information and ... Low water pressure can cause your boiler to turn itself off. ... boiler is not turning off, you aren't getting the amount of hot water you require. ... If there is air in your central heating system, then your boiler may shut down.
Feb 09, 2016 | Water Water Heaters
sounds like your not getting gas...maybe a vapor lock,,,,,,,make sure you are compressing the pilot button all the way.....try to listen and see if you hear gas flowing....
Jan 19, 2013 | Bosch Worcester Spark Electrode...
Worcester Bosch Highflow 400 Boiler - no hot water or heating
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi, this is Worcester, Bosch Group
Although we don't currently offer live technical support online, our Technical Support department will be able to help. Their number is 0844 892 3366 - they're open 6 days a week and on average answer calls within 20 second. If you want to know more about our Technical Support department visit our website
We look forward to helping you
May 13, 2010 | Bosch Water Heaters
We have a Worcester Bosch Highflow 400 (10 year old) combi boiler. Over the last few weeks when we have put on the heating the boiler kicks in and fires up and the heating comes on (the water comes on fine...
The by pass pipe may be limed up. This apparently causes a reduced flow which will stop the heating side of the thing working. Call out Worcester Bosch engineer. It costs £210 including VAT and most parts and they almost guarantee to get it working.
Nov 06, 2009 | Ruud Matching Split Air Conditioner
A trickle of hot water from taps, central heating ok
it sounds like your shut off valve might be bad even though it turns on and off by turing it doesn't mean that the washer is not stuck to the seat and not opening, try replacing the valve
May 18, 2009 | Water Heaters
Worcester bosch high flow 400 lost pressure put up pressure
There are two small brown reset buttons under the control panel. Take off the white front cover and you will see them.
Nov 23, 2008 | Ruud Matching Split Air Conditioner
Worcester bosch highflow 400 - the green demand light never works when i select it, there's no hot water or heating. The green demand light does not comes on but there is noise from the boiler . .
Nov 01, 2008 | Heating & Cooling
Ruud Matching Split Air Conditioner Logo
1,001 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
