Question about Sony STR-DE197 Receiver
Does anyone know the Comcast Remote code for my Sony Receiver?
I hae a Sony STR-DE197 Receiver and all of the codes supplied in the Comcast Universal Remote guide didn't work to allow me to use my Comcast remote for this Sony Receiver.
Any help?
5 Suggested Answers
  • 50 Answers
SOURCE: Need a code for my Comcast Universal Remote
30176 is the code you need . Press Aux and then hold setup until Aux lights up. Enter code. If you want the remote to control the receiver all the time, press Aux and then hold setup until Aux lights up. Enter 993 then press Aux. Aux will flash, now press Cbl and Aux should light up when you use the volume.
Posted on Jul 06, 2009
  • 17 Answers
SOURCE: I have a Sony STR-DE197 Stereo Receiver that I got
Could be a faulty grounding. Do all the components do this? Usually turntables will have a buzzing noise if you don't hook it up to the ground bolt but I'm going to take a guess that maybe the amplifier isn't being grounded itself.
Posted on Aug 18, 2009
Testimonial: "So, would just taking a wire and hooking it to the ground hookup on my receiver work?"
  • 19 Answers
SOURCE: Hello, I need help with my sony str-de197
It sounds like the switch might be OK mechanically but not electrically. Have a look to see if you can check the connections on the switch. Perhaps there is a broken or loose or bad solder joint.
Posted on Oct 30, 2009
  • 99 Answers
SOURCE: I have Sony STR DE845
If you consult the card that came with the remote, you will find several codes for "Sony". You will need to experiment with each code until you find one that will power the receiver on and off. Then you will have control of the receiver. If you don't have the card, then go to the web site and download a copy in PDF format from there. I have a lot of Sony stuff, and I have found that the codes varry according to the year the equipment was made and its function.
Posted on Aug 31, 2010
Need Comcast 5-digit universal remote code for Sony BDP-S3100
Find Your Comcast Remote Control Programming Code
make sure your using those codes with the AUX button. Comcast does not have all remote codes for every electronic made though.
Feb 05, 2014 | Comcast Custom DVR 3 Device Universal...
Need remote control programming codes
I assume you have purchase a universal remote control...if the programming codes for your Sony STR-DE675 receiver is not listed in the remotes code guide, then you purchased the wrong type universal remote. Make sure you get a universal that does stereo equipment or check eBay for a reasonable price on the original.
Jan 07, 2014 | Sony STR-DE675 Receiver
I need the code to input to a universal remote for my Sony STR-DE325. Please help.
I just got mine to work with the STR-DE325. I programmed my Dish receiver remote following the reference in the back of the Dish receiver manual. I missed the comment at the beginning of the receiver codes at first which stated to enter a 2 before setting a tuner/amplifier code on aux. I then used the first code listed which was 683 and it works. So it was hold aux on the remote, wait until the aux was enabled by blinking, enter 2, enter 683 for the Dish remote and enter pound. E. LaPierre
Jan 18, 2011 | Sony STR-DE325 Receiver
Need remote code to program for universal remote
Code 31518 should work on your Comcast universal remote here is a link good luck! http://www.comcast.com/MediaLibrary/1/1/Customers/Customer_Support/Digital_Cable_with_OD/Digital_Cable/remotes/Remote_M1067BX3.pdf
Oct 13, 2010 | Sony STR-DG500 System
I have Sony STR DE845 receiver and comcast red button dvr remote. Anyone know the code to have the comcast remote control the sony?
Aug 31, 2010 | Sony STR-DE845 Receiver
STR-DE197 Continuous Auto-Protect
Probably dry joint on an output/regulator chip or a failed output ic.
Jun 29, 2017 | Sony STR-DE197 Receiver
Remote control won't work
Could need a new ir sensor or repair solder connections on the display (ir) board. You can check that the remote is putting out a signal by viewing it with a camcorder, turn the camera on look through the viewfinder and point the remote at it push a button. If it is working you will see a flashing light on the remote.
Feb 08, 2009 | Sony STR-DE197 Receiver
Need a remote for for Sony STR-DE597 Receiver.
Bad news, most every universal remote is for tv, vcr, dvd, cable box, and nothing else. you can goto sony.com or check ebay for a new one.
Dec 21, 2008 | Sony STR-DE597 Receiver
Code for Comcast remote for Sony DAVHDX275
It seems like most (maybe all) Sony HTIB do not work with the Comcast Custom Remote. I've found a work around that fixes the volume control and power button though. Hope it helps you all. I have a DAVHDX275 but I think this will work for most Sony HTIB systems.
What you need to do is steal some codes from a like product and then hardcode in the changes you need to the comcast remote. Set your AUX to 21232 (a sony code for TV/VCRs).
Then do the following:
1. While still on AUX, press and hold SETUP again until the remote blinks twice
2. Type 994
3. Press and release SETUP
4. Type 32975
5. Press and release VOL+
The remote should blink twice. That should reprogram the VOL+ to work with your Sony HT device. For each of the following function codes, follow the same steps and use the codes listed below:
Vol+ = 32975
Vol- = 31951
Power = 32719
Good luck. Let me know if it works.
Sep 27, 2008 | Sony BRAVIA DAV-HDX267W Theater System...
Need codes for comcast remote to ilo tv
When programming your Comcast universal remote for your TV, the programming guide states that you should enter the 4-digit code provided for your equipment, and if you did it correctly, the TV button will blink twice.
What you have to do is put a "1" in front of your 4-digit code, making your code a 5-digit code. For instance, the code for my Panasonic is listed as 0250. I tried and tried. Then I entered 10250 and it worked perfectly the first time. I did it again to make sure I wasn't seeing things, and it worked.
Good luck.
Apr 10, 2008 | Audio Players & Recorders
Sony STR-DE197 Receiver Logo
512 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
