Convergence problems TOSHIBA TP55H60
Convergence problems with my TOSHIBA TP55H60 rear projection tv. Can align center, 4, 5 & 6 but not the remaining. Green bow down from the top and up from the bottom keeps me fron aligning top and bottom convergence.Is there a fix and if so, is there a repair manual I can get to instruct me how to fix. Old TV...purchased in 1997.
  • 185 Answers
You need to replace the convergence ic's these are the stk-xxx-xxx chips found on heat-sinks
on or around the main chassis don't adjust the tubes or anything else this will only make things worse after you replace them you can do the user alignment also check the values of the resistors in the circuit as they may be off now pay close attention to the resistors that have a value less than 10 ohms these are critical to the correct alignment if in doubt replace the resistor.
Posted on Jan 02, 2009
What causes the yellow and blue ghost on tv, and how to solve it. It is on a Toshiba rear projection
The problems ur tv have is known as a convergence problems,it dead.The tv colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look like.The tv convergence board have dead 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced these parts on the tv convergence board to solved the tv picture convergence problems.The shop,will cost u $300-350 for parts and labors.
Oct 25, 2010 | Toshiba 55H70 55" Rear Projection...
Ihave a toshiba 43 inch hd 2002 rear projection the picture has shiffited to the right can I fix this
This tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignment,have colors shadows picture or 3D picture? The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,require changing to solved the tv picture convergence problems.The shop,will cost u $300-350 for parts and labors.
Oct 16, 2010 | Toshiba 51H84 51" Rear Projection...
Fuzzy picture and dark picture and color seperation when hot.
The colors seperating is a convergence problem, as far as being dim this may be related but the TV likely needs service adjustments.
convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Nov 05, 2009 | Toshiba TP55H60 55" Rear Projection...
Toshiba 64H80 alignment problem
need to replace convergence control ic's
Jun 12, 2009 | Toshiba 65H80 65" Rear Projection...
Tv turns off and will not turn back on
IC convergence chips most likely need to be replaced and maybe something else on the cicuit board
Apr 10, 2009 | Toshiba TP55H60 55" Rear Projection...
Tv shows double images
Look for the convergence menu in the manual and try to align it.
Apr 02, 2009 | Toshiba TP55H60 55" Rear Projection...
Not able to adjust convergence
Hello there, its possible it is way out of adjustment where you are no longer able to see it.
I don't know if you want to play with this, because t can be very frustrating inching each line into the proper alignment and it maybe better to call a repair person and pay them and also allow them to suffer in that time consuming headache.
I hope this helps.
BWLY
Jan 23, 2009 | Toshiba TP55H60 55" Rear Projection...
Toshiba tv model # tp55h60
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Feb 04, 2008 | Toshiba TP55H60 55" Rear Projection...
Convergence and audio problems
1)replace convergence IC's w/best quality. re-align as needed. 2)recheck audio,source and selections in menu. PVAT!
Sep 29, 2007 | Toshiba TN55X81 55" Rear Projection...
Televison & Video Logo
115 people viewed this question
Top Televison & Video Experts
