Question about Philips Magnavox MWR20V6 DVD Recorder/VCR
VCR tape loads and runs about 5-10 sec; then ejects
We tried several tapes. We put a VCR tape in and it stops and the power goes off. When we turn power back on, it ejects with the eject sign with the letter R beside it with the tape mode under the eject sign - SP.
  • 9 more comments
  • Anonymous Jan 11, 2009
    I have the same problem with my unit. I've taken the top off and watched the tape load. I see no obvious problems it runs smooth loading and unloading. but my unit shuts down after ~7 seconds. It doesn't eject the tape untill I turn the unit back on. The DVD side works fine with no problems.
  • hhylin Jan 14, 2009
    I've tried this and nothing seems to work? any other thoughts than a repair shop or a new one?
  • Anonymous Jan 17, 2009
    bought this not to long ago havent used very much and now vcr tape wont play, plays a few seconds then ejects... tried several tapes
  • Anonymous Jan 25, 2009
    I have same problem. One wierd thing though. I had the problem turned off the unit. That nite lost power for 6 hours. Next day no problem.
    I usually have the problem trying to watch a tape after watching a DVD?
  • betar Feb 08, 2009
    video cassette tape either ejects or the player turns off, sometimes it will snag the tape when it comes out.
  • ronann1 Feb 13, 2009
    VCR tape runs less than 10 seconds and the VCR shuts off. When started again the VCR tape ejects and a TV message shows a triangle with a capital R to the right and the recording speed below.
  • Anonymous Feb 17, 2009
    Up until about a month ago the tape player worked fine. One day, just stopped working. DVD player fine. VCR starts, runs about 5-10 seconds and shuts off power. When turned back on tape ejects. Cannot even fast forward or rewind tape. Same results.
  • rhaugen Feb 18, 2009
    VCR Loads and plays for a few seconds then stops and powers off. DVD is ok.
  • Anonymous Mar 03, 2009
    tried solution from hunchristia, not the problem. It appears the machine thinks it is at the end of tape. The R that appears when you turn the machine back on is the sign for auto rewind or end of tape. I have looked for an answer for a while. Any other suggestions would be helpful
  • Anonymous Apr 23, 2009
    I'M HAVING THE SAME PROBLEM. JUST THAT I DONT GET GIVE ME THE LETTER R OR E1. HOW CAN I FIX IT.
  • guitarman50 Apr 27, 2009
    my front panel indicates a tape is loaded when the cassette caridge is empty.
  • 121 Answers
The letter R could be a fault code to that machine. depending on the deck installed a number of faults could cause it to instantly eject such as its not lacing the tape correctly or the deck as gone out of timing due to wear. the tape run pulses are not being detected due to senser problems .tray switches faulty ...even some thing fallen inside and jamed the deck like a label from the cassette.good luck farr64
Posted on Apr 27, 2009
  • apode77 Nov 07, 2010
    I just tried to repair my Magnavox dual deck recorder. It kept showing the "E1" error code. What I found was a belt off on the right side of the tape drive. I assume this belt on the side is for loading/ejecting the VHS tape. The motor drive pulley was fine but the idler pulley that is located lower and more towards the front was completely worn out. It was unrepairable, or at least not economically feasible to repair. Hope this helps.
  • 3 Answers
You need to clean the vcr with a cleaner that you can buy at a store. If that doesnt work then you need to take the 4 or 5 skrews out that hold the top on and look at the motor and gears move while you put a tape in and you should spot the problem pretty quick. It'll be with the round metal wheel that turns the tape.
Posted on Jan 02, 2009
Unit will not stay on. Turn power on unit with no tape. After several seconds cycles off. I am using the aux. to monitor a cctv camera.
VCR's with faulty mechanisms will power down to prevent tape damage. Checking inside might reveal damage to the tape mechanism. Even if the mechanism isn't damaged the VCR has a device called the mode switch. These tell the electronics what position the mechanism is in. If that goes faulty the electronics can think that mechanism is in say playback mode, even when it's in eject mode. So when it detects no tape tries to stop and eject the tape. Since it can't carry out this it shuts the entire video down to be on the safe side and prevent further damage.
Mar 15, 2015 | Emerson EWV404 VCR
VCR EJECT FAILURE
When a tape won't eject, the problem can be caused by several things. The most common problem is that the belt that operates the eject mechanism is slipping and not allowing it to eject the tape. This can be fixed by either using a re-grip solution on the belt or having the belt replaced. With the cover off (be careful not to touch anything live with power) and try loading and unloading a tape. Try to find the motor and belt which operates the loading mechanism. When it "catches" as you say, try moving the belt pulley with your finger to give it a little help and see if it continues on with the operation. If it does, the belt is probably slipping. It takes more effort on the belt & pulley during an eject sequence rather than the a load sequence, so it may load fine but have trouble ejecting. Gravity and the weight of the tape is why you may not have this problem during the load sequence.
Jan 28, 2008 | Goldstar GBV241 DVD Player/VCR
The TV turns off when i put a VHS tape in the VCR. The tape will play for a few seconds, then the Power goes off. When i turn the Tv back on the tape immediately ejects.
Possibly have a tape drive motor issue it powers down to save itself .Thats the dickens with those combo sets they are hard to look at ,you have to take it half apart just to see whats going on
Feb 16, 2011 | Sylvania 6719DC 19 in. TV/VCR/DVD Combo
Loads tape then stops - won't play rewind fast
Way to go. Usually if you use anisotropic Alcohol with a few Q-tips works well I've found.
Try cleaning the other tap path items like the capstan that the pinch roller get's pushed up to also with this Alcohol. The cleaner the better the tape goes through. Much better picture.
Blessings,
A/V Media Guy
Nov 19, 2009 | Sony EVC100 Hi8 VCR
Stuck VHS Tape/Power Issue
It sounds like the vcr is not completely loading the tape, and is overloading or getting confused. If you feel up to it, you can take the cover off the tv, find the tape loading mechanism, and 'help' the loading rollers along yourself... once the tape loads, eject it immediately, and you should be off and running again. Just be careful not to touch any electrical connections. If you're not comfortable with that, you're right, it's probably cheaper to get a newer tv - check with a local independent shop first, though, it should be a really quick fix.
Mar 14, 2009 | Samsung Televison & Video
Stuck vhs tape
When a tape won't eject, the problem can be caused by several things. The most common problem is that the belt that operates the eject mechanism is slipping and not allowing it to eject the tape. This can be fixed by either using a re-grip solution on the belt or having the belt replaced. With the cover off (be careful not to touch anything live with power) and try loading and unloading a tape. Try to find the motor and belt which operates the loading mechanism. Try moving the belt pulley with your finger to give it a little help and see if it continues on with the operation. If it does, the belt is probably slipping. It takes more effort on the belt & pulley during an eject sequence rather than the a load sequence, so it may load fine but have trouble ejecting. Gravity and the weight of the tape is why you may not have this problem during the load sequence.You will need to take the cover off. Try to find the motor and belt which operates the loading mechanism. Try moving the belt pulley with your finger to give it a little help and see if it continues on with the operation. If it does, the belt is probably slipping.
Hopefully, you won't find any spilled tape in the unit.
Also look for a broken spring or cracked gear or gear with missing teeth.
Let me know what you find out and we'll go from there.
Good Luck, Jim
Mar 02, 2008 | Panasonic PV-C2010 20 in. TV/VCR Combo
MINI DV TAPE WON'T LOAD
First power off the unit, then remove the DV's tape housing , power up the unit, and allowed the mechanism to go back to the unload mode, make sure that the tape posts are at unload mode. then unplug the vcr back again, put back the tape's housing in the load position (tape in) power the vcr back on and push eject button to reset tape mechanism.
Jan 16, 2008 | JVC HR-DVS3 Mini DV/S-VHS VCR
VCR repeatedly tries to play and eject when tape deck is empty
the tape carriage is probably stuck, or something stuck inside blocking the tape sensor.
feed a tape in and see if it does it "with" the tape too
hope this helps
Jan 08, 2008 | Sylvania 6313CB 13 in. TV/VCR Combo
Ejecting of tapes
this sounds like the sensor that when you put a tape in then it places it over the sensor saying tape in then takes tape in ready for play and band maybe streached if machine is over 1 year old open case and load tape in and see whats going on if the tape is getting through the guide loading to drumhead and look to see if drum is turning if it is and guides come out to drum then it ejects tape have a look to see if any object is jaming the pinch wheel if pinch wheel is clear then when tape is removed from loading bay use a cotton bud to clean the pinch wheel from dirt as this is the take up side and spindle then try tape again if same resaults clean the sensor where tape sits if same again screw lid down and take for repair but if in 1 yrs warranty take straight for repair. good luck
Aug 14, 2007 | Aiwa HV-MX100 VHS VCR
Tape ejects just after insertion
the end-of-tape optical sensor is at fault. either it is very dirty, has failed or something else is detecting end of tape. many VCR's now will auto-eject the tape upon end of tape detect
Dec 19, 2006 | Mitsubishi HS-U760 S-VHS VCR
Philips Magnavox MWR20V6 DVD Recorder/VCR Logo
1,155 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
