Question about Garden
Light is new,but only lights up extremely dim, possible solutions
The light on my snowblower cracked, after it was replaced the new light was terribly dim. Is there some way to clean '' magneto'' to get more power generated to supply light or is there some other solution for this problem ? We have had a lot (Record Breaking) of snow and I don't always have the time to clear driveway before dark.
  • Thomas F. Schneider May 11, 2010
    An old trick. If you can find a smaller wattage bulb that wil fit,it's life will be shorter but light brighter. WE used to place 6 v headlamps in 12 volt cars,for example. I am thinking you have a 6 volt battery system on your mower, though.
  • 49 Answers
Make sure the ground wire from the light is clean and secure to the frame.
Posted on Feb 01, 2009
Dim tail light.
Brake light switch under dash and actuated by the brake pedal lever is out of adjustment or faulty. Adjust or replace it and you'll have your brake lights back. The dim tail lights may just be that you have possible replaced them with the wrong bulbs or the ground to light housing is faulty.
Jul 11, 2017 | Cars & Trucks
What are the ideal specs for LED lighting for use in indoor gardens?
LED tape lighting provides a wide range of installation possibilities as these extremely thin strips of light can be installed in the thinnest of grooves unfit for traditional fixtures and they can light place with dim-able warm light or a remote-controlled rainbow of vibrant colors for a virtually undetectable, surprisingly unpredictable effect. So, you can use them for indoor gardens.
Source: Amazon com Led Grow Light Bulb 50W GLIME E27 Grow Plant Light Plant Bulb...
Apr 25, 2017 | Heating & Cooling
Hey there I've got a BMW 318is I've put new light globes in and had the nrma check fuses an still keep going out an stay out for a while, please help
Lights on these cars all run through an LKM box = light control module. It's purpose is to turn on a warning on the dash when some bulb is not working, and all models up to 1994 have terrible problems with failing headlamps, turn signals, brake lights, etc.due to poor solder joints in these modules. Very common for headlamps to fail driving down the road, or fail when changing from dim to bright. It is possible to repair by heating and re-soldering every connection in the box, but far easier to get one from a 1994 or later junk car, if you can find one.
Jul 26, 2014 | BMW 318 Cars & Trucks
SONY VAIO PCG-61611l has a very dim screen
Normally, this is in part due to you not replacing it with what should've been an LCD. The reason why it's dim is because those diodes are not getting the required voltage to emit as it should. LCD's work under a different concept where crystals use the light modulating properties of liquid crystals. Liquid crystals do not emit light directly as LED's, because it stand for light emitting diodes.
Mar 25, 2013 | Computers & Internet
Iphone iphone light is too dim automatically i dnt knw wht happen...screen is ok but light is too dim to see...
There are only ? handful of possible causes for the problem which you are facing. The most common being the light settings for your device. The brightness of the light might have been tampered with. Simply go to settings and adjust the contrast and brightness of the your taste. If this happens not to be the case then the bulbs for your screen are bad and therefore have to be replaced. This will have to be done by an expert. Hope this solution has been helpful?
Jun 20, 2011 | Apple iPhone Smartphone
Clock lights is extremly dim on my 2000 Celica GTS, what is the solution. Is there a possible "weak" fuse, if so which fuse is it and what voltage should I replace it with... A new clock is 300 from...
There should be a resistor switch on the dashboard to either make it dim or bright, check if it works. Otherwise it is the clock that needs to be replaced.
Sep 30, 2010 | 2000 Toyota Celica
I have a Hunter fan with remote. The fan or the light comes on by itself with no one around
See my post below: (Sorry, we're in the same boat)
Hunter ceiling fan with remote, have 5, 4 are seriously impaired! Lights dim to half strengh after variable time 10 seconds-30 minutes. And lights or fan turns on randomly (come home & fan on full blast), and one in which the lights won't dim (just blinks when try to dim)! Hunter "kinda" admits there is serious problem with remote but doesn't have a solution. Tells people to try changing to different code due to possible interference (pain in **** to change code on ceiling base!), was totally ineffective. Then replaced receiver in ceiling base (another total pain) in 3 fans with new ones sent Hunter, still totally useless. Hunter's suggestion, don't use the remote, just use the pull chain. If I had wanted a pull chain fan, I'd have bought a pull chain fan. TOTALLY USELESS! Moral of story: If you want a remote ceiling fan (my friend found out that all their remotes are made by the same company in Taiwan), don't buy Hunter!!!!! P.S. I found a "Kinda"- fix for the lights dimming to half strenth. After turning on the lights, wait 1 second, then dim lights slightly, they will then stay on the strength that you dim them to. - P.P.S. When I changed the receiver in the one where the lights won't dim, it "solved" that problem...Now it has the same problem as the others, lights or fan turn on randomly!
Apr 02, 2010 | Hunter 52" Ceiling Fan With Light And...
Screen sometimes lights up but mostly stays dim
You have a bad connection on the LCD ribbon, or a cracked LCD ribbon, or the Inverter is intermittently faulting, the backlight/circuit is faulting. It is hardly ever the switch....but it is under the end of the screen look for a tiny black stick.
Mar 02, 2010 | Acer 15.6'' Aspire AS5335-2238 Laptop PC...
2005 Chevy Trailblazer. We recently had the gas
you need a new altinator if ur head lights dim and u are loosing power!!
Sep 28, 2009 | Chevrolet TrailBlazer Cars & Trucks
Screen extremely dim
I think you should look at the sleep button on pin.When you close LCD it should push that pin down(Stanby or sleep pin).
When you press or it get stuck, this pin will block or not send voltage to inverter so that the light on monitor should go off or computer go to standy or sleep mode.Check this one.
best of luck,takecare
Apr 20, 2008 | HP Pavilion dv4000 Notebook
Garden Logo
65 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
