When we try to play dvd the audio/video vsx-1017txv-k turns off
We are having problems with the audio/video receiver turns off when dvd starts to play
  • craft333 Jan 02, 2009
    no, when the dvd starts to play the pioneer audio/video receiver turns off
  • christian hunt May 11, 2010
    so does that mean you have no sound?
    Problem Solver:
  • 7 Answers
If you remove the video and audio inputs to the reciever and select dvd does it still shut down? You may have a bad rca jack that is shorted and it is causing the reciever to go into protective shut down. You can try moving the input to anothe input say aux in or vcr and see if it does the same. If it does try changing your rca jacks. You can also try just the video in and see if it does not shut down or one of the audio inputs one at a time,you may be able to isolate the problem. Always check you have the gozintos and goesouttos in the right places. what happens if you disconnect the jacks completly does it stay on and if it does do the one at a time input yellow for video white next for left channel then red for right channel audio. Hope this helps
Posted on Jan 02, 2009
Pioneer VSX-D509S 5.1- No voice audio on DVDs
try the dvd player settings to bitstream out in setting menu ok not pcm best to use coxal cable to get fiull 5.1 suround
Jan 20, 2008 | Pioneer VSX-D509S Receiver
Amp plays sound through previews of the movie - but NOT when the movie starts??
This sounds like a problem with the DSP chip. Turn off any DSP and surround modes in the unit and see if it at least plays in stereo. You may need to unhook the DVD player from the 5.1 inputs and put the front left/right into a CD or TAPE input to fully test this theory.
If that doesn't work, I have a VSX-D309 that just came up for sale (sorry, no remote)
Feb 22, 2011 | Pioneer VSX-D557
Not getting sound thru speakers only tv with hdmi cable connected do I need to connect Digital fiber optic cable too Also able to download owners manual for vsx1017txv
Receivers of this complexity require some patience. I believe the HDMI on this receiver is only for on screen display and video pass through. The audio needs to be separately connected. For digital audio you need to connect either via the digital audio coax or fiber optic input. I replaced my entire 1980s audio system with this unit and have been very happy. It's compact, and I feed it everything via a 35' fiber optic cable (under $20!) tied to a 3-way passive fiber switch (under $10) connected to my computer, a Tivo, and a DVD player. Sounds amazing (make sure to run set up to get the unit to perform with all of your speakers! -- I use an 8 speaker 7.1 surround set up).
Jun 17, 2010 | Pioneer VSX-1017TXV-K - iPod Ready, XM...
Pioneer VSX-D307 Receiver - no audio using DVD inputs
Sometimes the default on receivers in dvd mode will be digital. Make sure you are on an analog input or just try an optical or digital coax out of the dvd player and be done.
Jul 06, 2009 | Pioneer VSX-D307 Receiver
Pioneer VSX-1017TXV-K.......it keeps shutting off at high volume..can't figure out why and have tried everything in the manual to stop it but it keeps doing it
Hello, your speakers are the problem or if your unit has a fan it is not working. Turn on the stereo at low volume. Take off the speaker grill (if you can) and put your ear up to each speaker in each cabinet. You will most likely find that a mid-range or tweeter speaker is not putting out sound. That's what I have seen the most in the 20 years or so of doing this. Good Luck
barneyluc
Oct 08, 2008 | Pioneer Audio Players & Recorders
No sound
I assume you have the user manual for it.
If not it's here in Adobe Acrobat format .pdf file:
http://www.4electronicwarehouse.com/content/pioneer/vsx-101txv-k-manual.pdf
Just a thought but are you sure the speaker connecters on the back or the reciever are gripping the inner wire and not the plastic covering on the leads. Sounds daft I know but I have seen it before.
Mar 07, 2008 | Audio Players & Recorders
DVD movies do not play
A blue screen means the TV is not receiving a video signal. Check all connections, then try another player, cable, etc. Also, check DVD and TV AV settings.
Dec 10, 2007 | Pioneer VSX-D912 Receiver
DVD wont play in colour
First we need to know how you are relating the video problem to the receiver. What video inputs are you using from your DVD player to the receiver, and from the receiver to the display you are using. What display are you using? The receiver does not control or modify any video sources... it only selects (switches) them, and is basically just a pass through.
Jun 30, 2007 | Pioneer VSX-D712 Receiver
Televison & Video Logo
111 people viewed this question
Top Televison & Video Experts
Electro Med Services...
