Question about Infinity BassLink II Car Subwoofer
Light is always on!
I have installed the BassLink II in my Alpha GTV, It is working amazingly great and I am so satisfied from the sound! The only problem I am having at the moment is the blue light on the sub stays on even if I turn the stereo and the engine off! I have tried the automatic swich on as well as the off position, but unfortunately the BassLink II is always on even after 10 hour(supposed to go off after 5 to 10 mn)! can you you tell me what the solution could be? is the problem from the installation which I doubt, or from the BassLink II?
  • 49 Answers
Yes the problem is in the installation.the power supply usually has 2 to 3 positives one positive which is usually red go directly to battery. the other,either yellow,orange,or blue go to car stereo(not to battery or ignition) this supply,turn off the amp when u turn of the stereo. hope this help u....
Posted on May 09, 2007
SOURCE:
Infinity Basslink. I wired and connected everything and sounded amazing. I removed my center console to construct a box to put the Basslink in. When I was putting the Basslink sub into the box (tight fit)...
I would get a test light and see if the remote line is still working. Otherwise, yes you probably fried it. Doesn't take much in car audio to fry an amp.
Jan 17, 2014 | Infinity BASSLINK Car Subwoofer
My basslink worked great, son blew fuse, replaced, now sounds lik
If the speaker has been overdriven, it may have damaged the cone surround or damaged the speaker coil, causing it to 'rub' inside the magnet. To check for rubbing, you need to move the speaker cone backwards and forwards by hand and listen where the speaker coil/cone goes into the magnet. It should be silent if ok. If you can heara rubbing or grating noise, then the speaker is damaged. If the output driver on the amp is damaged it can give a distorted sound, which could easily happen if it tries to provide too much current.
Nov 04, 2009 | Infinity BassLink II Car Subwoofer
Basslink keeps cutting off into protection!!
From what i have heard, If you have a speaker level input connection. this sympton does occur. You buy a scosche LOC and try giving the input to Basslink, it should work fine
Jun 24, 2008 | Infinity BassLink II Car Subwoofer
Basslink Stoped working after a month ** sound ** red LED
check all your power fuses and insure you havec power where it is supose to be. maybe you have blown a fuse.
Mar 09, 2008 | Infinity BASSLINK Car Subwoofer
Power LED lit, Servo LED lit as well, no output
check the power cables on the amp and the inputs.isome time when ground cable disconnect the lioghts will light up any way. depending on the way ur vehicle is ground ed .toyota chssis r usually posite un like the norm which is neg.rating please
Jan 21, 2008 | Infinity BASSLINK Car Subwoofer
Basslink II problem running off speaker input
Definately a wiring issue. Go to this site and backtrack to see where you went wrong. hope it helps.
http://www.ehow.com/how_5829_wire-car-stereo.html
Dec 12, 2007 | Infinity BassLink II Car Subwoofer
Infinity BassLink II Keepps Cuting Out!
Auto cut is due to overload, check out the wattage handling capacity of the Amp & the woofer( if the impedence is too low there will be an over load for the Amp.
May 06, 2007 | Infinity BassLink II Car Subwoofer
Amp keeps blowing fuse
I have this same problem. You have blown the internal amp. I have had 2 of these do the same thing. There is nothing you can do but report it to infinity and try to get the unit replaced.
Dec 21, 2006 | Infinity BASSLINK Car Subwoofer
Basslink intermittant
i posted similar prob. servo lights when power is being cut to speaker (over drive) and manual shows it for purpose of tuning gain. it should flicker at highest input only...mine is on always too. infinity wasnt much help since mine is out of warranty.
Nov 13, 2006 | Infinity BASSLINK Car Subwoofer
Infinity BassLink II Car Subwoofer Logo
260 people viewed this question
Top Infinity Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Mark Skinner
Are you an Infinity Car Audio and Video Expert? Answer questions, earn points and help others
