Question about Dell XPS 420 PC Desktop
Dell xps 420 desktop want go into windows mode or reboot
Today, we were working on the electricity, and i flipped the breaker in my son's room and his computer will not go into windows mode, only a black screen....how do i get this to reboot?
    Scholar:
  • 116 Answers
Try clearing the motherboard state:
unplug power cable
hold power button 15 seconds
release power button
plug in power cable
start as usual
As much as these issues can be as drastic as noted above, this is rarely the case.
finnaly, please post some more info, do any lights come on?
The power light can be different colors and may blink, and there are diagnostic lights on the front (usually marked 1,2,3,4).
Posted on Jan 05, 2009
  • 827 Answers
When it comes to power surges it's hard to say how much of the system was fried. dell xps 420 desktop want go into windows mode or  - frown.gif It could stop at the power supply, it could stop at the motherboard, or it could go on to other components and fry everything.
The only way to tell what's good is to start testing individual parts in another machine. I don't recommend testing new parts in the damaged system as the new parts could be damaged by parts that are not working correctly in the old system. Also until you isolate the good parts you have no way of knowing if the part is not working because the motherboard is fried, or if it is because of another part that needs to work, for it all to work.
Although there is less of a chance, it is possible that testing damaged parts in another system can screw up that system as well.
If you don't have another computer to test on, you will need to take the system in to a repair shop and have them test the components.
Sorry for the bad news, but if it got past the power supply, chances are at the minimum, the motherboard is fried. frown.gif There is also a good chance you will need a complete new system.
Chris (ziraffa)
PS Always disconnect all electrical components when the power is being worked on. You should test all the TV's and stereos that came off that switch too..
Posted on Jan 02, 2009
  • chris grams
    chris grams Jan 02, 2009
    If it's any comfort, you might be able to get some of the data from the hard drive, but get it done at a PC specialists because the hard drive will only work on a system with the same hardware and bios settings, don't do it yourself..
My XPS 420 desk top won't accept my SD card
back up pics on sd card then format, reload pics and retry
Sep 10, 2014 | Dell XPS 420 PC Desktop
I have a dell xps that came with a wireless/bluetooth keyboard with mouse pad and i have another dell xps 420 that i'd like to use the wireless keyboard on...they are both dell xps's and both
Wireless/Bluetooth keyboards and mice can only be used with one device at a time it is like a bluetooth headset once it is paired with a phone it will 99.99% of the time only work with that phone and that phone only, Wireless keyboards and mice are setup on the same principal once they are paired up with 1 PC to use on another PC you have to remove the pairing. The worst case scenario is that the second PC's Wireless/Bluetooth has failed. I hope this helps.
Sep 03, 2012 | Dell XPS 420 PC Desktop
Connect midi to dell xps 420
You can use Midi to USB adapters.
Here: .MIDI Interfaces
Feb 06, 2012 | Dell XPS 420 PC Desktop
I have a dell xps 420 and its infected with some form of spyware. my issue is getting it to run in safe mode... i have no clue on how to do this. most site explain the use of f8 at startup and it should go...
To enter safe mode you must press f8 right before the Windows logo screen. In my experience the best way to achieve this is to tap the f8 button repeatedly when you turn on the computer. F8 is the correct button for Windows operating systems, the guides were right, you might have just not pressed it at the right time.
Apr 22, 2011 | Dell XPS 420 PC Desktop
XPS 600 will not boot up
goto safe mode and remove the router software from start up ? check on the screen to find which button to press normally it's f7 or f9 but it depends on the model
Jun 15, 2010 | Dell XPS 420 PC Desktop
Dell XPS 420 won't boot at all not even a BIOS screen
the bios is not starting ...
check the memory ram if its inserted correcly or
chek the beeps wen cpu starts and
http://kb.iu.edu/data/afzy.html
se if tha link is help full
Apr 29, 2010 | Dell XPS 420 PC Desktop
Dell xps 420, won't finish loading bios boot screen, freezes and gives steady fast beep,cant get into safe mode, no clue what to try
see if this info helps narrow down the failure
http://www.fixya.com/support/r4282412-find_no_post_diagnostic_information_dell
Apr 03, 2010 | Dell XPS 420 PC Desktop
Xps 420 keeps freezing or going to blue screen
Same with my Dell Vostro 420. At this rate I will just buy a new PC as I am wasting too much time on this. We tried usual stuff like cleaning inside, making cooler, removing certain virus software, still no luck. I have to restart 4 times a day and keep saving material. Can only restart by turning it off by pulling out power socket.
Jun 24, 2009 | Dell XPS 420 PC Desktop
Dell Webcam Center and Manager not showing up on my PC
Try Uninstalling them using the add or remove programs and then try reinstalling them again
Apr 05, 2009 | Dell XPS 420 PC Desktop
Word 2007 Crashes in Vista
Here is a free office program that works great.
http://www.openoffice.org/
Mar 23, 2008 | Computers & Internet
Dell XPS 420  PC Desktop Logo
256 people viewed this question
Alun Cox
