Question about OKI B4100 Laser Printer
Printer won't print without pressing the // button
Hi, my Oki won't print without me pressing the // button on the printer. Has anyone any idea why, and what I can do to resolve this. Thanks
  • 3 more comments
  • SwordUK Jan 03, 2008
    Was this ever fixed. I have the same problem. On a multi-sheet document, I have to press // after every sheet to print the next - the Oki seems to go offline after printing a single sheet.
    Many TIA,
    S.
  • jcparker Jan 16, 2008
    I am having the exact same problem. In addition to that my paper jam light is continuously flashing.
  • Anonymous May 24, 2008
  • rauke Dec 29, 2008
    Same problem for me,
    Gordon
  • Anonymous Feb 11, 2009
    i ve the same problem, and the yellow light keeps blinking. Deeox
Thank You flopez but everyone can thing of this solution. Come on and think how to resolve this when the toner is all fine you "wiz"
Posted on Feb 10, 2008
My printer can t print anything.how do i fix it?
Posted on Dec 27, 2007
We have the same problem at my workplace and it is the toner cartridge. once replaced you will find that you no longer need to press the pause button to print and the paper jam light will stop flashing. The toner cartridge you purchase slowly empties into a tray below the replacement cartridge and will continue to print for weeks or months just fine if you push the pause button, but if you lift out the cartridge you will find that it is empty. You just need to replace it when that starts happening and it will be back to normal.
Posted on Jan 08, 2009
  • 161 Answers
Your problem's been posted for 4 months, so you should have figured it by now. In any case, you eed to replace the toner bottle, which is empty.
Posted on Sep 26, 2007
I have a Oki b6500. Replaced the fuser. How to reset the message exchange, "Maintenance." Please help!
The following procedure was provided by Oki Tech support when a web search did not provide an answer. Resetting the Fuser After Replacement - When Counter is NOT Reset First print out a MenuMap and note the fuser count, to later verify that the maintenance reset has taken affect. To reset the fuser counter, enter the diagnostics mode and go to Maintenance Mode Step-1 How to enter the maintenance mode. Hold the Menu & Right arrow button while powering on the printer. Hold the buttons down until the op panel displays “Initializing”. The op panel will display “Output Test” Step-2 Press the down arrow three times. The op panel will display “Maintenance Info” Step-3 Press the right arrow. The op panel will display “Reset Maint Reqd Execute” Step-4 Press the select button. A quick flash will come up on the op panel “Resetting Maintenance Reqd”. The op panel will then display “Reset Maint. Reqd. Execute” Step-5 Press the Cancel button to exit the Maintenance Mode and go back to “Online”. This completes the process, please print out the Menu and inspect the Fuser Count it should read ‘0.’
May 19, 2010 | OKI B6500 Led Printer
Paper needs to be a little lower when it prints, it;s printing too high
hi,press the offline button , manually turn the paper feed knob back a few clicks then press the set button and remember to switch the printer mode to online
hope this helps
Apr 28, 2010 | OKI MICROLINE 390 Turbo Matrix Printer
Stuck copy button
Snap off the cover off around it and attempt to release the button. Only shot.
Jan 05, 2010 | OKI C5500n Printer
OKI 24DX - Press ONLINE button to print each page
you have to open your printer icon in CONTROL PANEL
CONTROL PANEL
THEN
PRINTERS AND FAXES
RIGHT CLICK ON YOUR OKI PRINTER
select PREFERENCES
under SET UP and MEDIA size change it to A4
I think this might help you. I'm guessing that you have the wrong size paper selected. And each time the computer needs you to confirm you want to print with a different size paper
I wouldn't phone OKI help line..I was on hold for 15 minutes, then just gave up.
Jul 01, 2009 | OKIPAGE 24 Led Printer
Oki b4600 drum reset ?
On the printer press the menu button until you reach MAINT.Then press the item + button until you reach DRUM CT RESET. Then press select.YOUR DONE!!!!!!!!
Jun 19, 2009 | OKI B4600 Printer
Setting up an OKI printer on an IMAC
Without mac drivers you do have a problem. Put it on ebay and get another printer that supports mac and windows.
May 12, 2009 | Apple MacBook Pro Laptop Computer with...
Oki Microline 590
Try to perform an offline test print using your printer alone
To do this, power off your printer first
Press and hold the LF/FF button on the printer panel then power on. The printer will perform its own printing ( lines of pattern )
If it does it without problems ( no MENU lights came on ) the printer should be OK. If not try replacing the printer main control board.
Hope this helps
KM Hoo
It
Mar 04, 2009 | OKI MICROLINE 590 Matrix Printer
"490: MP tray is empty" message when trying to print labels from Word 2003
The MP tray referred to is the Multi Purpose tray and is located at the front of the printer. To access it, you need to find the 2 indentations at the side of the front feed assembly and pull them towards you. this then gives access to the MP tray. Don't forget to press the blue button after loading the paper. Your user guide/manual will give clear instructions and pictures. It may also be called manual feed tray. Once loaded with the correct paper press the online button and printing will start.
Oct 18, 2008 | OKI C5500n Printer
Printing from apple OS 10
http://malta.oki.com/fcgi-bin/public.fcgi?cid=144&pid=6&languageId=1&hex=013581&hex2=97ACCB&prid=466&prodname=B4100&pdflag=2
Apr 24, 2008 | OKI B4100 Laser Printer
Oki c5500n drum reset
To get the OKI C5500 to keep going (without opening and closing the lid constantly) in spite of toner cartridge & drum life messages:
1) Turn off printer.
2) Hold down "+" and "-" buttons at the same time, and keep them held down while turning printer back on... continue to hold until the word "OKIUSER" appears.
3) Use "-" button to scroll down to "FUSE KEEP MODE".
4) Press "Enter" button, hold for approx. 10 seconds, then release.
5) Press "Enter" button again, followed by rapid release and repress with hold for approx. 10 seconds.
6) Release "Enter" button, then press and let up one more time quickly.
7) You will see "INITIALING" and then "ONLINE" messages.
If you currently have an error message for toner cartridge life, the message will continue to be shown until after you've sent one print job, and then it will usually disappear for awhile. It will stay gone for longer if you have your printer set up so the toner sensor is turned off.
If you currently have a error message for drum life, it will continue to appear, but you will still be able to print.
Beware that you will have to keep a closer eye on print quality (since you are no longer relying on error message to tell you when your toner cartridges are in need of a replacement or refill, or the drum truly needs to be changed or refurbished).
Please note that anytime you turn the printer off, you will have to go through the whole process again when you turn it back on. It doesn't take long though, and will quickly become habit whenever turning on your printer for the day!
Good Luck.
Apr 08, 2008 | OKI C5500n Printer
OKI B4100 Laser Printer Logo
343 people viewed this question
Top OKI Office Equipment & Supplies Experts
Steve Allison
Steve Allison
Clive
Clive
Argospete
Argospete
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
