Question about Philips HTS-6500/37 System
HOW DO I ADD A BLU RAY PLAYER TO PHILIPS HTS6500
I HAVE A 42INC VIZIO 1080P LCD, WHICH I USE THE HTS6500.I WANT TO ADD A BLU RAY PLAYER TO THIS SETUP. CAN YOU TELL ME HOW OR CAN THIS BE DONE.
THANKS
  • 8,596 Answers
If there is some type of audio cable running directly from the Vizio to the HTS6500, then you can just plug the Blu-Ray player into the TV and you're set. If the current audio cables are running instead from the cable or sat box to the HTS6500, then you will need to run audio cables from the Blu-Ray to the Philips HTS6500. There are 3 available audio slots on the Philips - the Digital Audio/Coaxial IN, AUX 1, and AUX 2. If the Digital Audio slot is already taken, then you will have to run red and white cables from the Blu-Ray player Audio OUT to either the Aux 1 or Aux 2 on the Philips (I am making a huge assumption that your Blu-Ray player has red/white audio outs). If the Digital Audio slot on the Philips is not taken, then run a digital audio cable from the Blu-Ray to the Philips. Good luck!
-Tha Mp3 Doctor
Posted on Jan 02, 2009
How do I install my Philips BDP2100 Blu-ray player
Why do you want to install the blu ray player you Xbox one can play blu Rays I would bother connecting the blu ray player at all
Nov 22, 2014 | Philips BDP2100 Blu-ray Disc Player -...
Philips quadrasurf TV
Analogue TV reception has nothing to do with signals from Blu-ray players.
Connect your Blu-ray player to either a HDMI port on the TV, or use a HDMI to DVI adapter (which is picture only) and supplement it with a a connection for audio via RCA/phono- or RCA/phono to jack cable from the BD player to the TV.
Press the AV Input button on the remote to cycle through the input sockets.
Sep 08, 2014 | Philips 40MF430B/F7 model Magnavox LCD TV,...
Adding amazon app to blu-ray player
Unfortunately, no. All the apps that are on any Blu-Ray are added or removed by the manufacturer. In your case, Netflix pays Vizio to put their app on there. I've seen apps removed and added from players during updates. So unless Amazon and Vizio make some sort of an agreement, that player will never be able to access anymore than what was loaded on it when you bought it.
Jan 20, 2014 | Vizio VBR220 Blu-Ray Player
Can't get 3D to work on my Vizio
To view 3D content, you will need:
  • VIZIO Theater 3D HDTV
  • 3D Blu-rayTM player with a Blu-ray 3DTM disc (sold separately)
  • VIZIO Theater 3D Glasses
  • 3D-Ready HDMI cable (sold separately)
    Make sure you have all of these things in order and let me know if your still having problems.
Oct 25, 2012 | Vizio M3d420sr 42" Full 3d 1080p Hd Led...
My Sansui SLED 2453W 1080p HDTV will not support my Toshiba BDK33 blu-ray disc player.
try to force resolution below 1080p to interlaced, or 720 and see what happens..you may have a bad logic board
Aug 20, 2012 | Televison & Video
Blu-ray player mode not supported
Is your TV 1080p? If the Blu-Ray is putting out 1080p and your TV only supports 720p/1080i then you will get a message like this. Try changing your settings to 720p while it is connected to a TV that does display correctly, then move it back to the 47 in LCD.
Jul 08, 2012 | Insignia NS-LCD47HD-09 47 in. LCD TV
I am trying to figure out the code for my Philips CL034 Universal Remote to operate my new Vizio Blu Ray Player. I have tried every Vizio 4 digit remote code I can find. Plus, every 3 digit code with a 0...
You could try the manual code search for the remote. With the player on, press and hold Setup until the light blinks then press the button that you want to use to control the Blu-ray player. Press Play repeatedly until the player responds. Press and release Mute to lock in the code.
However, I suspect your problem is that the blu-ray player is newer than the remote. Universal remotes tend to be limited to codes for devices released 6 months or more before the remote was programmed. Thus you need a newer universal remote. You can try the remote that came with the Vizio player (most of these will control a few other devices).
I hope this helps.
Apr 04, 2011 | Televison & Video
I have a sony bdps360 i need to reset the res from 1080p to 1080i i need HELP
You can select the “HDMI Resolution” of the Blu-ray Player is set to “Auto,” “1080i,” or “1080p” in the “Video Settings” setup. You can refer the page # 43 of the Manual of the Blu-ray Player.
Jan 16, 2010 | Sony BDP-S360 DVD Player
I dont have HD quality
You would have to supply much more detail to answer this!
What make/model is your Blu ray player?
I'm assuming you have gone thru all of the system setup menus on your DVD player to select HDMI interface, etc???
Nov 17, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Philips HTS-6500/37 System Logo
323 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
