Question about Novelty Manufacturing Older Than Dirt Birthday Cake Hat
Portable generator low voltage
Generator only puts out 85 volts on both 115 and 220 outlets. Increasing engine rpm only increases voltage slightly. Pulled generator apart nothing seemed damaged or miscolored.
  • troubleguy Mar 06, 2009
    have 89 +/_ volts on 120v circuit & 175 +/_ volts on 240v circuit -- no owners manual -- unit has set for extended peroid--how do you flash kohler 11500 watt generator?
  • 3 Answers
85 volts represents residual voltage. It is possible that your unit sat for an extended period and lost it's magnetism or the excitation system failed under load. check your manual for a procedure to "flash the field". If that is not successful, e-mail me and I'll tell you how to trouble shoot the failure.
Posted on Jan 04, 2009
  • Gordon Litton
    Gordon Litton Sep 27, 2014
    I am having the same problem with low voltage. I don't have a manual so I can't find the procedure to 'flash the field'. Mine is putting out about 110 volts on the 120 side. My generator has set for a couple of years without being started. It does start and runs fine, just a little low voltage.
Briggs & Stratton Briggs Stratton 6200 Watt Portable Generator voltage adjust
Usually the cause of slightly low voltage like this is that the engine is not running at full operating RPM. Find the high speed adjusting screw on the govenor linkage and adjust the engine RPM until the output is 220V - 240V
Dec 09, 2013 | Briggs & Stratton Briggs Stratton 6200...
Adustments engine speed low rpm
You cannot adjust the voltage output. All generators are rated for 110-125 volt recepticals and usually have at least one 220-240 volt receptical for special appliances that require it such as water heaters, pumps, welders, air conditioners. When one of these higher draw appliances is connected and they begin to draw amperage, the gas engine will automatically increase rpm to produce enough amps. If your generator gauge is showing low voltage such as 60,80 or 90volts for example, then you have overloaded the generator and blown a capacitor, resistor or similar item.
Dec 05, 2013 | Northstar North Star Honda 13hp 8000 Ppg...
Low voltage
Have the out put voltage on you altenator checked, if it's fluctuating it may be going bad
Oct 25, 2017 | 1994 Buick Regal Gran Sport
I have a coleman 6000. It runs for a whileand when I load it up it trips off.
Make sure the governor is working properly. When you put a load on it the engine should increase in speed slightly. Make sure the engine is running at the correct speed 3600 rpm. Try plugging in an item that draws less power such as a electric drill and see how the generator behaves. Also make sure the engine runs smooth while not under any load. Check the voltage from the outlet to make sure it is putting out 132 volts not under load.
Mar 14, 2011 | Coleman Powermate Proforce 6,000 Watt 12...
Briggs and stratton 8000 watts generator, the output of the 120 is only 102. How do I adjust the output?
Voltage is adjusted by increasing rpm of engine. Use meter with Hz setting and try to adjust to 60 cycles and check voltage to be at about 115-120. If engine is turning 3600rpm/60 cycles and voltage is very low, then problem is most likely with brushes/ commutator rings, or voltage regulator. Some voltage regulators have an adjustment screw to bring voltage up/down (adjust to proper rpm/cycles first). Good luck
Sep 09, 2010 | Briggs & Stratton Electrical Supplies
My generator is not putting out the proper voltage? it's only putting out approx 75 volts on the 120 volt circit. i adjust the idle to full out and i get approx 112v.
Most low voltage conditions on generators are simply due to a low engine rpm. Most modern generators are 2- pole windings. So your engine rpm should theoretically run @ 3600 rpm. which will produce 120/240 volts @ 60 HZ. In actuality You want to set your rpm's @ Approx. 3720rpm no load. About 62.5 Hz. Without getting to technical this will give you your desired 120/240 volts loaded. Hope this helps.
Aug 09, 2010 | Northstar Electrical Supplies
Test for charging
take a voltage indicator, and put the wires of the tool on the batery. each wire one each pole of the batery. Black to black, red to red. Turn on the engine, and increase the idle speed until aprox. 6000 rpm. the voltage indicator should indicate voltage from aprox. 12 Volts to aprox 15 volts. if the volt are not increasing with the engine rpm, is mostly a charging relay issue.
At the idle speed, the voltmeter should indicate minimum 12,5 -13 volts. If not, the same issue.
The test should be made with the battery charged and in great working condition.
Apr 12, 2010 | 1985 Honda CB 700 SC Nighthawk
Buffalo tools 4,000 watt generator
wow, that is high, i would think voltage regulator is faulty also
Aug 17, 2009 | Buffalo Tools 4,000 Watt 6.5 Hp Portable...
I have a Coleman Powermate Pulse 1750 generator. The engine runs fine but lately I've noticed I'm only getting approx. 105 volts. Any suggestions.
Engine speed is low, does your meter read frequency? Set for 60 Hz @ speed. I doubt there is a voltage regulator adjustment. This may help
Jun 25, 2009 | Coleman Powermate Premium Plus 6250W...
Low voltage
Most generators use a flyball type governor within the engine to control rpm; also there is a voltage regulator that tries to maintain voltage at about 115v. The voltage regulator varies the voltage to the armature increasing /adjusting magnetic force. Use a meter with htz or freq setting to adjust engine governor to 60 cycles. When the generator is producing 60 cycles, the engine should be turning 3600 rpm, max power range. At 3600 rpm the voltage should be 115 to 120 volts. Loading the generator will cause governor to try to maintain 3600 rpm. Check engine manual for proper adjustment of gonvernor and linkage. The governor mech should last the life of the engine, however governor system does wear out. Expensive repair. enjoy
Nov 26, 2008 | Yamaha Electrical Supplies
Novelty Manufacturing Older Than Dirt Birthday Cake Hat Logo
1,695 people viewed this question
Top Novelty Manufacturing Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Novelty Manufacturing Toy Expert? Answer questions, earn points and help others
