Question about Kenmore 24032\24036 Top Load Washer
Top load washing machine
Washer will not run in water when set on ''medium'' load. won't stop running in water when set on ''high load''
  • 163 Answers
Hi!!! looks like you have a bad timer..timers can be expensive..good luck
Posted on Jan 04, 2009
Is it normal for the washing machine to start and stop the spinning while the machine is in each cycle? Should it take over an hour to run one wash cycle?
Yes...they use less water...so they start, tumble, then cycle again adding more water. I use the fastest setting on all my clothes which is 1/2 hour. It also does start and stop during spinning to tumble the clothes. It speeds up as it goes thru each stop till it spins real fast. All my clothes wash perfectly on fastest cycle.
Aug 13, 2014 | Bosch Nexxt 100 Series WFMC1001UC Front...
Washer just keeps filling and never advances on large and medium loads only
Your drain hose is pushed too far down into the drain so when you select the larger load sizes the water is being siphoned out as it goes in due to the pressure differential.
Jun 01, 2012 | Electrolux Washing Machines
Top load maytag performa washer won`t stop flling both on wash and rinse cycles.
The switch the tube connects to shuts the water off. Will it cut off on high medium or low level. You can try blowing on the tube to see if it works. It should cut off when you blow.
Oct 15, 2017 | Maytag Performa PAV2200
Water wont cut off
Does the water run if you push the timer dial in to stop the cycle or does it run even if you unplug the washer?
Dec 31, 2011 | Whirlpool LSR7333 Top Load Washer
Do water level is not working. It will over flow
change your pessure switch. Thats the switch that says
medium low or high loads
Jun 06, 2010 | Kenmore 22422 Top Load Washer
Maytag washer water doesnt stop
raise top or remove front panel(can't remember which) rear corner left small hose attached to connector on tub pull and clean probably plugged up with crud also ck connection on tub
Dec 12, 2008 | Maytag HAV3460AWW Top Load Washer
Hotpoint topload washing machine won't water won't stop running.
washer top load will not stop filling even when turned off
Dec 01, 2008 | Hotpoint VBSR3100D Top Load Washer
Ge washing machine
does the cold and hot shut off at med. and high?it sounds like your cold water valve solinard is sticking and needs to be changed,(very easy fix,let me know more-mike
Oct 28, 2008 | GE WVSR1060A Top Load Washer
We just bought our Admiral Top load washer 1 week ago and now the water will not fill the machine to do one load. We have stop using the super capacity setting and are trying the medium capacity setting...
ck to see how far down in stand pipe drain hose is shouldn't be more than 6-8 in also be sure stand pipe is at least the height of washer edge above floor there also needs to be small gap between washer hose and standpipe ..if hose is too tight in stand pipe or too far down or not high enough from floor a problem with siphoning may occur
Aug 10, 2008 | Washing Machines
Kenmore 24032\24036 Top Load Washer Logo
27 people viewed this question
Sal De
fordexpert
Robert Rankin
