Most LCD and PLASMA sets use two boards (some combine them into one board) that drive the Display Panel (the entire front screen unit) so I would suspect one of yours is bad.
The other unpleasant possible cause is where the left board is connected to the Display Panel (entire front screen unit) you have a problem inside that Display Panel and that is fatal as there is no way to get INSIDE the panel---it can cause both lines and a dark picture on one side of the screen.
You have the unit in dark mode. Press the Dim/Dark button again to get the unit to full brightness. THe unit has 3 levels of DIM. First the unit is at its full brightness, pressing the dim/dark button will dim the display and the unit functions normally. Press the Dim/Dark button again will futher darken the display but when the unit alarms the display is turned off and remain off during the alert. After the alert is over the unit waits 20 seconds of no alert to turn the display back on.
The problem actually is from a lamp in the unit, it is getting damaged gradually that is why it is two third of the screen that has gone dark. once it gets completely damaged, the entire screen will turn dark.
Try to ***** the lamp of the television and replace it with a new one.
After doing that your television will be in good condition once again.
if the screen needs to be wired to the dash light switch it will not change unless the lights are on, if the wire is disconnected it is possible to bypass it making the screen stay bright.
although it would seem more likely that the brightness could be adjusted on the unit settings or by a button on the unit itself
you have damaged the screen and it will likely need replacement. there is one other possibility... you may have loosened a connector inside the radio... tap it gently with your finger to see if there are any changes in the display
Press the middle key and menu key at the same time until the apple screen comes on. This will reset your settings but usually when my iPod does something funky like that I just do that and it's fine. If that doesn't work, contact your local Apple store.
sitnlisten - yes it does appear your pix tube is getting weak,but we may be able to turn up the flyback alittle to brighten up the picture.If you take the back off you will see the flyback-large black unit with a wire going to the round rubber cap on the back of the pix tube.Look at the flyback there are usually 2 adjusters one marked focus the other screen,just turn up the screen a little bit at a time.If you turn this up too much you will wind up with retrace lines on the screen.You may also want to check the pcboard ass'y for a sub bright adjust,and same thing small adjustments.If this don't help your pix tube may be too far gone.I hope this helps. cooltek Feb.1/08
