Question about Emerson Smartset Clock Radio
The clock does not show the correct time.
At first the projector did not work,so changed the battery and then
the time is incorrect, how do you change the time to be correct?
  • 814 Answers
[] copy this web link and paste it into the address bar of your web browser. It will take you to the Emerson customer web page for the pdf copies of the SmartSet Clock/Radios. You will need a pdf reader and writer to read and make a copy of the owners manual for yourself.Find the make and model number of your Clock/Radio. The instructions for resetting the time after changing the battery will be in the manual. I hope this information helps you with your problem. Than you for using FixYa and have a nice day.
Posted on Jun 13, 2009
My 87700 skyscan does not keep the time correctly after the day lite changing
The first thing to do is check the batteries. Corrosion is a common problem, so check and clean the contacts if need be. Weak batteries can also contribute to issues.
Clocks require more signal as they get older. In order to keep the correct time, the clock 'checks in' with the satellite periodically. If it isn't able to receive a signal, it may lose its way and display the incorrect time, so you might experiment with placing the clock in different locations at 48-hour intervals to see if that might be affecting its time-accuracy.
Nov 07, 2017 | Home
Problem with sony cybershot camera showing incorrect date- how do i change the date?
If you know how much wrong the clock was set, ie.
The clock was 1999-01-01 14:37 but it should have been 2017-05-22 19:00, there are softwares that could correct this error for a directory of files.
just search for exif time offset correct software (exif is the files hidden information about the photo)
Nov 16, 2017 | Sony Computers & Internet
Clock is 2 hours ahead of actual cst time
If you have an atomic clock/watch that is not showing the right time, you could have one or two separate problems. First, the clock may not be set for the correct time zone. Second, the clock may have a manual switch to adjust the time for daylight savings time. Each of these problems can make your clock display the incorrect hour of the time, especially after you change the batteries and your clock "forgets" some or all of its prior settings.
Check the back of your clock to see if there is a button or switch to set the correct time zone. If your clock appears to be set to your time zone, change the switch to another time zone and see whether the clock moves forward/backward to adjust. Once it has finished adjusting to the new time zone, adjust the clock back to your time zone to see whether it will now correctly reset to display the time.
I have seen atomic clocks that have manual adjustments for these settings as well as ones that adjust automatically other than the time zone. If you provide the manufacturer and model number of your clock, we should be able to provide more detailed instructions.
May 06, 2011 | Watches
My emerson cks1850 still stuck to the old daylight savings time and I need to fix it as i rely on it for work and frequat power outages we have were i am and the auto reset is why i like it but now it...
unplug the clock radio from the power, take out the back up battery ( if it has one). let it set for 60 seconds or so, plug it back in, It should now be flashing 12:00 over and over. now reset the clock to the correct time and date.
Mar 14, 2011 | Emerson SmartSet CKS1850 Clock Radio
Hi. The clock on my Acer will not keep the correct time any more and it doesnt change dates on the calendar either. Do I need to change a battery in my motherboard?
If you change the BIOS date and time and when you boot up next time and the date and time has changed back or is incorrect, then the most likely fault is a flat BIOS battery. Replace the BIOS battery, it maybe a coin type lithium 3volt battery. this is the most common type used in motherboards is a CR2030 lithium battery.
Nov 03, 2009 | Acer Aspire 5630 Notebook
Time is incorrect on tomtom 330s
Turn on your TomTom and tap the screen until you see change preferences. Tap "change preferences", then tap the forward arrow until you see "set clock". If you don't see "set clock" you may have to tap "show more menu options".
Aug 28, 2009 | Tomtom XL 330S GPS Receiver
Outside temperture
Try changing the batteries in the CLOCK. I had the same problem in a 3M similar clock and it didn't read the transmitter correctly or eventually, at all, when the CLOCK batteries were getting low.
Nov 19, 2008 | SkyScan 86742 Digital Atomic Wall Clock
Resetting the atomic clock to the correct time zone, and outside temp to work.
For the Sharp SPC374T Atomic Clock - Time Zone setting- Press the 'Time' button once, the time zone will show where 'Day' usually is, use the Up or Down buttong to adjust.
For the outdoor Thermo, credit to my neighbor for this one. Remove battery from main unit, wait 2-3 minutes. Reload batteries. Once you get a reading from the outdoor sensor, hit the reset on the main unit. You will have to reset the time zone as described above, but this worked for me after 10 months of no outside temp showing up!
Good luck,
Dec 01, 2007 | Baby Gear
Wrong date on the radio.
If you do not change the built in lithium battery within a reasonable period of time after you see the ‘flashing’ LOW BATT. warning indicator, the lithium battery may become exhausted and will no longer be able to supply back up power to the SmartSet internal computer.
If the unit is disconnected from the AC outlet after the battery is exhausted, or if a power interruption occurs, the SmartSet memory will be lost and the clock will need to be reset when the power is restored. Be sure to install a fresh lithium battery before you reset the clock, otherwise the clock will need to be reset each time the power is interrupted.
If the lithium battery is exhausted and you experience an interruption in the AC power supply, the clock will reset itself to its initial default setting when the power is restored.
The initial default setting is “12:00 AM, Saturday, January 1
(1 1), 2005”.
If you notice that the time on your SmartSet clock radio is completely incorrect, and the day indicator is also wrong, press the MONTH/DATE button to see the date. If the date display is showing “1 1” (January 1 ), you probably experienced
a total memory loss. To reset the clock after a total memory loss, proceed as follows:
1.) Install a new CR2430 lithium battery in the battery compartment.
2.) Connect the radio to your AC outlet and let the clock set itself.
3.) Depress the MONTH/DATE and TIME buttons together. The display will change from ‘time’ to ‘year’. While holding the MONTH/DATE and TIME buttons, press the UP button to
set the display to the correct year, then release the buttons.
4.) Depress the MONTH/DATE button. The display will change from ‘time’ to 'month/date’ (mm/dd). While holding the MONTH/DATE button, press the UP button to set the display
to the correct month and date. The Day indicator will change automatically as you adjust the month/date settings. When the correct month and date appear on the display, release the buttons.
5.) Depress the TIME button and the UP button to set the display to the correct time. Be sure to confirm that you have set the time correctly to ‘AM’ or ‘PM’ by observing the AM indicator.
6.) After you set the time, reconfirm that the Day, and Month/Date displays are still correct. Make final adjustments if necessary.
The SmartSet clock memory is now reset and the new lithium battery will maintain it for the next 5 to 8 years, depending on the number and duration of the power outages you experience.
After resetting the clock, don’t forget to reset your wake up times, and alarm mode settings, and sleep timer settings as well.
Oct 22, 2007 | Emerson SmartSet CKS1850 Clock Radio
Emerson Smartset Clock Radio Logo
241 people viewed this question
Top Emerson Audio Players & Recorders Experts
Greg Cann
Greg Cann
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
