Question about Canon PowerShot SD1000 Digital Camera
I can only view some of the pictures on my computer.
When I view my pictures I took on my camera I can see them just fine, When I put the memory card into my card reader on the computer and try to view them a large amount of the pictures are not viewable there is the icon showing the picture is there but if I tr to view it with any program I have it tells me there is no data or the program I am using will just shut down.
  • apeck47 Jan 06, 2009
    I found when I plugged the camera in using a USB cord I could view all the pictures so the problem was with the card not the camera formated the card and it seems to be okay now. Thanks so much
  • Canon Master
  • 4,738 Answers
Your card reader or the card itself might be failing. The way to check the reader is to simply buy a cheap replacement USB reader to see if it corrects the problem. Example:
http://www.amazon.com/gp/product/B000I4RFO2/ref=s9subs_c1_23_at1-rfc_p_si1?pf_rd_m=ATVPDKIKX0DER&pf_rd_s=center-1&pf_rd_r=0F2N9JTRPXSGCNJ05THH&pf_rd_t=101&pf_rd_p=463383351&pf_rd_i=507846
But if this doesn't help, then it's likely the card. In this case you'll then need to use recovery software to get at your pictures. There's plenty of good freeware available:
http://camerarepair.blogspot.com/2007/12/recovering-those-accidentally-lost.html
Finally after recovering your photos, consider formatting your card IN YOUR CAMERA. This may help rejuvenate your card, and help prevent this from happening again. If you don't know how, press menu, then select tools menu, then scroll down to the selection outlining your cards memory capacity and select it. Then follow the on-screen prompts for "low-level" format. Again only do this after you've recovered your photos as it will also erase your card.
Posted on Jan 03, 2009
I have a Nikon D5300. I can see the photo count number increasing, but I cannot view the images and they are not going on the SD card. Where are they? The SD card is not full.
many small Nikon cameras have memory to store images ON THE CAMERA. If you have a memory card installed that the CAMERA CAN READ it will put images on the card. if the memory card is corrupted the camera will not use it.
First Backup all IMAGES on Memory Card to COMPUTER make sure you saved ALL images. This is IMPORTANT.
After you SAVED all images you PUT Memory card back in camera and FORMAT it (Format is in TOOL Menu that looks like a wrench)
Now if you can take an images and it saves to memory card you are done. To see if they go to MEMORY CARD. Turn off camera and remove MEMORY CARD and Check.
If it STILL does not work you may have a defective memory card.
Feb 23, 2017 | Nikon Cameras
When I view my photos I have already taken they look good until I try to zoom in, then the photos go fuzzy in multiple color stripes taking over the screen. Will my photos be fine when I load them to my...
Fuzzy pictures are most often caused by not holding the camera steady enough it's the number one problem with shooting "Live View". It's not the camera nor the memory card it's the person that's taking the picture. Sorry if that was to blunt. Now saying that not all the pictures will be blurry if you are shooting in full auto the camera is correcting for different scenes and lighting conditions so some will have a faster shutter then others so faster shutter speed will produce less blurry pictures.
Okay the memory card thing you should never swap memory card between cameras unless you format them first. Formatting wold remove all the pictures so what you did was really not good, I can get into a whole lot of issues why not but to keep this short It's not a good idea to swap card.
Transferring pictures from the camera to the computer requires having the camera software installed on the computer first. There are different sequences or flow of connectivity between camera makes one thing for sure is you don't "just unplug it" that is a sure fire way of corrupting the memory card.
With the camera turned off . The proper transfer sequence for your camera will be listed in the owners manual but, normally you connect the cable (if you connected a cable between it was the right cable) to the computer USB port not a hub or a keyboard. Then to the camera digital out put which looks like a mini USB port. Some will have you turn it on while others will have you press the "playback" button for about a second when it come on there will be a download screen appear on the computer, read your manual.
Okay after you have downloaded the pictures to the computer you need to format the memory card sound all complicated now but as you get onto it it's like breathing, you just do it.
Jan 18, 2011 | Nikon D40 Digital Camera with G-II 18-55mm...
Took memory card out to show pictures in new laptop. When done put memory card back in camera. Camera shows number of pictures listed but when you try to view the pictures the memory card says that it is...
Possibly, but you may no longer be able to view them on your camera. If you hadn't saved your pictures to your computer yet, try to do so. If your computer also has a problem seeing the pictures, you may need to use recovery software (see this link). Finally, after you've saved your photos to your camera, you should format the card in your camera to rejuvenate the card. If prompted to format your card by your computer, don't do it. It uses a different file handling structure than your camera.
Dec 30, 2010 | Kodak MX1063 Digital Camera
I took my memory card out of my camera,erased what was on it, add new pictures from my computer,to it,then put the memory card back in to the camera,and hooked the camera up to my television so I could...
Your mistake was in assuming your camera would recognize any information your computer put on the card. It won't because of the difference in the operating systems. To get your card to work properly in your camera again, you will have to format it in the camera.
Oct 31, 2010 | Canon PowerShot SD1000 Digital Camera
When i put card in camera it keeps saying reinsert card
You didn't say what camera you are using, check the specs for the camera and see if it can use a 2GB card. If the camera is not able to use that size card it will not "see" it.
Have you tried putting the card in a reader and formatting it on your computer?
If it the computer can't see it, the card may be bad.
Oct 09, 2009 | Sony 2GB Memory Stick PRO Duo Memory Card
Exilim camera, PNY optima SDHC memory card error
Hi
  1. 1 Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  2. 2 Open up 'My Computer'. You should see it under the list of available drives.
  3. 3 Check its contents first to make sure that you have the right drive.
  4. 4 In 'My Computer', right-click on the drive and choose 'Format'.
  5. 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  6. 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
Nov 10, 2008 | Casio Exilim EX-S2 Digital Camera
Auto delete
If you are refering to the pictures you took on the camera before you put in the memory stick, then you took those pictures on the internal camera memory. the camera is set to default on the memory card whenever one is in. To get to the pictures on the internal memory, remove the memory stick and you should be able to view the pictures. To transfer those pictures to your computer follow the steps in the manual, just be sure not to have the memory stick in.
Dec 23, 2007 | Sony Cybershot S650 Digital Camera
Gone?
buy a memorycard reader and stick it in the computer. not by usb cable on the camera
then
You might use a program like ontrack easy recovery.
choose data recovery then formatrecovery.
goodluck
Dec 07, 2007 | Canon PowerShot A410 Digital Camera
Canon PowerShot SD1000 Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
