Tune Tv Without Remote Control
I have a 51cm NEC ChromaVision television (not sure exact model). How do I access a menu to tune the channnels without a remote control?
  • Anonymous Jan 02, 2009
    how to tune in logik LCX 154 LN4 without remote
  • Anonymous Feb 23, 2009
    I also have an NEC Chromavision TV and I have the remote but can't figure out how to tune it. None of the buttons on the remote are labelled with something obvious, like "tuning", but I tried them all and got nowhere. Is there is a way to tune it without the remote?
5 Suggested Answers
  • 556 Answers
SOURCE: NEC FS6807S tuning
yes you can do it without remote control.
there is menu button on the front panel you can tune from there.
good luck.
Posted on Oct 12, 2007
SOURCE: old philips tv model no 21PT1532/05
this may be too late, but i had the same problem, then discovered that if you press the top of the volume up/down buttons together, the menu comes up. I was trying to solve another problem this way when I accidentally locked the TV. The instruction booklet tells me that you can only unlock it with the remote control, but that has long ago bit the dust. Does this mean that I'll never be able to turn it on again??!!
Posted on Jul 17, 2008
  • 5 Answers
SOURCE: How do I tune TV channels on my Sharp CX48G4 TV without a remote control? There is no tuning / settings panel on the TV itself which is very strange.
press the preset button on the front panel once then (TV should be on) the on the screen there should be words the likes of (Auto VHF 1 60.00mhz) now the Auto stands for auto tuning VHF stands for its frequency where its going to search the 1 stands for the channel where its going to start with 60.00mghz stands for the lowest signal to which its going to start now that you have understood all that just press the volume up button then it will automaticly locate all your working channels leave till it stops for when does it will start from channel 1 to which I believe that you be able to see the channel working so press the up button on the channel button to check the rest of your channels hope this will solve your problem!
Posted on Sep 16, 2009
SOURCE: Options to auto-tune or manual re-tune are greyed
Problem solved!!
According to the Sony website I needed to get a software download in order to fix this problem. I found out how to do this from the manual and realised that the re-tune menu I was looking at was for analogue only. The pictograms onmy remote control are a blurred but the manual helpfully provided a picture showing the correct program "info" button (next to 0) which has options to look at other things, including a "detailed set up" menu on the blue tab, which provides options for software download and re-tune of digital channels.
Incidentally, I discovered that my TV model was not quite as quoted above - it is KD-28DX200U, but expect the same process works for other oldish models.
Posted on Oct 03, 2009
SOURCE: tuning in a N-4858 nec tv
I have also recently been given a 10 year old nec n4858 tv and would like to know how to tune in the stations?
Posted on May 12, 2010
Can you tune in a JVC LT - 32DY8ZJ TV without a remote control?
As there is no Menu button on the front panel of the TV, you must have its remote control to tune it.
Nov 15, 2012 | JVC Televison & Video
Beko television need to tune without remote, seems to be no menu key
You must have its remote control to do this, as there is no Menu key in the front panel of the tV.
Jun 08, 2012 | Televison & Video
How do I tune my sylvania tv model SRT2127S to video mode with out a remote
If there is Menu button on the front panel to your tV, you can get ito its menu, and can select inputs, by entering into int input selection option. If there is no Menu button, there is no other way to select the input, without a remote control
Mar 08, 2012 | Sylvania Televison & Video
Nec tv RD1113e 79644901 cant tune stations, no menu button on remote
Hello
If there is no Menu button on the front panel of the tV, it will be difficult to get an auto tune function to this set. Try to muy one universal remote contol, which have setup codes for your NEC Tv.
Mar 01, 2012 | Televison & Video
Need to tune a trinitron kv-28f65u to a terristrial signal with no remote control, i can access the tuning menu but without the remote cannot press to OK to start tuning. Are there any combination of...
there is only autotune button on the panel which means it programmes all findable channels in serial order. sorry to say there is no other way without remote commander.
Sep 11, 2011 | Sony KV-28FX60 28" TV
Channel search on toshiba 27afx54 tv without remote control
Hello
There is no MRNU button on the front panel of your Toshiba TV. So it is impossible to tune it manually. You must have its remote control to select MENU options. OK.
Jan 02, 2011 | Toshiba 27AFX54 TV
Tuning in a N-4858 nec tv
Jun 15, 2009 | Televison & Video
How do i tune tv channels?
I am afraid thatyou need the original remote to access tuning universal remotes will not give you this option. An original remote will probably be very expensive check with your local TV dealer.
SUPER8
Jan 05, 2009 | Televison & Video
NEC FS6807S tuning
good luck.
Oct 12, 2007 | Televison & Video
Zenith wont tune channels
You must get a proper replacement remote control, once you can access the menu and find you cannot store above 13, place another post and i will help you further.
Oct 11, 2007 | Sony FD Trinitron WEGA KV-21CL10 21" TV
Televison & Video Logo
1,316 people viewed this question
Top Televison & Video Experts
Electro Med Services...
