Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
Removing the water filter and not replacing
Can you remove the water filter and not replace it in a Whirlpool Gold Refrigerator? Our water does not need filtering and I would like to remove it. I usually get water from tap anyway. Thanks for any info.
Billy
  • 37 Answers
Not with out re plumbing the unit underneath, it would be much easier to leave it in place.
Posted on Jan 03, 2009
Where is the filter for the ice maker on whirlpool refer model number ED2CHOXK005
Removing and replacing a water filter - base grill location
Filters situated in the base grill (below the freezer compartment) of Whirlpool-built side-by-side refrigerators are relatively simple to replace. Follow these two steps:
  1. Grasp the filter's end and make a one-quarter turn to the left.
  2. Pull the filter straight out.
To replace with a new filter, repeat these two steps in the opposite order, making sure to first remove the red cap from the filter. Proceed by pushing the filter straight into the slot, and then giving it a one quarter turn to the right.
Note: Replacing this type of filter is quick - there is no need to unplug your refrigerator when replacing it. Also, this filter should be replaced every six months.
Dec 18, 2010 | Whirlpool 21.8 cu. ft. Side-By-Side...
Putting in the new water filter to the Whirlpool gold fridge that goes in at the bottom.
Removing a water filter from the base grill of your Whirlpool brand refrigerator:
Dec 06, 2010 | Whirlpool GD5DHAXVY Stainless Steel Side...
We have a Amana refrigerator Model # SXD22SW2 and need to replace the water filter. We don't have the owner's/service manual for the refrigerator and I have looked everywhere on-line, including the Amana...
Removing a water filter from the base grill of your Amana brand refrigerator:
Oct 13, 2010 | Amana SXD524VW Side by Side Refrigerator
My Whirlpool side y side refrigerator purchased last year august is not dispensin water but making ice. I have replaced the filter but still not dispensing water.
there iis a switch on the door dispenser that operates when you slip your glas up for cold water and in doing this you should hear a click from the solinoid when this part of operation takes place
if no noise then probable the solinoid is faulty
if there is a noise then disconnect pipe going up inside of door which in toe kick area try pushinhing on switch to operate if no water comes out remove filter and try again, water should come out where the filter is situated
if no go replace water valve
Nov 10, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
My Whirlpool Gold 22 cu.ft. refrigerator stopped making ice. I recently changed the water filtration cartridge...could this be related? Any ideas on how I can fix this myself?
prior to the replacement of the cartridge, the ice maker is okay? if yes , try to re check the installation, there might be something to remove before installation,you can check it also by comparing to the old one, sometimes taking pictures before removing parts can help a lot.
Aug 27, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Water Filter
most whirlpools have the filter located in the bottom kickplate, right below the freezer door. turn counter-clockwise and toward you to remove. if it has never been removed before, they are hard to get out the first time.
Jul 24, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Can I remove refrigerator filter if hooked up to RO system?
its not necessary to keep the filter in place with an r/o system.
Thanks for using FixYa peyton
Feb 20, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
When use water dispeser water comes out from behind the refridge
no real "schematic" available showing how hte water lines are run, but illtell you that they start at teh rear of machine,incoming water, form there they travel to the water filter and into an opening under the refrig side. can be viewed by removing hte lower crisper(theres a holding tank) from ht tank goes back out nad heads for the door assy, so a simple trace of water lins will determine point of leak, usually a fiting or hte water lineitself has dry-rotted, in which case needs replacing, hter are no "hidden" lines with refrig, ohter then within the freezer door,and even that can be removed and replaced if ness.
Dec 01, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
How do you remove and replace the water filter for Conquest side by side
where is the water filter located?..
if it is inside the refrigerator top shelf, then just twist it countr clock wise and it would fall down right away.
if it is at the bottom front freezer side, turn it also counter clock wise and pull it to the front. it is just being hold on to by an o-ring at the tip of the filter.
tnx 4 using fixya,
drcool
Sep 13, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
348 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
