Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
After power failure makes noise but will not open or close
We operated it manually during power failure but now that we have power it makes a noise but doesn't move. Lights are on but no movement.
Any help would be appreciated!
  • 2 more comments
  • drsmcbride Jan 02, 2009
    chamberlain liftmaster. We have 2 of them and one of them worked well after the power was restored but the other won't do anything but make a motor noise.
  • Anonymous May 16, 2009
    I HAVE A GARAGE OPENER WHICH THE MOTOR MAKES NOISES, BUT NOT THING WORKS. WHAT MAY BE WRONG WITH THIS? PLEASE HELP ME. :)
  • Joseph Chapman
    Joseph Chapman May 11, 2010
    On the one that is not working does thhe traveler move? If it does not where on the rail is it stopped?
  • Joseph Chapman
    It sounds like the manual release is not reengaged. What kind of operator do you have?
    President:
  • 3,197 Answers
Remove the cover and look at the drive gear which is just in front of the motor. Chances are it is stripped. It is available at any door opener service company and comes with instructions.
Posted on May 16, 2009
  • 74 Answers
Make sure that the troley is engaged with the garage door first
Posted on Mar 10, 2009
How do I reset lift gate on 2004 lincoln navigator. It doesn't open or close anymore with the remote
Maybe your key fob needs a new battery !
Power Liftgate Initialization
NOTE:If the power liftgate system is turned OFF in the message center, the system cannot be activated with any switches or with the liftgate handle. The system will need to be turned ON for any power operation to occur.
NOTE:The power liftgate may not operate under the following conditions:
  • a low voltage or dead battery.
  • a disconnected battery
  • a power liftgate that has been left open for more than six hours.
  • a power liftgate that has been manually closed and left ajar.
If any of these conditions has occurred, the power liftgate must be reset.
  1. Manually close and fully latch the power liftgate.
  1. NOTE:If the power liftgate does not open during this step, refer to the symptom chart to diagnose the power liftgate for no operation.
    Power open the power liftgate by using the keyfob or overhead console switch.
  1. Once the power liftgate is fully open, close the power liftgate by using the keyfob or overhead console switch.
    This system can also set DTC'S
  2. POWER LIFTGATE MODULE DIAGNOSTIC TROUBLE CODE (DTC) INDEX (BODY CLOSURES) 501-03 Body Closures 2004 Expedition/Navigator DIAGNOSIS AND TESTING Procedure revision date: 08/23/2004
    Power Liftgate Module Diagnostic Trouble Code (DTC) Index
    DTC Description Source Action B1342 ECU Is Defective Power Liftgate Module INSTALL a new power liftgate module. REFER to Power Liftgate Modulein this section. B2477 Module Configuration Failure Power Liftgate Module REFER to Section 418-01. B2522 Vbatt1 Circuit Failure Power Liftgate Module GO to Pinpoint Test B. B2552 Vbatt2 Circuit Open Power Liftgate Module GO to Pinpoint Test B. B2698 Vbatt2 Circuit Failure Power Liftgate Module GO to Pinpoint Test B. B2699 Left Pinch Strip Open Or Short To Battery Power Liftgate Module GO to Pinpoint Test B. B2700 Right Pinch Strip Open Or Short To Battery Power Liftgate Module GO to Pinpoint Test B. B2701 Left Pinch Strip Stuck Active Power Liftgate Module GO to Pinpoint Test B. B2702 Right Pinch Strip Stuck Active Power Liftgate Module GO to Pinpoint Test B. B2703 Open/Close Switch Stuck Active Power Liftgate Module GO to Pinpoint Test B. B2704 Optical Sensor Power Short To Ground Power Liftgate Module GO to Pinpoint Test B. B2705 Optical Sensor 1 Input Not Active During Powered Gate Movement Power Liftgate Module GO to Pinpoint Test B. B2706 Optical Sensor 2 Input Not Active During Powered Gate Movement Power Liftgate Module GO to Pinpoint Test B. B2709 Gate Open Output Short To Battery Power Liftgate Module GO to Pinpoint Test B. B2710 Gate Close Output Short To Battery Power Liftgate Module GO to Pinpoint Test B. B2711 Gate Open Output Short To Ground Or Open Power Liftgate Module GO to Pinpoint Test B. B2712 Gate Close Output Short To Ground Or Open Power Liftgate Module GO to Pinpoint Test B. B2713 Unlatch Output Short To Ground Or Open Power Liftgate Module GO to Pinpoint Test B. B2714 Uncinch Output Short To Ground Or Open Power Liftgate Module GO to Pinpoint Test B. B2715 Cinch Output Short To Ground Or Open Power Liftgate Module GO to Pinpoint Test B. B2718 Gate Ajar Output Short To Battery Power Liftgate Module GO to Pinpoint Test B. B2721 Gate Ajar Output Short To Ground Or Open Power Liftgate Module GO to Pinpoint Test B. B2722 Open/Close Switch Active During Self-Test Power Liftgate Module GO to Pinpoint Test B. B2723 Glass Position Switch Active During Self-Test Power Liftgate Module GO to Pinpoint Test B. B2724 Forkbolt Switch Invalid During Self-Test Power Liftgate Module GO to Pinpoint Test B. B2725 Detent Switch Invalid During Self-Test Power Liftgate Module GO to Pinpoint Test B. B2726 Home Switch Invalid During Self-Test Power Liftgate Module GO to Pinpoint Test B. B2819 Gate Motor Circuit Short To Battery Power Liftgate Module GO to Pinpoint Test B. B2820 Gate Motor Circuit Short To Ground Or Open Power Liftgate Module GO to Pinpoint Test B. B2821 Cincher Motor/Unlatch Actuator Short To Ground Or Open Power Liftgate Module GO to Pinpoint Test B. B2822 Cincher Motor/Unlatch Actuator Short To Battery Power Liftgate Module GO to Pinpoint Test B. B2825 Movement Ceased Due To Excess Speed Deviation Power Liftgate Module GO to Pinpoint Test B. B2903 Chime Output Circuit Short To Battery Power Liftgate Module/ Liftgate Chime Module GO to Pinpoint Test C. C1935 Chime Circuit Failure Power Liftgate Module/ Liftgate Chime Module GO to Pinpoint Test C. U1950 UBP Communication BUS Fault UBP Communi cation REFER to Section 418-00. U2338 Invalid ACM Message Data Power Liftgate Module
Feb 05, 2015 | Lincoln Cars & Trucks
What are the common problems when a 2001 Lincoln navigator lifegate won't open
Do you have power lift gate ?
  • a disconnected battery.
If any of these conditions has occurred, the power liftgate must be reset before performing any pinpoint tests. For additional information, refer to
Power Liftgate Initialization NOTE: If the power liftgate system is turned OFF in the message center, the system cannot be activated with any switches or with the liftgate handle. The system will need to be turned ON for any power operation to occur.
NOTE: The power liftgate may not operate under the following conditions:
  1. NOTE: If the power liftgate does not open during this step, refer to the symptom chart to diagnose the power liftgate for no operation.
Jan 16, 2015 | Lincoln Cars & Trucks
Locked door flashes and oven will not start
Per GE Service bulletin # RA 03-01:
Serial Numbers affected: TZ, VZ, ZZ, AA, DA
Door will not open after self clean cycle due to motorized latch motor stuck in closed position or grinding noise during motorized lock operation.
Both issues are caused by interference of the inner vent trim slot with the latch arm as it travels to the closed position.
Correction:
Replace both the lock motor (WB14T10008) and inner vent trim (WB07T10179).
Failure to replace the inner vent trim will not correct the problem long term, and subsequent lock motor failures will occur.
Jul 27, 2014 | GE Profile JTP18 Electric Single Oven
Makes a really loud buzzing noise during operation
Unit uses a Magnetron and likely a power board called an inverter to run it. Someone would have to open the unit in a way where they might pinpoint where the sound is coming from and then take action--does not of course sound normal or good to me.
Dec 10, 2012 | Samsung SMH1622W
How to set powered sunroof open / close limits?
These limits are not adjustable.
Feb 21, 2012 | Cars & Trucks
My rear lift gate on 07 tahoe opens and closes its self weather the key is in the ignition or not, opens 1/2 way closes 3/4 then all the way up and all the way down, sometimes it sets off the car alarm- it...
Operation
A power open or close cycle can only be initiated from the fully closed or open positions while the vehicle is in park and the liftglass ajar switch input to the liftgate module is inactive. At any time during a power open or close cycle the operation can be reversed by pressing any of the open/close switches. The power liftgate can be switched to manual mode with the on/off switch in the overhead console and during manual operation the power latch will still operate. During power liftgate operation the liftgate module continuously monitors the liftgate position and load profile. The position is calculated from hall effect sensor counts and the electrical load of the gear motor is used to determine physical resistance to the liftgate. Both of these profiles must be learned before the liftgate can operate properly and relearned any time most liftgate components are serviced.
Object Obstruction Detection
The liftgate control module continuously monitors power liftgate operation and calculates its location and direction of travel using 2 hall effect sensors that are part of the gear motor assembly. The hall effect sensors are 3 wire sensors and are supplied with a 5 volt power circuit, ground and signal circuits from the liftgate control module. The hall effect sensor signal circuits are referenced from battery voltage within the liftgate control module and pulsed low by the hall effect sensors.
The power liftgate system uses a secondary object detection method which consists of object sensors fixed to both sides of the liftgate near the seal area. The object sensors consist of an internal fixed resistor and normally open switch contacts which when closed will bypass the resistor. The signal circuit is supplied 5 volts through a resistor and monitored within the liftgate control module, and during normal power liftgate operation the signal circuit should remain a fixed value. When an object presses one of the sensors the contacts close and the resistor is bypassed causing the signal circuit voltage at the module to go low.
Gear Motor Assembly
The liftgate motor is a bi-directional motor and open or close operation is the result of the direction of the motor rotation. The liftgate module controls the liftgate motor through the control circuits by suppling power and ground in the appropriate polarity. The motor control circuits are monitored by the liftgate module prior to activation for a high or low condition and during motor operation for any irregular current flow conditions.
The liftgate motor clutch engages or disengages the liftgate motor to the liftgate drive gear and is the component that determines power or manual operation. When the liftgate module supplies power to the clutch control circuit the clutch coil is energized and the liftgate motor is engaged to the liftgate drive gear so that power operation can occur. The liftgate module monitors the clutch control circuit at all times for a short high while in an inactive state or a short low or insufficient current flow while in an active state.
The full open switch is part of the gear motor assembly and will close and become active when the liftgate reaches the full open position. The full open switch signal circuit is supplied battery voltage through a resistor and monitored within the liftgate module. The liftgate provides a low reference circuit and when the switch contacts close the signal circuit goes low and the liftgate module determines the switch to be active.
DTC B153A 00: Liftgate Latch Switch Signal Circuit
DTC B153A 08: Liftgate Latch Switch Signal Circuit Signal Invalid
When calibrating the liftgate position, the liftgate module (LGM) is placed in a functional state to learn the liftgate travel limits. DTC B1019 00 will set automatically as an indicator that the system is in learn mode and not as a fault indicator. Once the travel limits are learned by the liftgate module, the LGM will exit calibration mode. If the LGM does not exit learn mode, DTC B1019 00 will remain current and indicate a fault.
DTC B153B 02: Liftgate Open Switch Signal Circuit Short to Ground
DTC B153B 05: Liftgate Open Switch Signal Circuit Short to Short to Battery or Open
DTC B153E 02: Liftgate Position Sensor Signal Circuit Short to Ground
DTC B153E 05: Liftgate Position Sensor Signal Circuit Short to Battery or Open
DTC B153E 08: Liftgate Position Sensor Signal Circuit Signal Invalid
Your best bet , take it to the dealer .
Aug 08, 2017 | Chevrolet Tahoe Cars & Trucks
Kenmore Elite HE3 washer won't spin during rinse cycle...
possible door lock failure fdl/error code f-11- maybe f-2 pump,,,
Dec 27, 2008 | Kenmore Elite HE4 Electric Dryer
KM-450MAB making beaping noise-compressor will not run
The cleaning valve must be closed duing the ice making mode. If it is open, the machine will not make ice. The beeping you hear is the alarm which is present on the machine. Remove the front cover and read the included text. This will tell you what alarm you have.
Oct 07, 2008 | Hoshizaki Cubelet Ice MakerDispenser Water...
Model KM-450MAB--Ice Machine Making Beaping Noise
Keeps on beeping? Every 3 to 4 seconds? Try putting the thermostat wires together. An open bin thermostat will cause this problem and the board see it and starts beeping.
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
371 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
