Question about GE JBP80 Electric Kitchen Range
Element Melted - Turned White Hot/on fire and would not go out
The element melted on our JPB80W0F2WW electric range. Element in oven turned white hot and melted and was on fire. Turning off power did not kill the fire so we killed the breaker. That stopped the fire. Why did the fire not go out when we turned off the oven if it was just a bad element? What cause the element to overheat?
  • exit13i84 Jan 02, 2009
    Why did the element stop burning only after I killed the breaker? Why did the fire not stop when we turned the oven off? Should I be replacing more parts other than the element?
    Scholar:
  • 111 Answers
You need to replace the element. Very easy to do. Cut power off at the breaker or unplug the stove FIRST (please!). Remove the two 1/4" screws securing the element to the oven cavity then two wires to the element just unplug. The wires can go either way. Call 1-800-626-2002 or go to the GE Appliance web site for the part. It is a WB44T10011 for the lower (bake) element and WB44T10009 for the top (broil) element.
Posted on Jan 02, 2009
The bake element (in over) will no longer get hot, should the element itself be replace or could it be something else? Range model RS675PXEQ0
It does sound like the bake element is probably the problem. Many ovens turn on the broil element with 120 volts to even out the heat in the oven or pulse the broil element. This may be why the oven is warm but not baking.
Nov 12, 2013 | Whirlpool 30" Self-Cleaning Freestanding...
Kenmore Elite Gas range, model # 790.79363401 The range works but the oven does not seem to heat up. It appears to ignite, just not get hot.
the problem should be from the heating element of your Kenmore Elite Gas range. The heating element is either defective or may have loosed contact as a result of heat coming out of the Oven. The heat coming from the oven may have melted the wire connected to the heating element which might not make it heat up.
Disassemble the oven and check if its actually the wire connected to heating element that got melted, or its time to replace the heating element.
Good luck.
Dec 15, 2010 | Kenmore Ovens
My lower oven element started to glow white hot so i turned it off . it continued to glow and travel about 6 inches until i pulled the plug, the element now has a break in it. is my control faulty too or...
The element can just be replaced, Sometimes these will start a small fire inside the oven. It's just the element has burned completely out. Some of these are tricky to take out, but it's fairly easy.
Apr 04, 2010 | GE Spectra JBP78 Electric Kitchen Range
The bottom element in my Kenmore oven just got red
Yes. Unplug the range, remove the screws, holding the element, remove element, disconnect wires on the ends of the element. Installation is the same in reverse. Complete model number is needed for the part# of the element
Mar 04, 2010 | Kenmore 96422 / 96424 / 96429 Electric...
Bottom oven heating element turned white hot and broke in the middle. Can I replace myself?
This is a common problem and easy repair. Locate the model number onside the oven door frame. Purchase the element based on the model number. TURN OFF the power to the oven. Unscrew the 2 screws inside the oven holding the element to the back wall. Gently pull the element forward. The wires will be short.Remove the wires from the broken element. Place them on the new element. Re-insert the element terminals and attach the screws.
TURN ON the power. Bake me some cookies and send them to me.
Jul 05, 2009 | Maytag MER6772 Gemini Electric Kitchen...
BROILER ELEMENT WOULD NOT TURN OFF WITH OVEN
I just had the same problem! I would not have known that the broiler was still on, since the red light was off, except that the oven got so hot that the drips started to burn. The only solution was to turn off the circuit breaker.
This sounds like a serious safety issue!
My guess so far is that there is a broiler relay that has shorted in the on position and will need to be replaced. Until then I cannot use the stove or oven.
Apr 30, 2009 | GE Spectra JBP78 Electric Kitchen Range
Bottom baking element remains on
From a consumer repair stand-point; I would inspect, test for continuity and or replace your oven bake heating element.
How to Replace an Oven Bake Heat Element: While ensuring power off when servicing; Remove (2) mounting screws and slowly back-out the element about 3" or so. Then, disconnect and remove wires located on each side of heat element; re-install new element.
Should problems still exist, contact me.
- C
Jan 27, 2009 | GE 30" Self-Cleaning Freestanding Electric...
Eliment in oven will not turn off
Sounds like the element is still getting a feed from the thermostat, even though it is in the Off position
If it has a temp indicator light and this is still glowing then you definately have a faulty thermostat.
The other possibility is that there is an earth fault on the element, and this could cause problem.
Plz rate this solution.
Thanks.
Dec 15, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
The hot surface light is staying on and will not go off. Is there a way to fix this?
Each element contains a sensor to detect when the element is hot, this sensor has failed. The element will have to be replaced. If there is only one light to indicate hot surface, you will have to determine which element has failed.
Jun 09, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
GE JBP80 Electric Kitchen Range Logo
532 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
